    Cant Start MMPM GUI
    15 Posts 5 Posters 6.6k Views 4 Watching
      requiemmg
      New question about the GUI here:
      I have 2 MM installations on 2 R3B+.
      Both the same config. Both the same Raspian Buster.
      On one, GUI is working as intended.
      On the other, for a while now (worked before), I have to reinstall the MMPM GUI after every reboot with mmpm install --gui, then it works.
      After a reboot -> 502 Bad gateway.
      MMPM 2.05.
      Anyone already came across this and has a solution available?
        mr190e
        I have exactly the same problem: I can’t get MMPM get to autostart after reboot. Any ideas?
        • mumblebajM Online
          mumblebaj Module Developer @Guest
          @Zar You could just issue a pm2 delete mm and then pm2 save which will get rid of pm2 restarting the mirror. The feature helps with crashes and restarts the mirror automatically.
          The scripts from @sdetweil is awesome and has helped 100’s on the forum.
            sdetweil @mumblebaj
            @mumblebaj none of my scripts address MMPM
            (MagicMirror Package Manager)
            • mumblebajM Online
              mumblebaj Module Developer @sdetweil
              @sdetweil Still don’t like the response he made to you about not advising people to use your scripts.
