    NPM RUN CONFIG:CHECK not working
    3 Posts 2 Posters 731 Views 2 Watching
    • D
      dbrett25
      Hi all,
      I had to get a new SD for my raspberry and i am currently redoing my magic mirror. I’m having issues when trying to run Config checker, even when using the sample config. My MM starts up fine but as i start adding modules i want to be able to check it etc.
      This is the error i get:
      [2020-08-03 17:39:15.028] [LOG] Line 1 col 1 Definition for rule ‘prettier/prettier’ was not found.
      /home/pi/MagicMirror/js/check_config.js:66
      throw new Error(“Wrong syntax in config file!”);
      Error: Wrong syntax in config file!
      at /home/pi/MagicMirror/js/check_config.js:66:10
      at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.12.0 config:check: node js/check_config.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.12.0 config:check script.
      I’ve tried googling but without any luck so i’m hoping somebody on here might have some knowledge!
      Thanks in advance :)
        sdetweil
        yes, its broken on 2.12
          sdetweil
          see the pinned topic at the top on Troubleshooting section for work around
