Executing python in js - troublshooting/development
18 Posts 2 Posters 1.6k Views 2 Watching
    beejay22
    Tried this (all I changed was “python” to “python3”):
    const spawn = require("child_process").spawn
    var NodeHelper = require("node_helper")
        switch(notification) {
          case "GIVE_ME_DATA":
            this.job()
            break
      job: function() {
        var process = spawn("python3", ["/home/pi/Desktop/realTester.py"])
        process.stdout.on("data", (data)=>{
          console.log(data)
          var result = String.fromCharCode.apply(null, new Uint16Array((data)))
          this.sendSocketNotification("HERE_IS_DATA", data)
    And also changed pyscript to this (just added python3 to the shebang):
    #!/usr/bin/python3
    from bs4 import BeautifulSoup
    import requests
    url=requests.get("https://www.whitehouse.gov/presidential-actions/")
    src=url.content
    soup = BeautifulSoup(src, 'lxml')
    for h2_tag in soup.findAll('h2'):
        a_tag = h2_tag.find('a')
        print(a_tag.string)
    Also tested “python” again (not python3) in my node_helper along with the updated shebang as shown above
    If custom.css file doesn’t matter I wonder why it’s giving this error… Have no clue what’s going on now lol
    S 1 Reply Last reply Aug 25, 2020, 3:51 AM Reply Quote 0
      sdetweil @beejay22
      @beejay22 u need the fix for the data conversion… as well…
      custom.css cause its a file t=hat MM force loads, and while the browser is unhappy (thus the error), the MM runtime doesn’t care WHY there was no data, missing file, empty file, don’t care there were no css updates…
      i don’t do python so I can’t help much…
      but you gotta put in the fixes I gave you for data…
            console.log(data.toString()) // debugging, log string
            //var result = String.fromCharCode.apply(null, new Uint16Array((data)))
            this.sendSocketNotification("HERE_IS_DATA", data.toString())   // pass the string, module expects string
        beejay22
        Sorry I copied the wrong node_helper.js file in my last post. This is how it looks like now:
        //node_helper.js
                console.log("received notification")
                this.job()
                break
          job: function() {
        I was trying to test if I can at least print something to magic mirror without a pyscript… node_helper looks like this:
        //node_helper.js
                this.job()
                break
          job: function() {
            var process = spawn("python3", ["/home/pi/Desktop/test.py"])
              data= "Hello World";
        Hello World appears on MagicMirror but the test file that’s provided in the path (the test file just has: print(“this works”) does not so I’m not sure why I need to provide var process spawn if Hello World prints by itself… Anyways, I’m aware that there’s other ways to execute the child process however I’m not familiar with it. Please correct me if I’m wrong but can exec work in this situation as well? (pyscipt just prints out the latest titles when magic mirror restarts). I’m trying anything and everything at this point
        And I added the default and start function to my core module although I don’t think I have to use it. This is how it looks like now:
        /// MMM-Whitehouse.js - Core Module
        Module.register("MMM-Whitehouse", {
          defaults: {},
          start: function () {},
          getDom: function() {
            var e = document.createElement("div")
            e.id = "DISPLAY"
            return e
          notificationReceived: function(notification, payload, sender) {
              case "DOM_OBJECTS_CREATED":
                var timer = setInterval(()=>{
                  this.sendSocketNotification("GIVE_ME_DATA")
                }, 1000)
                break
              case "HERE_IS_DATA":
                var e = document.getElementById("DISPLAY")
                e.innerHTML = payload
                break
        S 1 Reply Last reply Aug 25, 2020, 11:05 PM Reply Quote 0
          sdetweil @beejay22
          @beejay22 I don’t understand why u have trouble.
          the 3 files I posted work together as u designed.
          does your spawn(‘/use/bin/python’, [execname]) work to return the data.
          console log to see
          spawn and exec have different methods of returning the data. see the doc
          Google search nodejs process spawn
            beejay22
            Did you try it with the pyscript? Or are you talking about it the core module, node_helper and config?
            And okay
            S 1 Reply Last reply Aug 25, 2020, 11:24 PM Reply Quote 0
              sdetweil @beejay22
              @beejay22 I am only working on inside MagicMirror
              the spawn on.data() gets called when the pgm launched outputs to stdout. my print hello
              of course I made sure the python script worked both ways, before showing that
                beejay22
                Okay. And yes it does return the data as output I believe
                S 1 Reply Last reply Aug 26, 2020, 12:07 AM Reply Quote 0
                  sdetweil @beejay22
                  @beejay22 do you see this output from the node_helper in the terminal window where you do npm start?
                  from your python script
                  2 / 2
