    Running the same module twice with different URL, but same content is being displayed (MMM-HTMLSnippet)
    6 Posts 2 Posters 1.4k Views 2 Watching
    • K Offline
      kasperb
      Hi all,
      I’m running two instances of MMM-HTMLSnippet on my mirror with the objective of showing two different twitter feeds (CNN & Axios). I’ve copied the initial module in the modules folder, renamed it to ‘MMM-HTMLSnippet2’ and changed the *.js file to ‘MMM-HTMLSnippet2.js’. I’ve also updated the first line in *.js file to MMM-HTMLSnippet2. Finally, I’ve updated my config as outlined below.
      However, both modules are showing the CNN twitter feed on my mirror.
      What did I miss?!
      Thanks!
        module: "MMM-HTMLSnippet",
        position: "bottom_right",
              html:`<a class="twitter-timeline" data-height="500" data-dnt="true" href="https://twitter.com/cnnbrk?ref_src=twsrc%5Etfw">Tweets by cnnbrk</a> <script async src="https://platform.twitter.com/widgets.js" charset="utf-8"></script>`, //insert your script or html codes here.
              width: "400px",
              height: "500px",
              backgroundColor: "#FFF",
              updateInterval: 3600000,
        module: "MMM-HTMLSnippet2",
        position: "bottom_left",
              html:`<a class="twitter-timeline" data-height="500" data-dnt="true" href="https://twitter.com/axios?ref_src=twsrc%5Etfw">Tweets by axios</a> <script async src="https://platform.twitter.com/widgets.js" charset="utf-8"></script>`, //insert your script or html codes here.
              width: "400px",
              height: "500px",
        sdetweil @kasperb
        @kasperb sadly the module is not designed to be used in multiples
        the problem is the url to get the html (which isn’t needed anyhow)
        the node helper sets up a ‘server’ to return the html,. and the web side calls to get it
        ‘/MMM-HTMLSnippet’
        but MM cannot have two servers with the same name, so first one wins…
        if you turn the two entries around, the resutls will be from the top one…
          sdetweil @kasperb
          @kasperb you could hack one module to get what I want.
          edit the second one, where u changed the name. change the
          /MMM-HTMLSnippet
          to
          /MMM-HTMLSnippet2
          in both .js files
          • K Offline
            kasperb @sdetweil
            @sdetweil Thanks for your response. When you say both *.js files, which ones exactly do you mean? There is only one *.js file in the folder with ‘MMM-HTMLSnippet’ in it.
              sdetweil @kasperb
              @kasperb node_helper.js
              this.expressApp.get("/MMM-HTMLSnippet", (req, res) => {
              and
              MMM-HTMLSnippet.js
              wrapper.src = '/MMM-HTMLSnippet'
              • K Offline
                kasperb @sdetweil
                @sdetweil You’re right; I missed that one.
                Thank you - that did the trick and both versions of the module now work as expected.
