    How to support multiple translations in different UI and API?
    1 Posts 1 Posters 386 Views 1 Watching
    • W
      winstonma
      My modules would like to support multiple languages (e.g. zh-hk and zh-tw). But actually both language uses the same set of language (Traditional Chinese).
      UI
      I could support both language in the following function:
        getTranslations: function () {
          return {
            "zh-hk": "translations/zh-tw.json"
            "zh-tw": "translations/zh-tw.json"
      Is it possible that I could pre-map zh-hk to zh-tw so that I only need to keepzh-tw in getTranslations?
      API
      The API also returned the localized value based on the language parameters. Therefore I would like to convert zh-hk and zh-tw into zh-hant required by the API (in two different lines). Currently I am doing the conversion in a hard-code way. Is it possible that I could pre-map zh-hk to zh-tw so that I could translatezh-tw into zh-hant in the API code?
