    MMM-GoogleAssistant
    Scheduled Pinned Locked Moved Unsolved Development
    18 Posts 3 Posters 3.6k Views 3 Watching
      MrDondoT @sdetweil
      :folded_hands: appreciate
      but the mm will continue restarting with errors.
      I’ve put the rachele.pmdl file in the same dir of the others:
      /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/resources/models
      and that’s the log:
        sdetweil @MrDondoT
        @MrDondoT and what did u specify in config?
        must the full name rachele.pmdl
        else it will look for the other file type
        • ? Offline
          A Former User
          this feature is not yet supported by GA
            sdetweil @Guest
            @Bugsounet booo… how did u break it?
            • ? Offline
              A Former User
              It’s not breaked, just not coded in core of @bugsounet/snowboy
                MrDondoT @Guest
                @Bugsounet
                ahh, that’s why I couldn’t find any support on that.
                Will you support personal ww?
                thanks
                • ? Offline
                  A Former User
                  in the begining, i’m try to make a simple configuration because original snowboy configuration is very … very boring
                  I have planned to add it but not set actually
                  Just official hotkey is supported
                    MrDondoT @Guest
                    @Bugsounet
                    yeah, I’ve seen guys around trying using MMM-Hotword, MMM-Snowboy with your module to get around it, also the old repo https://github.com/gauravsacc/MMM-GoogleAssistant had that option available.
                    • ? Offline
                      A Former User
                      sure,
                      my npm library is NOT the same like original snowboy
                      I use only my own npm library, but i have a lot of module so i have a choice to do for update ;)
                      actually i’m working around MMM-Tools maybe after i will code your feature :)
                      Note:
                      it’s not too complex to add it, just give me time to do it !
                      unfortunately I only have 2 hands … otherwise I will be an octopus mouahahah
                        MrDondoT @Guest
                        @Bugsounet
                        :flexed_biceps:
                        thanks, you did great!
