    Executing python in js - troublshooting/development
    18 Posts 2 Posters 2.3k Views 2 Watching
      sdetweil @beejay22
      @beejay22 sorry
      2more things.
      1. u need to add the 1st line to the script to tell the system what processor to use
      #!/usr/bin/python
      1. u need to make the script executable
      chmod +x /home/pi/Desktop/realTester.py
      • beejay22B Offline
        beejay22
        Okay so now my pycript looks like this:
        #!/usr/bin/python
        from bs4 import BeautifulSoup
        import requests
        url=requests.get("https://www.whitehouse.gov/presidential-actions/")
        src=url.content
        soup = BeautifulSoup(src, 'lxml')
        for h2_tag in soup.findAll('h2'):
            a_tag = h2_tag.find('a')
            print(a_tag.string)
        If I’m my understanding correctly, adding this shebang line lets shell know that my src code is a script, the type of interpreter we want to use and the path of said interpreter…
        Also am I suppose to execute chmod +x /home/pi/Desktop/realTester.py in shell? If so how and when… sorry I’m still trying to understand how exactly to do all of this
          sdetweil @beejay22
          @beejay22 yes, you need to execute the chmod command once, to mark the python script as executable. do this on a terminal window, or ssh session window
          ANY file in Linux can be executable.
          if you try to spawn/exec a file which does not have the execute permission set, u get the access error. it is not even opened.
          once the bit is set, then it is searched for the shebang, if present the identified file is exec’d and the rest of the parms are passed on.
          • beejay22B Offline
            beejay22
            Hmmm I did this in the terminal:
            $ chmod +x /home/pi/Desktop/realTester.py
            Nothing changed… still the same error log message… I think there’s something wrong with my custom’s css file since it says it’s not loading… in my css folder there’s only a main.css file there
              sdetweil @beejay22
              @beejay22 so, can u run the script from the terminal like before
              python /home/pi/Desktop/realTester.py
              and then /home/pi/Desktop/realTester.py
              both should work, produce the same results
              that $ wasn’t part of the chmod
              • beejay22B Offline
                beejay22
                I didn’t add the $ to the command, I just said that in my post for clarity lol. I typed just this in the command line:
                And yes I can run my script in the terminal with “python3 /home/pi/Desktop/realTester.py” but not with “/home/pi/Desktop/realTester.py” because the module I’m using in my script includes bs4 which is available with python3 I believe so I have to say python3
                I also tried ‘touch ~/MagicMirror/css/custom.css’, still showing same error log
                  sdetweil @beejay22
                  @beejay22 u can run python3 as the shebang. I was just giving example
                  your node_helper code was spawning python, not python3. I just copied what u did. u can put python3 in the spawn as well
                  custom.css, doesn’t matter, it’s empty so no harm
                  • beejay22B Offline
                    beejay22
                    Tried this (all I changed was “python” to “python3”):
                    const spawn = require("child_process").spawn
                    var NodeHelper = require("node_helper")
                        switch(notification) {
                          case "GIVE_ME_DATA":
                            this.job()
                            break
                      job: function() {
                        var process = spawn("python3", ["/home/pi/Desktop/realTester.py"])
                        process.stdout.on("data", (data)=>{
                          console.log(data)
                          var result = String.fromCharCode.apply(null, new Uint16Array((data)))
                          this.sendSocketNotification("HERE_IS_DATA", data)
                    And also changed pyscript to this (just added python3 to the shebang):
                    #!/usr/bin/python3
                    import requests
                    src=url.content
                        print(a_tag.string)
                    Also tested “python” again (not python3) in my node_helper along with the updated shebang as shown above
                    If custom.css file doesn’t matter I wonder why it’s giving this error… Have no clue what’s going on now lol
                      sdetweil @beejay22
                      @beejay22 u need the fix for the data conversion… as well…
                      custom.css cause its a file t=hat MM force loads, and while the browser is unhappy (thus the error), the MM runtime doesn’t care WHY there was no data, missing file, empty file, don’t care there were no css updates…
                      i don’t do python so I can’t help much…
                      but you gotta put in the fixes I gave you for data…
                            console.log(data.toString()) // debugging, log string
                            //var result = String.fromCharCode.apply(null, new Uint16Array((data)))
                            this.sendSocketNotification("HERE_IS_DATA", data.toString())   // pass the string, module expects string
                      • beejay22B Offline
                        beejay22
                        Sorry I copied the wrong node_helper.js file in my last post. This is how it looks like now:
                        //node_helper.js
                                console.log("received notification")
                                this.job()
                                break
                          job: function() {
                        I was trying to test if I can at least print something to magic mirror without a pyscript… node_helper looks like this:
                        //node_helper.js
                                this.job()
                                break
                          job: function() {
                            var process = spawn("python3", ["/home/pi/Desktop/test.py"])
                              data= "Hello World";
                        Hello World appears on MagicMirror but the test file that’s provided in the path (the test file just has: print(“this works”) does not so I’m not sure why I need to provide var process spawn if Hello World prints by itself… Anyways, I’m aware that there’s other ways to execute the child process however I’m not familiar with it. Please correct me if I’m wrong but can exec work in this situation as well? (pyscipt just prints out the latest titles when magic mirror restarts). I’m trying anything and everything at this point
                        And I added the default and start function to my core module although I don’t think I have to use it. This is how it looks like now:
                        /// MMM-Whitehouse.js - Core Module
                        Module.register("MMM-Whitehouse", {
                          defaults: {},
                          start: function () {},
                          getDom: function() {
                            var e = document.createElement("div")
                            e.id = "DISPLAY"
                            return e
                              case "DOM_OBJECTS_CREATED":
                                var timer = setInterval(()=>{
                                  this.sendSocketNotification("GIVE_ME_DATA")
                                }, 1000)
                                break
                              case "HERE_IS_DATA":
                                var e = document.getElementById("DISPLAY")
                                e.innerHTML = payload
                                break
                          sdetweil @beejay22
                          @beejay22 I don’t understand why u have trouble.
                          the 3 files I posted work together as u designed.
                          does your spawn(‘/use/bin/python’, [execname]) work to return the data.
                          console log to see
                          spawn and exec have different methods of returning the data. see the doc
                          Google search nodejs process spawn
                          • beejay22B Offline
                            beejay22
                            Did you try it with the pyscript? Or are you talking about it the core module, node_helper and config?
                            And okay
                              sdetweil @beejay22
                              @beejay22 I am only working on inside MagicMirror
                              the spawn on.data() gets called when the pgm launched outputs to stdout. my print hello
                              of course I made sure the python script worked both ways, before showing that
                              • beejay22B Offline
                                beejay22
                                Okay. And yes it does return the data as output I believe
                                  sdetweil @beejay22
                                  @beejay22 do you see this output from the node_helper in the terminal window where you do npm start?
                                  from your python script
