    Rotate screen by custom.css work only for -90deg
    9 Posts 2 Posters 2.9k Views 1 Watching
    • J
      Joern
      Hello,
      based on that showcase here
      [Showcase] (https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi/12)
      I tried to rotate screen. So post it here again in Troubleshooting, as showcase is not right place for support I assume.
      Iam struggeling on my PI3 to rotate by 90deg to right. Monitor has 1920x1080.
      Doing it I see only black screen at any other position than -90deg!!
      At -90deg screen is there only upside done…
      As I need to change to 90deg or -270deg I got only black screen (also 180deg even) …
      So I changed config.txt to:
      display_hdmi_rotate=0
      framebuffer_width=1920
      framebuffer_height=1080
      & custom.css to:
      body {
              margin: 0;
              position: absolute;
              transform: rotate(90deg);
              transform-origin: top left;
              width: 100vh;
              height: 100vw;
              object-fit: cover;
              top: 100vh;
              visibility: visible;
      What is missing/wrong?
        A Former User
        This post is deleted!
        • J
          Joern
          Hello,
          I tried your proposal in custom.css.
          For -90deg as written works fine.
          For 90deg again black screen.
          (edit: 0deg , 180deg, -270deg result in black screen)
            A Former User
            • J
              Joern
              Screen appears THANKS, but whole display is having a offset of approx 10% moved to right… (left black bar, right gutted away…)
              bottom: 110%; works for right side, but left side is cutted.
              ist that something that is driven maybe by config or main.css?
              • J
                Joern
                After removing frame margin from main.css body, works fine!!
                @hango - Big thanks for super fast reply!!
                body {
                  margin: 0px;
                  position: absolute;
                  height: calc(100% - 0px);
                  width: calc(100% - 0px);
                  A Former User
                  • J
                    Joern
                    bottom 110% was first try, but cutted away parts on left side :-( even if there was space… Margin 0, if not other issues will come - works fine as mirror is anyhow bigger…
                      A Former User
