    Spotify with MMM-Assistant2Display
    15 Posts 4 Posters 4.7k Views 4 Watching
    • K
      killerjoe34
      Hi everyone,
      I’m a bit lost with Spotify, both MMM-GoogleAssistant and MMM-Assistant2Display are installed.
      LibreSpot is also ok
                              module: "MMM-GoogleAssistant",
                              position: "fullscreen_above",
                                assistantConfig: {
                                  latitude: 44.13333,
                                  longitude: 4.08333,
                                micConfig: { // put there configuration generated by auto-installer
                                  recorder: "arecord",
                                  device: "plughw:3",
                                A2DServer: {
                                useA2D: true,
                                stopCommand: "stop"
                                recipes: [ "with-MMM-Spotify.js", "with-radio_fr.js" ]
                                module: "MMM-Assistant2Display",
                                  debug:false,
                                  useYoutube: true,
                                  screen: {
                                    useScreen: false,
                                    delay: 5 * 60 * 1000,
                                    turnOffDisplay: true,
                                    ecoMode: true,
                                    displayCounter: true,
                                    displayBar: false,
                                    displayStyle: "Text",
                                    text: "Auto Turn Off Screen:",
                                    detectorSleeping: false,
                                    governorSleeping: false,
                                    rpi4: false
                                 spotify: {
                                    useSpotify: true,
                                    useIntegred: true,
                                    useLibrespot: true,
                                    connectTo: null,
                                    playDelay: 3000,
                                    minVolume: 10,
                                    maxVolume: 100,
                                    updateInterval: 1000,
                                    idleInterval: 10000,
                                    username: "xxxxxxxxxxxxxxxxxxxxxxx",
                                    password: "xxxxxxxxxxxxxxxxxxxxx",
                                    CLIENT_ID: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                    CLIENT_SECRET: "xxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                    deviceDisplay: "Listening on",
                                    usePause: true
      Logs seem ok
      [2020-07-16 13:04:05.306] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.2.1
      [2020-07-16 13:04:05.335] [LOG]    [A2D] MMM-Assistant2Display Version: 2.2.1
      [2020-07-16 13:04:06.795] [INFO]   Newsfeed-Fetcher: Broadcasting 21 items.
      [2020-07-16 13:04:07.159] [INFO]   Newsfeed-Fetcher: Broadcasting 32 items.
      [2020-07-16 13:04:08.482] [LOG]    [SPOTIFY] Launch Librespot...
      [2020-07-16 13:04:08.601] [LOG]    [A2D] Assistant2Display is initialized.
      [2020-07-16 13:04:08.657] [LOG]    [SNOWBOY] Model selected: jarvis
      [2020-07-16 13:04:08.672] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
      [2020-07-16 13:04:08.689] [LOG]    [ASSISTANT] RECIPE_LOADED: with-MMM-Spotify.js
      [2020-07-16 13:04:08.711] [LOG]    [ASSISTANT] RECIPE_LOADED: with-radio_fr.js
      [2020-07-16 13:04:08.716] [LOG]    [ASSISTANT] Assistant2Display Server Started
      [2020-07-16 13:04:08.719] [LOG]    [ASSISTANT] Google Assistant is initialized.
      What am i supposed to do now ? What is missing to make it work, what command ? (tried music play and GA seems to understand)
      but nothing happens…
      French radios work fine, youtube news also in full screen.
      Thanks a lot for this great work btw, you must have spent hundreds of hours developping these :)
        sdetweil @killerjoe34
        @killerjoe34 by default, the pi does not enable PLAYING spotify music ON the PI… the librespot or raspotify modules must be installed outside of MM and configured to enable the PI to be a spotify device.
        if u install the Spotify Connect app on your windows machine, it will show u the devices it knows about and let you start play on one of them. (if u have a spotify premium account)
        there u can tell if the librespot or raspotify setup is correct and working
        THEN
        you can use the MMM-Spotify module to SEE what is playing wherever
        and
        the A2D extension to send commands to start/stop play on the spotify device.
          A Former User
          @sdetweil : now librespot is embed on A2D
          @killerjoe34
          recipes: [ “with-MMM-Spotify.js”, “with-radio_fr.js” ]
          why using “with-MMM-Spotify.js” recipe ?
          [pourquoi utilisez-vous le recipe de “with-MMM-Spotify.js”]
          I will broken the search spotify process
          [Cela va poser souci pour la découverte des lien spotify et ne trouvera rien]
          connectTo: null
          You need to give the name of your Librespot device, I will connect to it when you want to play music
          [Vous devait renseigner le nom que vous avez donner a votre Lecteur Librespot, pour qu’il se connecte a lui a la demande]
          and You can call any spotify music with play Thriller on Spotify after activating assistant
          [ Ensuite vous pouvez demander a l’assistant Mets Thriller sur Spotify une fois activé]
          [L’assistant decouvrira le lien et ouvrira librespot pour ecouter la musique demandé]
            sdetweil @Guest
            @Bugsounet said in Spotify with MMM-Assistant2Display:
            thank you for that info…
              A Former User
              sorry … euh I don’t write it in main topic ?
              • K
                killerjoe34
                @sdetweil said in Spotify with MMM-Assistant2Display:
                That’s getting clearer :)
                connectTo: null
                Ok, I removed Spotify recipe
                And null is the name I left by default it seems :D
                If I enable this device (null) on the Spotify App, I can hear the music through my MM, so that looks good
                But if I say “Jarvis, play Thriller on Spotify”, GA says “opening app” and nothing :(
                  sdetweil @Guest
                  @Bugsounet i have not read your doc in a long time, been busy…
                  • K
                    killerjoe34
                    Oh strange thing, I just opened teh app on windows again and MJ began to sing on my MM :D
                    I guess I don’t have the right command words, where can I find or modify them ?
                    ? 1 Reply Last reply
                      A Former User
                      @killerjoe34 said in Spotify with MMM-Assistant2Display:
                      connectTo: null
                      It’s a tag to say to spotify module: there is no Librespot installed so … i will never connect to it automaticaly
                      [c’est un tag qui permet de dire qu’il n’y a pas Librespot installé, donc il ne se connectera pas automatiquement]
                      You have to set the name of your Spotify device
                      [Vous devez donc definir le nom du lecteur]
                      connectTo: "LibreSpot",
                      For example
                      • K
                        killerjoe34
                        connectTo: “LibreSpot”,
                        For example
                        Great, I did that and that works :D
                        Thanks a lot !!!
                        Where can I get the commands ? Cause I can’t stop it now ;)
                          A Former User @killerjoe34
                          euh désolé mais je sais comment je code mon module ;)
                          Si vous ne fait pas ce que je dis, cela va risque d’être compliqué
                          Note: je suis français
                          K 1 Reply Last reply
                          • K
                            killerjoe34 @Guest
                            Ah si si ! J’essaie de suivre et je modifie à mesure, j’ai pleinement confiance en vos capacités, n’en doutez pas ;) Et d’ailleurs ça fonctionne maintenant grâce à vous !
                            Je cherche juste quelles commandes lui lancer :D
                              A Former User
                              In GA configuration, you can set your prefered command to stop all process of A2D
                              A2DServer: {
                                useA2D: true,
                                stopCommand: "stop"
                              Actually, it’s an english value
                              so set stopCommand: "stoppe" for frenchies
                              • K
                                killerjoe34
                                Thanks again ;)
                                  banbutcher
                                  @killerjoe34
                                  if i leave out the recipe with-MMM-Spotify, my a2d will not follow instructions? i have tried the with-A2DSpotify recipe and the search doesnt work.
                                  speaking of search… is anyone elses spotify search results a bit weird… for example i say “jarvis play jack johnson on spotify” it returns a crazy song called jack johnson/ghostrider. if i get more specific and ask “jarvis play jack johnson, upside down on spotify” it returns an the sone upside down but its from Acoustic tribute to jack johnson album. its as if the mainstream artists are avoided!?
                                  edit:
                                  ive just seen this…
                                  so am i right in thinking that search is still under development?
                                  thanks very much for all time and effort in modules! :)
                                  Richie
