    LED Pi4 PIR
    3 Posts 3 Posters 817 Views 3 Watching
    • H Offline
      hec59
      Hi all. I am currently working on a MagicMirror. I have the pi4 4gb and I have the program running on a monitor until I have the actual mirror made. I have the PIR sensor I want to add so when approached, it will trigger off and light up LED strip lights as a sort of mood light. Is it possible to have these light up using the usb port? PS I am totally noob to this. Any help or pointers greatly appreciated. TIA
        mmcghee
        Hi Hec,
        This is what i am looking to do also, i figure that if you use the PIR and a button module to trigger a button press when the the PIR is activated. I think i saw on the raspberry pi forum that the power to the USB ports can be turned on and off this way however this only works with all usb ports and cant be done individually.
        If you come across a better method please let me know.
        • cowboysdudeC Offline
          cowboysdude Module Developer
          The triggers that turn on and off the monitor are different in the Pi4 then they were in the Pi3.
          I would spend some research time on the internet seeing what the new commands are :)
