    help with MMM-MyWordClock and MMM-PIR-Sensor
    1 Posts 1 Posters 290 Views 1 Watching
    • L
      lostcheese
      Re: Help Translating Word Clock
      @j-e-f-f
      thanks for the awesome module!
      i had a question regarding the MMM-PIR-Sensor module settings for use in conjunction with your module. do i just need to set the sensorPin number as follows or add anything else?
      module: ‘MMM-PIR-Sensor’,
      sensorPin: 22
      also, would it be possible to set the clock as a module within the main magic mirror without PIR-Sensor involvement or would that require some significant rewriting on the main code?
