    ERR when running DISPLAY=:0 npm start
    1 Posts 1 Posters 2.0k Views 1 Watching
    • P
      Pziran
      Here is the debug log:
      1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
      2 info using npm@3.8.9
      3 info using node@v6.2.0
      5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
      6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
      8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/root/MagicMirror/node_modules/.bin:/usr/bin:/usr/local/sbin:/usr/local/b$
      10 verbose lifecycle magicmirror@2.0.0~start: CWD: /root/MagicMirror
      11 silly lifecycle magicmirror@2.0.0~start: Args: [ '-c', 'electron js/electron.js' ]
      12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1  signal: null
      13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
      14 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
      14 verbose stack Exit status 1
      14 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:245:16)
      14 verbose stack     at emitTwo (events.js:106:13)
      14 verbose stack     at EventEmitter.emit (events.js:191:7)
      14 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/spawn.js:24:14)
      14 verbose stack     at ChildProcess.emit (events.js:191:7)
      14 verbose stack     at maybeClose (internal/child_process.js:850:16)
      14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
      15 verbose pkgid magicmirror@2.0.0
      16 verbose cwd /root/MagicMirror
      17 error Linux 4.4.9-v7+
      18 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      19 error node v6.2.0
      20 error npm  v3.8.9
      21 error code ELIFECYCLE
      22 error magicmirror@2.0.0 start: `electron js/electron.js`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
      23 error Make sure you have the latest version of node.js and npm installed.
      23 error If you do, this is most likely a problem with the magicmirror package,
      23 error not with npm itself.
      23 error Tell the author that this fails on your system:
      23 error     electron js/electron.js
      Note from admin: Please use Markdown on code snippets so it is easier to read!
