    different screen resolution
    2 Posts 2 Posters 904 Views 2 Watching
    • B
      bdream
      Hi guys,
      I startet right now with my experimental MagicMirror.
      I took an old LCD, an Pi0 and brought up my configuration of an alright running MM.
      Now, as I have different screen resolution I have to tune my custom.css and perhaps the modules in use.
      My question is:
      Is there a possibility, that MM swiches on the base of the connected screen
      a. different costum.css (expl. custom.4x3-1024x768, custom.XxY-1680x105, …) or
      b. different sections within a custom.css
      That would give a possibility maintaining only one (set of) custom.css, don’t matter the display connectet to MM
      Additional I would like to do same with config.js on base of connectes screen.
      Any ideas?
      cheers, bdream
        sdetweil @bdream
        @bdream well, the main.css is hard coded to 1920/1080…
        I have an adjusted one that uses view height/width
        view height/width main.css
        config.js doesn’t adjust and most modules (including mine) are pixel based
