    Help with setting up mmpm and finding the right ip address
    4 Posts 2 Posters 1.3k Views 2 Watching
    • C Offline
      coope310
      I’m pretty new to the magic mirror concept, and while I was able to get it to work just fine from my house, once I moved to an apartment I can’t seem to get mmpm to work. When I try to go to my magic mirror’s ip address from my laptop, which is how I’ve previously access the mmpm GUI, I’m taken to some sort of weird site that says “Welcome to nginx”. I don’t know what that is or where it came from and I’m very confused.
      Do I have the wrong IP address? Does anyone have any idea what the issue is? I’ve been getting the address from running hostname -I in the terminal on my pi.
        sdetweil @coope310
        @coope310 are you using wireless or wired network?
        if wireless, u had to change your network info unless you moved your WiFi router to the new home.
        • C Offline
          coope310
          I switched over the wireless network to the apartment’s network. I know that works because my reddit module updates properly as does my weather.
            sdetweil @coope310
            @coope310 did u reset the MMPM environment variables , which contains the url of MagicMirror
            https://github.com/Bee-Mar/mmpm/wiki/MMPM-Environment-Variables
