    MMM-Remote-Control (undefined error)
    3 Posts 2 Posters 901 Views 2 Watching
    • Q Offline
      qqqqqqqq
      I installed the MMM-Remote-Control module for the 3rd time. It gets installed successfully. But here are few problems that I face when MagicMirror Starts.
      1. Instead of showing me the pi’s local ip address, it is showing me the default “http://ip-of-your-mirror:8080/remote.html”. I am able to access it with another device in the same network, but why won’t it show me y ip?
      2. I am unable to see any icons on the magicmirror remote website and I see this error (file attached) 2020-06-16-182258_1360x768_scrot.jpg
      Here is my congif file
      ar config = {
      	address: '0.0.0.0', // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.1/120", "192.168.0.1/24"], // Set [] to allow all IP addresses
      			module: "MMM-Remote-Control",
      			// you can hide this module afterwards from the remote control itself
      				customCommand: {},  // Optional, See "Using Custom Commands" below
      				customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
      				showModuleApiMenu: true, // Optional, Enable the Module Controls menu
      				apiKey: "",         // Optional, See API/README.md for details
        sdetweil
        there is a bug in 2.11, you need to replace the contents of one file ~/MagicMirror/js/socketclient.js
        with a prior version or, copy the old contents from here
        https://forum.magicmirror.builders/topic/12485/has-anyone-got-mmm-remote-control-working-on-mm-2-11/10?_=1592231548914
        • Q Offline
          qqqqqqqq
          Okay, thanks for your help. It is working now.
          There are still few issues, if you can help.
          1. The exact ip still isn’t shown on the magic mirror.
          2. The icons aren’t still visible, like it was in earlier versions.
          3. The top buttons just showing “All” and not “Show all” or “Hide All”.
