    MMM-GoogleAssistant doesn't run
    20 Posts 6 Posters 5.2k Views 6 Watching
      Mauro-1998 @Guest
      @Bugsounet Ok, I will wait, thanks!
      • ? Offline
        A Former User
        @Mauro-1998
        There problem is not there
        The problem is a snowboy library needed by snowboy in main core is not found
        so it’s not an GA issue but a snowboy isssue
        I will install Ubuntu for see what happen
          Mauro-1998 @Guest
          @Bugsounet Ok thanks for your help!
            Mauro-1998 @Guest
            @Bugsounet
            Fix the problem by re-installing the snowboy library at @ bugsounet / snowboy, thanks for your help!
            • ? Offline
              A Former User
              fixed so ?
                Mauro-1998 @Guest
                @Bugsounet
                yes, install the library again in case it was an installation error and it worked, thanks for your help, it works perfectly!
                  bryan_1 @Mauro-1998
                  @Mauro-1998 hai, could you tell me how you reinstall the snowboy library? I have the same Problem, after installing the GoogleAssistant only black screen :-(
                  Thanks.
                  • ? Offline
                    A Former User
                    can help with … reading wiki for example ?
                      bryan_1 @Guest
                      @Bugsounet sorry, I am a beginner. I have installed GoogleAssistant successfully
                      as in Wiki. But when I start MagicMirror, I have only blank screen.
                      • ? Offline
                        A Former User
                        @bryan_1 said in MMM-GoogleAssistant doesn't run:
                        for me you have updated the module
                        I have installed GoogleAssistant successfully as in Wiki
                        now you tell me you have just installed
                        Sorry but I don’t know which answer to choose
                        or just maybe i’m stupid !?
