    disable NO signal message
    22 Posts 9 Posters 24.5k Views 8 Watching
      Desertswing @bhepler
      @bhepler , But when i want to keep my raspberry always online i have to do something about this situation, it is possible to put new firmware on the TV but i can`t find any modding software thats easier then Hexa codes to configure…
      with an LG tv its possible because u can get the firmware software download on a USB drive from the TV, but i want to use a tv that i don`t use anymore.(Recycle project).
        Desertswing @aboulezz
        @aboulezz said in disable NO signal message:
        I faced the same problem with my LG screen but found a work around.
        Step 1) I used wiringpi.com and modified the simple blink example to send out just one impulse:
        #include
        int main (void)
        wiringPiSetup () ;
        pinMode (0, OUTPUT) ;
        digitalWrite (0, HIGH) ; delay (200) ;
        digitalWrite (0, LOW) ;
        return 0 ;
        Step 2) I modified the PIR modules’ node_helper.js so within the functions activate / deactivate don’t enable/disable the HDMI output but execute my compiled ‘blink’ command.
        Step 3) I hard - wired the singal pin to the (with resistor / transistor) to the screens power-button.
        done :-)
        Can`t i use this instead and make my raspberry a longer time to get the HDMI port visible to the TV, ore do i get the message still when giving the HDMI port a command to show himself. (If u know what i mean).
