    Running MM2 on a Mac Mini
    3 Posts 2 Posters 2.9k Views 2 Watching
    • C Offline
      core
      I´m planning to modify my MM to an “Apple mirror” using a Mac Mini.
      Unfortunately, I have no idea how to setup MM2 on a Mac Mini - I did run MM on a RPi3 before folowing the installation described in the documentation for RPi so that was not a problem.
      Has anybody here successfully run MM2 (current version) on a Mac/Mac Mini and can tell me step by step how to setup and get it running? This would be great!
      Thanks !!
      Beste regards!
      core
        sdetweil @core
        @core use the installation script from here
        just cut/paste the one line to your Mac terminal window
        • C Offline
          core
          Hi sdetweil,
          thank you very much - I will give it a try!
          Best regards
          core
