Display won't rotate into a vertical position
Let me start by saying I am very new to this. But I having a problem with my display not rotating. I have went into config.txt and have added (display_rotate=1) but it does not seem to work. I am running 2.12.0 on a RPi4 4GB RAM. I also have MMM-GoogleAssistant & Google2Display modules installed. Everything is running beautifully, I just want to change orientation of the display and I’m hoping it will apply to the modules I have installed as well. If anyone can help, it would be greatly appreciated. Thank you.
Thank you very much! Is there a way I can make the resolution any better though?
Never mind I apologize. I started to do more than I needed to. Thank you very much though you’re the man!
@smbarr37 well there is 1080p, which is 1920x1080, and 4k which is 3840x2160
I don’t know what your monitors can do… I have a 4k tv
I put it back on 1920x1080. Only thing I gotta alter is removing the boarders and mess around with the Google Assistant visuals. Thanks again!
@smbarr37 sudo raspi-config should allow you to adjust the borders
