Executing python in js - troublshooting/development
18 Posts 2 Posters 1.6k Views 2 Watching
    beejay22
    Hi. I’m very new to coding and I have a pyscript that simply prints out the latest titles from a website using BeautifulSoup. However, when I launch magic mirror it’s just a black screen. I deleted all other modules besides my own in the config file so that it’s just my module that runs. I’ve done ample research and can’t seem to figure out what’s going on (updated mm software, reinstalled dependencies in the css directory just in case it wasn’t installed correctly, checked to see node was up to date - v10.21.0, etc.). I’m starting to think it may be my pyscript but it runs correctly in the console (I can attach my pyscript if needed). I’m not sure what the problem is so I appreciate any and all help!
    Core module: MMM-Whitehouse
    Module.register("MMM-Whitehouse", {
      getDom: function() {
        var e = document.createElement("div")
        e.id = "DISPLAY"
        return e
        switch(notification) {
          case "DOM_OBJECTS_CREATED":
            var timer = setInterval(()=>{
              this.sendSocketNotification("GIVE_ME_DATA")
            }, 1000)
            break
          case "HERE_IS_DATA":
            var e = document.getElementById("DISPLAY")
            e.innerHTML = payload
            break
    node_helper.js
    const spawn = require("child_process").spawn
    var NodeHelper = require("node_helper")
          case "GIVE_ME_DATA":
            this.job()
            break
      job: function() {
        var process = spawn("python", ["/home/pi/Desktop/realTester.py"])
        process.stdout.on("data", (data)=>{
          console.log(data)
          var result = String.fromCharCode.apply(null, new Uint16Array((data)))
          this.sendSocketNotification("HERE_IS_DATA", data)
    config.js
    var config = {
    	port: 8080,
    	language: "en",
    	timeFormat: 24,
    	units: "metric",
    			     // false, default for all  NON-armv6l devices
     			module: "MMM-Whitehouse",
      			config: {}
    Error message (from dev mode):
    Initializing MagicMirror.
    translator.js:202 Loading core translation file: translations/en.json
    translator.js:225 Loading core translation fallback file: translations/en.json
    loader.js:179 Load script: modules/MMM-Whitehouse//MMM-Whitehouse.js
    module.js:479 Module registered: MMM-Whitehouse
    loader.js:150 Bootstrapping module: MMM-Whitehouse
    loader.js:155 Scripts loaded for: MMM-Whitehouse
    loader.js:157 Styles loaded for: MMM-Whitehouse
    loader.js:159 Translations loaded for: MMM-Whitehouse
    loader.js:194 Load stylesheet: css/custom.css
    (index):1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
    loader.js:203 Error on loading stylesheet: css/custom.css
    module.js:46 Starting module: MMM-Whitehouse
    main.js:474 All modules started!
    /home/pi/MagicMirror…rity-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
      protocols.This exposes users of this app to unnecessary security risks.
      Consider loading the following resources over HTTPS or FTPS.
     - http://localhost:8080/css/main.css
    - http://localhost:8080/fonts/roboto.css
    - http://localhost:8080/socket.io/socket.io.js
    - http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
    - http://localhost:8080/js/defaults.js
    - http://localhost:8080/config/config.js
    - http://localhost:8080/vendor/vendor.js
    - http://localhost:8080/modules/default/defaultmodules.js
    - http://localhost:8080/js/logger.js
    - http://localhost:8080/translations/translations.js
    - http://localhost:8080/js/translator.js
    - http://localhost:8080/js/class.js
    - http://localhost:8080/js/module.js
    - http://localhost:8080/js/loader.js
    - http://localhost:8080/js/socketclient.js
    - http://localhost:8080/js/main.js
    - http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
    - http://localhost:8080/translations/en.json
    - http://localhost:8080/modules/MMM-Whitehouse//MMM-Whitehouse.js
    For more information and help, consult
    https://electronjs.org/docs/tutorial/security.
     This warning will not show up
    once the app is packaged.
    /home/pi/MagicMirror…ity-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
        Policy set or a policy with "unsafe-eval" enabled. This exposes users of
    S 1 Reply Last reply Aug 23, 2020, 12:28 PM Reply Quote 0
      sdetweil @beejay22
      @beejay22 I copy/pasted your code, and only see a black screen cause there is nothing to display…
      there is a bug in the node_helper
              console.log("received notification")
              this.job()
              break
        job: function() {
          // type A, you specify the pgm to execute your script HERE
          var process = spawn("python",["/home/sam/Desktop/realTester.py"])
          // type B, you specify the pgm to execute your script IN the script.
          var process = spawn("/home/sam/Desktop/realTester.py")
            console.log(data)
            var result = String.fromCharCode.apply(null, new Uint16Array((data)))   // < --- you processed data to result
            this.sendSocketNotification("HERE_IS_DATA", data)    // < ---- then sent data, which is still a 'buffer'
      i fixed to this
              this.job()
              break
        job: function() {
         //  I prefer this , before u needed two things, python and the script..
         // but if u changed the script to bash, or java, or whatever, then the app would break..
            console.log(data.toString()) // debugging, log string
            //var result = String.fromCharCode.apply(null, new Uint16Array((data)))
            this.sendSocketNotification("HERE_IS_DATA", data.toString())   // pass the string, module expects string
      the script for example is
      #!/usr/bin/python3
      print("hello");
        beejay22
        Thanks for the insightful reply! I changed my node_helper to what you posted:
                this.job()
                break
          job: function(){
            var process = spawn("/home/pi/Desktop/realTester.py")
        However, when I changed it I got an error message in the terminal which hasn’t happened before. Error message in terminal:
        [2020-08-23 22:36:26.161] [ERROR]  Error: spawn /home/pi/Desktop/testing.py EACCES
            at Process.ChildProcess._handle.onexit (internal/child_process.js:264:19)
            at onErrorNT (internal/child_process.js:456:16)
            at processTicksAndRejections (internal/process/task_queues.js:84:9) {
          errno: 'EACCES',
          code: 'EACCES',
          syscall: 'spawn /home/pi/Desktop/realTester.py',
          path: '/home/pi/Desktop/realTester.py',
          spawnargs: []
        [2020-08-23 22:36:26.171] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-08-23 22:36:26.172] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-08-23 22:36:27.069] [LOG]    received notification
        [2020-08-23 22:36:27.094] [LOG]    Whoops! There was an uncaught exception...
        Still getting the same error log in the magic mirror using dev mode though… lastly this is my pyscript, realTester.py:
        from bs4 import BeautifulSoup
        import requests
        url=requests.get("https://www.whitehouse.gov/presidential-actions/")
        src=url.content
        soup = BeautifulSoup(src, 'lxml')
        for h2_tag in soup.findAll('h2'):
            a_tag = h2_tag.find('a')
            print(a_tag.string)
        S 1 Reply Last reply Aug 24, 2020, 12:37 PM Reply Quote 0
          sdetweil @beejay22
          @beejay22 sorry
          2more things.
          1. u need to add the 1st line to the script to tell the system what processor to use
          #!/usr/bin/python
          1. u need to make the script executable
          chmod +x /home/pi/Desktop/realTester.py
            beejay22
            Okay so now my pycript looks like this:
            #!/usr/bin/python
            import requests
            src=url.content
                print(a_tag.string)
            If I’m my understanding correctly, adding this shebang line lets shell know that my src code is a script, the type of interpreter we want to use and the path of said interpreter…
            Also am I suppose to execute chmod +x /home/pi/Desktop/realTester.py in shell? If so how and when… sorry I’m still trying to understand how exactly to do all of this
            S 1 Reply Last reply Aug 24, 2020, 5:46 PM Reply Quote 0
              sdetweil @beejay22
              @beejay22 yes, you need to execute the chmod command once, to mark the python script as executable. do this on a terminal window, or ssh session window
              ANY file in Linux can be executable.
              if you try to spawn/exec a file which does not have the execute permission set, u get the access error. it is not even opened.
              once the bit is set, then it is searched for the shebang, if present the identified file is exec’d and the rest of the parms are passed on.
                beejay22
                Hmmm I did this in the terminal:
                $ chmod +x /home/pi/Desktop/realTester.py
                Nothing changed… still the same error log message… I think there’s something wrong with my custom’s css file since it says it’s not loading… in my css folder there’s only a main.css file there
                S 1 Reply Last reply Aug 24, 2020, 7:24 PM Reply Quote 0
                  sdetweil @beejay22
                  @beejay22 so, can u run the script from the terminal like before
                  python /home/pi/Desktop/realTester.py
                  and then /home/pi/Desktop/realTester.py
                  both should work, produce the same results
                  that $ wasn’t part of the chmod
                    beejay22
                    I didn’t add the $ to the command, I just said that in my post for clarity lol. I typed just this in the command line:
                    And yes I can run my script in the terminal with “python3 /home/pi/Desktop/realTester.py” but not with “/home/pi/Desktop/realTester.py” because the module I’m using in my script includes bs4 which is available with python3 I believe so I have to say python3
                    I also tried ‘touch ~/MagicMirror/css/custom.css’, still showing same error log
                    S 1 Reply Last reply Aug 24, 2020, 11:19 PM Reply Quote 0
                      sdetweil @beejay22
                      @beejay22 u can run python3 as the shebang. I was just giving example
                      your node_helper code was spawning python, not python3. I just copied what u did. u can put python3 in the spawn as well
                      custom.css, doesn’t matter, it’s empty so no harm
