    Executing python in js - troublshooting/development
    18 Posts 2 Posters 2.5k Views 2 Watching
      sdetweil @beejay22
      @beejay22 yes, you need to execute the chmod command once, to mark the python script as executable. do this on a terminal window, or ssh session window
      ANY file in Linux can be executable.
      if you try to spawn/exec a file which does not have the execute permission set, u get the access error. it is not even opened.
      once the bit is set, then it is searched for the shebang, if present the identified file is exec’d and the rest of the parms are passed on.
      • beejay22B
        beejay22
        Hmmm I did this in the terminal:
        $ chmod +x /home/pi/Desktop/realTester.py
        Nothing changed… still the same error log message… I think there’s something wrong with my custom’s css file since it says it’s not loading… in my css folder there’s only a main.css file there
          sdetweil @beejay22
          @beejay22 so, can u run the script from the terminal like before
          python /home/pi/Desktop/realTester.py
          and then /home/pi/Desktop/realTester.py
          both should work, produce the same results
          that $ wasn’t part of the chmod
          • beejay22B
            beejay22
            I didn’t add the $ to the command, I just said that in my post for clarity lol. I typed just this in the command line:
            And yes I can run my script in the terminal with “python3 /home/pi/Desktop/realTester.py” but not with “/home/pi/Desktop/realTester.py” because the module I’m using in my script includes bs4 which is available with python3 I believe so I have to say python3
            I also tried ‘touch ~/MagicMirror/css/custom.css’, still showing same error log
              sdetweil @beejay22
              @beejay22 u can run python3 as the shebang. I was just giving example
              your node_helper code was spawning python, not python3. I just copied what u did. u can put python3 in the spawn as well
              custom.css, doesn’t matter, it’s empty so no harm
              • beejay22B
                beejay22
                Tried this (all I changed was “python” to “python3”):
                const spawn = require("child_process").spawn
                var NodeHelper = require("node_helper")
                    switch(notification) {
                      case "GIVE_ME_DATA":
                        this.job()
                        break
                  job: function() {
                    var process = spawn("python3", ["/home/pi/Desktop/realTester.py"])
                    process.stdout.on("data", (data)=>{
                      console.log(data)
                      var result = String.fromCharCode.apply(null, new Uint16Array((data)))
                      this.sendSocketNotification("HERE_IS_DATA", data)
                And also changed pyscript to this (just added python3 to the shebang):
                #!/usr/bin/python3
                from bs4 import BeautifulSoup
                import requests
                url=requests.get("https://www.whitehouse.gov/presidential-actions/")
                src=url.content
                soup = BeautifulSoup(src, 'lxml')
                for h2_tag in soup.findAll('h2'):
                    a_tag = h2_tag.find('a')
                    print(a_tag.string)
                Also tested “python” again (not python3) in my node_helper along with the updated shebang as shown above
                If custom.css file doesn’t matter I wonder why it’s giving this error… Have no clue what’s going on now lol
                  sdetweil @beejay22
                  @beejay22 u need the fix for the data conversion… as well…
                  custom.css cause its a file t=hat MM force loads, and while the browser is unhappy (thus the error), the MM runtime doesn’t care WHY there was no data, missing file, empty file, don’t care there were no css updates…
                  i don’t do python so I can’t help much…
                  but you gotta put in the fixes I gave you for data…
                        console.log(data.toString()) // debugging, log string
                        //var result = String.fromCharCode.apply(null, new Uint16Array((data)))
                        this.sendSocketNotification("HERE_IS_DATA", data.toString())   // pass the string, module expects string
                  • beejay22B
                    beejay22
                    Sorry I copied the wrong node_helper.js file in my last post. This is how it looks like now:
                    //node_helper.js
                            console.log("received notification")
                            this.job()
                            break
                      job: function() {
                    I was trying to test if I can at least print something to magic mirror without a pyscript… node_helper looks like this:
                    //node_helper.js
                            this.job()
                            break
                      job: function() {
                        var process = spawn("python3", ["/home/pi/Desktop/test.py"])
                          data= "Hello World";
                    Hello World appears on MagicMirror but the test file that’s provided in the path (the test file just has: print(“this works”) does not so I’m not sure why I need to provide var process spawn if Hello World prints by itself… Anyways, I’m aware that there’s other ways to execute the child process however I’m not familiar with it. Please correct me if I’m wrong but can exec work in this situation as well? (pyscipt just prints out the latest titles when magic mirror restarts). I’m trying anything and everything at this point
                    And I added the default and start function to my core module although I don’t think I have to use it. This is how it looks like now:
                    /// MMM-Whitehouse.js - Core Module
                    Module.register("MMM-Whitehouse", {
                      defaults: {},
                      start: function () {},
                      getDom: function() {
                        var e = document.createElement("div")
                        e.id = "DISPLAY"
                        return e
                          case "DOM_OBJECTS_CREATED":
                            var timer = setInterval(()=>{
                              this.sendSocketNotification("GIVE_ME_DATA")
                            }, 1000)
                            break
                          case "HERE_IS_DATA":
                            var e = document.getElementById("DISPLAY")
                            e.innerHTML = payload
                            break
                      sdetweil @beejay22
                      @beejay22 I don’t understand why u have trouble.
                      the 3 files I posted work together as u designed.
                      does your spawn(‘/use/bin/python’, [execname]) work to return the data.
                      console log to see
                      spawn and exec have different methods of returning the data. see the doc
                      Google search nodejs process spawn
                      • beejay22B
                        beejay22
                        Did you try it with the pyscript? Or are you talking about it the core module, node_helper and config?
                        And okay
                          sdetweil @beejay22
                          @beejay22 I am only working on inside MagicMirror
                          the spawn on.data() gets called when the pgm launched outputs to stdout. my print hello
                          of course I made sure the python script worked both ways, before showing that
                          • beejay22B
                            beejay22
                            Okay. And yes it does return the data as output I believe
                              sdetweil @beejay22
                              @beejay22 do you see this output from the node_helper in the terminal window where you do npm start?
                              from your python script
