    When weather updates module unhides...
    8 Posts 3 Posters 5.2k Views 3 Watching
    • SnilleS Offline
      Snille Module Developer
      Hi all,
      I’m currently building a MM2 (2.1.0). For the moment I’m trying to find out why the weather (both current and forecast) shows up when updating.
      This is the scenario:
      I have usually the “local” weather (both current and forecast) shown. Then when my user logs in (using face recognition) then the local weather (both current and forecast) gets hidden and the weather (both current and forecast) from another location should be shown. Then when my user logs out, the local weather (both current and forecast) should be shown again and the “other” (both current and forecast) should be hidden.
      What I managed so far:
      When I start MM2, both weather locations (local and other and both current and forecast)) are shown. Then when the user logs in the local gets hidden and the “other” gets shown (stays shown). When the user logs out the local one get shown and the “other” hides. All good, I could live with the startup problem. :)
      Now, when the weather updates, everything (local and other, both current and forecast) are shown again and stays that way until a user logs in and out again.
      So, my config:
      First in the config is the Face recognition part(s):
      		module: "MMM-Facial-Recognition",
      		position: "top_bar",
      		header: "",
      			users: [
      				"Snille",
      				"Louise",
      				"Martin"
      			trainingFile: "modules/MMM-Facial-Recognition-Tools/facetrainer/training.xml",
      			logoutDelay: 30,
      			interval: 1
      And then further down the weather part(s)
      		module: "currentweather",
      		classes: "snille",
      		header: "",
      			locationID: "2679300",
      			appid: "b78a1a22ab05beb1fd30b2bf6013db64",
      			iconTable: {
      				"01d": "wi-day-sunny",
      				"02d": "wi-day-cloudy",
      				"03d": "wi-cloudy",
      				"04d": "wi-cloudy-windy",
      				"09d": "wi-showers",
      				"10d": "wi-rain",
      				"11d": "wi-thunderstorm",
      				"13d": "wi-snow",
      				"50d": "wi-fog",
      				"01n": "wi-night-clear",
      				"02n": "wi-night-cloudy",
      				"03n": "wi-night-cloudy",
      				"04n": "wi-night-cloudy",
      				"09n": "wi-night-showers",
      				"10n": "wi-night-rain",
      				"11n": "wi-night-thunderstorm",
      				"13n": "wi-night-snow",
      				"50n": "wi-night-alt-cloudy-windy"
      			showPeriodUpper: true,
      			showHumidity: true
      		module: "weatherforecast",
      		classes: "snille",
      		header: "Väder i",
      			iconTable: {
      				"03d": "wi-cloudy",
      				"10d": "wi-rain",
      				"13d": "wi-snow",
      				"50d": "wi-fog",
      			showRainAmount: true
      		classes: "default",
      		header: "",
      			locationID: "2724435",
      			iconTable: {
      				"03d": "wi-cloudy",
      				"10d": "wi-rain",
      				"13d": "wi-snow",
      				"50d": "wi-fog",
      			showHumidity: true
      		classes: "default",
      		header: "Väder i",
      			iconTable: {
      				"03d": "wi-cloudy",
      				"10d": "wi-rain",
      				"13d": "wi-snow",
      				"50d": "wi-fog",
      The rest of the modules get hidden and shown correctly as expected (MMM-SystemStats, MMM-bitcoin, calendar, compliments, newsfeeds (2), MMM-Mail, MMM-NetworkScanner and MMM-fitbit).
      It’s just the weather that gives “problems”. :)
      Anyone have any ideas?
      Best regards Erik
      If you cant find it, make it and share it
      MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
      • SnilleS Offline
        This is solved. It was actually the Profile-Switcher that created the problem. :)
          Ralf @Snille
          @Snille Can you please explain this more precisely. I have a similar problem with MMM-Instagram.
          Best regards Ralf
          SnilleS 1 Reply Last reply Reply Quote 0
          • SnilleS Offline
            Snille Module Developer @Ralf
            @Ralf Ok, this was (infact still is) my case:
            1. I have setup “profiles” showing different modules using MMM-ProfileSwitcher (triggerd by either MMM-Facial-Recognition, MMM-TouchNavigation or MMM-ModuleScheduler).
            2. When a “profile” is activated only the modules in that profile is suppose to be shown.
            For the moment the default “currentweather” and “weatherforecast” is set to show in only one of my defined profiles. However, when a profile that do not have (any one of) those modules is activated, the weather modules are hidden until they “update”, then they show them self even if the profile currently selected should not show them.
            Then I started to “lock” modules with the ProfileSwitcher and that solved the “popup-on-update-problem”, but that resulted in modules not showing up when triggered by ModulesScheduler instead. So I disabled locking again.
            Update: Forgot that I also have disabled the “schedule” for switching profiles. The reason being that if I have specified a profile to be shown at a specific time frame, I can not use the TouchNavigation to switch to another profile at any time because all the modules are locked by the Scheduler…
            So, for the moment, I still have the problem. However it’s only those two modules behaving this way so far. :)
            • SnilleS Offline
              HI all again,
              Am I the only one having this problem? The two default modules “currentweather” and “weatherforecast” does not respect the “hidden” (of not locked) attribute when they update.
              Anyone else? :)
                Antflips @Snille
                @Snille I have the same issue but am yet to find the solution. The modules appear at start up, but do respect the hidden state after the first user has logged out.
                Did you identify the fix for this?
                • SnilleS Offline
                  Snille Module Developer @Antflips
                  @Antflips Hi, nope unfortunately not. It is still “misbehaving”. You can use the “lock” mechanism in “Profile Switcher” if you want, but it’s then locking all hidden modules. Then it works, but then you can not un-hide with any hidden modules with other module. And that’s what I wanted to be able to do.
                    Antflips @Snille
                    @Snille I’m using the MMM-Echo module for my face recognition and to show and hide modules depending on the person. If you ignore the fact that the Weather and Forecast modules don’t hide until the first person has “logged out”, it works great.
