    New Install - custom.css missing
    6 Posts 3 Posters 1.4k Views 3 Watching
    • K Offline
      kyledettman
      Hi guys! Been messing around with MM on my PI4 and loving it.
      Been reading a lot on customizing the interface (specifically fonts), and everyone is telling me to edit the custom.css file in the CSS folder. Only problem is I don’t have a custom.css file there (or anywhere in the folder structure).
      Is this something I have to create? How do I call the custom.css file to override the main.css file?
      Many thanks.
      Kyle
        sdetweil @kyledettman
        @kyledettman yes, manual install requires u to create the file
        anyhow do
        touch ~/MagicMirror/css/custom.css
        • V Offline
          Viperzee @sdetweil
          @sdetweil How can I replace the custom.css file. It happened to me as well while installing a module. I am novice so bare with me. I saw in another post someone side make a file and rename it custom.css but I didn’t understand what to do next. Please help.
            sdetweil @Viperzee
            @Viperzee do
            • V Offline
              Viperzee
              Well damn… It worked and I am glad but what did I just do exactly? Make a new custom or what? Thanks for the quick reply.
                sdetweil @Viperzee
                @Viperzee the initial custom.css is empty.
                the touch command will update the date/time on a file, and create the file if it is not there.
                if you had used the installation script, which I support, then it would have done the same thing
