    Is it possible to ad an Arduino?
    55 Posts 4 Posters 20.8k Views 4 Watching
      Shinji0912 @sdetweil
      @sdetweil Not as far as i can see.
        sdetweil @Shinji0912
        @Shinji0912 so, I would use the linked examples outside mm to make sure it works
          @sdetweil Ok so i have installed Serialport on the Pi and told the arduino to digitalwrite 10 but how to i let the Pi read 10?
            @Shinji0912 Google , there are many examples
              @sdetweil , @wishmaster270
              Ok , so now i got the Arduino to communicate with the PI via usb, (i got the right Portname using NodeRed). This is the current Arduino Script :
              #include <Wire.h>
              #include "DHT.h"
              #define DHTPIN 2
              #define DHTTYPE 11
              DHT dht (DHTPIN, DHTTYPE);
              void setup()
                Wire.begin();
                Serial.begin(9600);
                dht.begin();
              void loop()
                delay(2000);
                float temp = dht.readTemperature();
                float rel_hum = dht.readHumidity();
                if (isnan(rel_hum) || isnan(temp)) {
                  Serial.println(F("Daten vom Sensor konnten nicht gelesen werden!"));
                  return;
                float hif = dht.computeHeatIndex(rel_hum);
                float hic = dht.computeHeatIndex(temp, rel_hum, false);
                Serial.print(F("Luftfeuchtigkeit: "));
                Serial.print(rel_hum);
                Serial.print(F("%  Temperatur: "));
                Serial.print(temp);
                Serial.print(F("°C "));
                Serial.println(F(""));
              Some things are in german so dont be suprised ^^
              and via NodeRed i know that it is working and the Pi is currently reading the data.
              alt text
              My issue now is that my Config.js isn’t working anymore after installing ArduPorts ??
              alt text
              This is the current config :
              /* Magic Mirror Config Sample
               * By Michael Teeuw https://michaelteeuw.nl
               * MIT Licensed.
              var config = {
              	address: "localhost", 	// Address to listen on, can be:
              	port: 8080,
              	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
              	language: "de",
              	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
              	timeFormat: 24,
              	units: "metric",
              		module: 'MMM-ArduPort',
              		position: "bottom_right",
              		portname: "/dev/ttyACM0",
              		updateInterval: 2,
              		animationSpeed: 1000,
              		displayIcons: ture,
              		showDescription: true,
              		useColors: true,
              	sensors: [ {
              	description: "Temperatur",
              		module: 'MMM-TelegramBot',
              			telegramAPIKey: '',
              			allowedUser: [''],
              			adminChatId: ''
              			module: "MMM-Online-State",
              			module: "updatenotification",
              			position: "bottom_bar"
              			module: "clock",
              			position: "top_right"
                          module: 'MMM-RBB-Weather',
                          position: "top_left", // All available positions
                                       days: "0",
                                       updateInterval: "600",
              			header: "Events",
              						symbol: "calendar-check-o ",
              						url: "",
              						maximumEntries: "5",
              						maximumNumberOfDays: "7"
                module: "MMM-NowPlayingOnSpotify",
                position: "bottom_left",
                  showCoverArt: false,
                  clientID: "",
                  clientSecret: "",
                  accessToken: "",
                  refreshToken: ""
              alt text
              i don’t know what to do now :C i thought i had it working this time finally …
              EDIT :
              Found the mistake i’ve written “ture” not “true” fml…
              EDIT 2 :
              But it’s still not working as i want it to it still says :“Waiting for Connection” on the Arduport module when launching the MagicMirror.
                @Shinji0912 and u did the npm install in the arduport module folder?
                  @sdetweil yes i did .-.
                    @Shinji0912 ok, need to see the console logs
                    from nom start or pm2 logs
                    and the developers window ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors.
                    u can also filter messages by.module, by adding part.of the module name to the filter field, ardu for example
                      @sdetweil Ok currently im not at home but will upload when home ^^
                        @Shinji0912 add
                        debug:true
                        to the config section of the arduport module def in config.js
                        • 6
                        • 3 / 6
