    MMM-plex-recently-added error
    3 Posts 2 Posters 868 Views 2 Watching
    • V
      v4r23
      Just getting started with MagicMirror and getting this error:
      [2020-07-01 10:37:37.853] [LOG]    Whoops! There was an uncaught exception...
      [2020-07-01 10:37:37.854] [ERROR]  TypeError: this.config.types.forEach is not a function
          at Class.update (/home/pi/MagicMirror/modules/MMM-plex-recently-added/node_helper.js:29:23)
          at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-plex-recently-added/node_helper.js:21:12)
          at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:113:11)
          at Socket.emit (events.js:200:13)
          at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          at processTicksAndRejections (internal/process/task_queues.js:82:9)
      [2020-07-01 10:37:37.883] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-07-01 10:37:37.884] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      module config:
                              module: 'MMM-plex-recently-added',
                              position: 'lower_third',
                                              token: '[my token]',
                                              hostname: '[ip of my plex server on my lan]',
                                              port: 32400,
                                              types: 'movie',
                                              limit: 10,
      • V
        v4r23
        Types requires an array.
        types: ['movie']
        Reply Quote 1
          sdetweil @v4r23
          @v4r23 types must be entries in an array
          types: [“movies”],
          even if only one entry
          Reply Quote 1
