    MMM-Ratp
    4 Posts 3 Posters 906 Views 3 Watching
      Stef81
      Hello,
      I’ve search on this forum but couldnt find anyone with the issue i’m facing.
      With MMM-Ratp module for French Public Transport:
      I’m using this code to make it work:
      module: ‘MMM-Ratp’,
      position: ‘bottom_left’,
      header: ‘’, // the title that will be displayed on top on the widget
      config:{
      debugging:true,
      apiURL:‘https://api-ratp.pierre-grimaud.fr/v4/schedules/buses/178/Chanzy/A’, // more info about API documentation : https://github.com/pgrimaud/horaires-ratp-api
      I can get the data but doesnt display anything else
      so it look like this
      5 min
      12 min
      Thx a lot
        sdetweil @Stef81
        @Stef81 doc says you need to specify the header yourself
          Stef81
          Yeah Sorry for this I messup with my copy / Paste Source
          Even with Header set to XXXX
          XXX doesnt appears on the Magic Mirror…
          DOC says something confusing at the end:
          Troubleshooting
          The first thing to do in to set a debbuging setting in the config file because it will enable more verbose trace. Ensure that any setting is followed by a comma (that’s the common mistake with Magic Mirror²)
          module: ‘MMM-Ratp’,
          position: ‘top_right’,
          header: ‘RATP’ // please leave this value, it will be replaced anyway,
          config:{
          debugging:true,
          apiURL:'https://api-ratp.pierre-grimaud.fr/v3/schedules/bus/163/dumont+d\‘urville+++belgique/A’,
          Doc says also this:
          Configuration
          To get bus timetable, you’ll need to specify the transport line, the station and the destination. These information will have to be specified in the configuration (https://github.com/lgmorand/MMM-Ratp/blob/master/MMM-Ratp.js#L14-L23)
          I dont understand If I have to setup something in the configuration file of MMM-RATP ? ??
          • O Offline
            Odissine
            Hello
            J’ai semble-t-il le meme soucis … j’ai ajouté 3 fois le module MMM-Ratp pour avoir les infos sur le une ligne de bus, ensuite pour un rer et enfin le metro… Ceci donne :
            		module: 'MMM-Ratp',
            		position: 'top_right',
            		header: 'Bus 113 (vers la gare)', // the title that will be displayed on top on the widget
                 		config:{
            		        apiURL:'https://api-ratp.pierre-grimaud.fr/v4/schedules/buses/113/place%2Bde%2Bla%2Bresistance/R',
            			 module: 'MMM-Ratp',
            			 header: 'RER A (vers Nation)', // the title that will be displayed on top on the widget
            			 config:{
            				 apiURL:'https://api-ratp.pierre-grimaud.fr/v4/schedules/rers/A/neuilly%2Bplaisance/A',
            			 module: 'MMM-Ratp',
            			 header: 'Metro 9 (vers Grands Boulevards)', // the title that will be displayed on top on the widget
            			 config:{
            				 apiURL:'https://api-ratp.pierre-grimaud.fr/v4/schedules/metros/9/nation/R',
            Tout fonctionne nicke mais les headers ne s’affichent pas … QUand je regarde le code html, je vois undefined en lieu et place de la valeur (avec en plus style=“display:none” … )
            Bref Si qq’un peut m’aider ;)
            Merci :p
