    Spotify with MMM-Assistant2Display
    15 Posts 4 Posters 3.4k Views 4 Watching
    • ? Offline
      A Former User
      sorry … euh I don’t write it in main topic ?
      • K Offline
        killerjoe34
        @sdetweil said in Spotify with MMM-Assistant2Display:
        if u install the Spotify Connect app on your windows machine, it will show u the devices it knows about and let you start play on one of them. (if u have a spotify premium account)
        That’s getting clearer :)
        @Bugsounet said in Spotify with MMM-Assistant2Display:
        why using “with-MMM-Spotify.js” recipe ?
        [pourquoi utilisez-vous le recipe de “with-MMM-Spotify.js”]
        I will broken the search spotify process
        [Cela va poser souci pour la découverte des lien spotify et ne trouvera rien]
        connectTo: null
        Ok, I removed Spotify recipe
        And null is the name I left by default it seems :D
        If I enable this device (null) on the Spotify App, I can hear the music through my MM, so that looks good
        But if I say “Jarvis, play Thriller on Spotify”, GA says “opening app” and nothing :(
          sdetweil @Guest
          @Bugsounet i have not read your doc in a long time, been busy…
          • K Offline
            killerjoe34
            Oh strange thing, I just opened teh app on windows again and MJ began to sing on my MM :D
            I guess I don’t have the right command words, where can I find or modify them ?
            • ? Offline
              A Former User
              @killerjoe34 said in Spotify with MMM-Assistant2Display:
              connectTo: null
              It’s a tag to say to spotify module: there is no Librespot installed so … i will never connect to it automaticaly
              [c’est un tag qui permet de dire qu’il n’y a pas Librespot installé, donc il ne se connectera pas automatiquement]
              You have to set the name of your Spotify device
              [Vous devez donc definir le nom du lecteur]
              connectTo: "LibreSpot",
              For example
              • K Offline
                killerjoe34
                connectTo: “LibreSpot”,
                For example
                Great, I did that and that works :D
                Thanks a lot !!!
                Where can I get the commands ? Cause I can’t stop it now ;)
                • ? Offline
                  A Former User @killerjoe34
                  euh désolé mais je sais comment je code mon module ;)
                  Si vous ne fait pas ce que je dis, cela va risque d’être compliqué
                  Note: je suis français
                  • K Offline
                    killerjoe34 @Guest
                    Ah si si ! J’essaie de suivre et je modifie à mesure, j’ai pleinement confiance en vos capacités, n’en doutez pas ;) Et d’ailleurs ça fonctionne maintenant grâce à vous !
                    Je cherche juste quelles commandes lui lancer :D
                    • ? Offline
                      A Former User
                      In GA configuration, you can set your prefered command to stop all process of A2D
                      A2DServer: {
                        useA2D: true,
                        stopCommand: "stop"
                      Actually, it’s an english value
                      so set stopCommand: "stoppe" for frenchies
                      • K Offline
                        killerjoe34
                        Thanks again ;)
