    PIR-module -> NODE_MODULE_VERSION...
    3 Posts 3 Posters 941 Views 3 Watching
    • P
      pw94
      Hey mirrorfans, one week ago i startet my first Mirror project and every module i installed worked perfectly. But the modules “MMM-PIR” or “MMM-PIR-Sensor” are getting me mad.
      As every modules i followd the discription to install but i did not get the modules to run. I Always get These errorcode :
      " WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node’
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 64. This version of Node.js requires
      NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
      the module (for instance, using npm rebuild or npm install). "
      Two days i googled the Problem and tried many Things (reinstall,rebuild,delete node_modules etc) but i have to confess i really dont know what to do :/ . Please help me.
      greets pw
      C M 2 Replies Last reply Reply Quote 0
      • C
        Cyric @pw94
        @pw94 I was never able to get either of those to run for me. I ended up copying the python script from https://www.putorius.net/using-pir-sensor-for-motion-detection.html and it’s been working fine.
        • M
          majik655 @pw94
          @pw94
          I had issues also running those PIR mods… the only mod that worked for me was ‘MMM-NewPIR’,
          I love this module. It also has the ability to not TURN OFF the display but rather just throw up a black screen or “hide” the modules .
          my config for MMM-NewPIR is below if it helps any.
          		  	module: 'MMM-NewPIR',
          			position: 'bottom_left',
          				useSensor: true,
          				sensorPin: 22,
          				reverseValue: false,
          				delay: 2* 60 * 1000,
          				turnOffDisplay: false,
          				ecoMode: true,
          				governor: "",
          				text: "",
          				counter: false,
          				rpi4: true,
          				debug: false
