    Black screen after 2.13 update - tentatively resolved
    53 Posts 9 Posters 20.1k Views 9 Watching
    • FoziF Offline
      Fozi Project Sponsor @requiemmg
      @requiemmg although I haven’t updated yet I‘d try @sdetweil script. That worked with each update for me
        requiemmg
        Sorry, no messages, just a black screen. Also tried the update script, which just gives me an “everything up to date”. :-(
        • C Offline
          carlywarly
          Same here, no messages, just black screen.
            sdetweil @carlywarly
            @carlywarly @requiemmg in the window where u start MM… either npm start or pm2
            if pm2, use pm2 logs --lines=???
            where ??? is a number 15 is the default.
            or open the developers window,
            ctrl-shift-i, select the console tab and scroll up
              requiemmg
              pm2 logs --lines=20 throws an error (unknown option)
              SO I did a npm start and copied both npm start output and the console window output. Here it is:
              npm start log:
              pi@SmartMirror2:~/MagicMirror $ npm start
              > magicmirror@2.13.0 start /home/pi/MagicMirror
              [2020-10-01 19:30:24.700] [LOG]    Starting MagicMirror: v2.13.0
              [2020-10-01 19:30:24.712] [LOG]    Loading config ...
              [2020-10-01 19:30:24.730] [LOG]    Loading module helpers ...
              [2020-10-01 19:30:24.734] [LOG]    No helper found for module: MMM-pages.
              [2020-10-01 19:30:24.736] [LOG]    No helper found for module: alert.
              [2020-10-01 19:30:24.745] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:24.747] [LOG]    Module helper loaded: mmpm
              [2020-10-01 19:30:24.843] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:24.844] [LOG]    Module helper loaded: updatenotification
              [2020-10-01 19:30:25.437] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:25.438] [LOG]    Module helper loaded: newsfeed
              [2020-10-01 19:30:25.439] [LOG]    No helper found for module: MMM-page-indicator.
              [2020-10-01 19:30:25.440] [LOG]    No helper found for module: clock.
              [2020-10-01 19:30:25.441] [LOG]    No helper found for module: MMM-Callmonitor-Current-Call.
              [2020-10-01 19:30:26.288] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:26.289] [LOG]    Module helper loaded: MMM-Spotify
              [2020-10-01 19:30:26.451] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:26.452] [LOG]    Module helper loaded: calendar
              [2020-10-01 19:30:26.999] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:27.000] [LOG]    Module helper loaded: MMM-MyCommute
              [2020-10-01 19:30:27.002] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:27.003] [LOG]    Module helper loaded: MMM-Vrr
              [2020-10-01 19:30:27.566] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:27.567] [LOG]    Module helper loaded: MMM-AVStock
              [2020-10-01 19:30:27.574] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:27.575] [LOG]    Module helper loaded: MMM-News
              [2020-10-01 19:30:28.174] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:28.175] [LOG]    Module helper loaded: MMM-MovieListings
              [2020-10-01 19:30:28.176] [LOG]    No helper found for module: MMM-PlexNowPlaying.
              [2020-10-01 19:30:28.187] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:28.188] [LOG]    Module helper loaded: MMM-teamspeak3
              [2020-10-01 19:30:28.525] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:28.526] [LOG]    Module helper loaded: MMM-FRITZ-Box-Callmonitor
              [2020-10-01 19:30:29.077] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:29.078] [LOG]    Module helper loaded: MMM-DWD-WarnWeather
              [2020-10-01 19:30:29.203] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:29.204] [LOG]    Module helper loaded: MMM-Fuel
              [2020-10-01 19:30:29.205] [LOG]    No helper found for module: MMM-WeatherOrNot.
              [2020-10-01 19:30:29.290] [LOG]    Initializing new module helper ...
              [2020-10-01 19:30:29.291] [LOG]    Module helper loaded: MMM-Bring
              [2020-10-01 19:30:29.291] [LOG]    All module helpers loaded.
              [2020-10-01 19:30:29.471] [LOG]    Starting server on port 8080 ...
              [2020-10-01 19:30:29.475] [INFO]   You're using a full whitelist configuration to allow for all IPs
              [2020-10-01 19:30:29.485] [LOG]    Server started ...
              [2020-10-01 19:30:29.487] [LOG]    Connecting socket for: mmpm
              [2020-10-01 19:30:29.488] [LOG]    Starting module helper: mmpm
              [2020-10-01 19:30:29.490] [LOG]    Connecting socket for: updatenotification
              [2020-10-01 19:30:29.491] [LOG]    Connecting socket for: newsfeed
              [2020-10-01 19:30:29.492] [LOG]    Starting node helper for: newsfeed
              [2020-10-01 19:30:29.493] [LOG]    Connecting socket for: MMM-Spotify
              [2020-10-01 19:30:29.494] [LOG]    Connecting socket for: calendar
              [2020-10-01 19:30:29.495] [LOG]    Starting node helper for: calendar
              [2020-10-01 19:30:29.496] [LOG]    Connecting socket for: MMM-MyCommute
              [2020-10-01 19:30:29.497] [LOG]    ====================== Starting node_helper for module [MMM-MyCommute]
              [2020-10-01 19:30:29.498] [LOG]    Connecting socket for: MMM-Vrr
              [2020-10-01 19:30:29.499] [LOG]    Starting module helper: MMM-Vrr
              [2020-10-01 19:30:29.500] [LOG]    Connecting socket for: MMM-AVStock
              [2020-10-01 19:30:29.501] [LOG]    Connecting socket for: MMM-News
              [2020-10-01 19:30:29.502] [LOG]    Connecting socket for: MMM-MovieListings
              [2020-10-01 19:30:29.503] [LOG]    MMM-MovieListing helper started...
              [2020-10-01 19:30:29.504] [LOG]    Connecting socket for: MMM-teamspeak3
              [2020-10-01 19:30:29.505] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
              [2020-10-01 19:30:29.506] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
              [2020-10-01 19:30:29.507] [LOG]    Connecting socket for: MMM-DWD-WarnWeather
              [2020-10-01 19:30:29.508] [LOG]    MMM-DWD-WarnWeather helper started...
              [2020-10-01 19:30:29.508] [LOG]    Connecting socket for: MMM-Fuel
              [2020-10-01 19:30:29.509] [LOG]    Starting module helper: MMM-Fuel
              [2020-10-01 19:30:29.510] [LOG]    Connecting socket for: MMM-Bring
              [2020-10-01 19:30:29.511] [LOG]    Sockets connected & modules started ...
              [2020-10-01 19:30:29.656] [LOG]    Launching application.
              [2020-10-01 19:32:30.032] [LOG]    Shutting down server...
              [2020-10-01 19:32:30.034] [LOG]    Stopping module helper: mmpm
              [2020-10-01 19:32:30.035] [LOG]    Stopping module helper: updatenotification
              [2020-10-01 19:32:30.036] [LOG]    Stopping module helper: newsfeed
              [2020-10-01 19:32:30.036] [LOG]    Stopping module helper: MMM-Spotify
              [2020-10-01 19:32:30.037] [LOG]    Stopping module helper: calendar
              [2020-10-01 19:32:30.037] [LOG]    Stopping module helper: MMM-MyCommute
              [2020-10-01 19:32:30.038] [LOG]    Stopping module helper: MMM-Vrr
              [2020-10-01 19:32:30.038] [LOG]    Stopping module helper: MMM-AVStock
              [2020-10-01 19:32:30.039] [LOG]    Stopping module helper: MMM-News
              [2020-10-01 19:32:30.040] [LOG]    Stopping module helper: MMM-MovieListings
              [2020-10-01 19:32:30.040] [LOG]    Stopping module helper: MMM-teamspeak3
              [2020-10-01 19:32:30.041] [LOG]    Stopping module helper: MMM-FRITZ-Box-Callmonitor
              [2020-10-01 19:32:30.041] [LOG]    Stopping module helper: MMM-DWD-WarnWeather
              [2020-10-01 19:32:30.042] [LOG]    Stopping module helper: MMM-Fuel
              [2020-10-01 19:32:30.042] [LOG]    Stopping module helper: MMM-Bring
              Console output
              main.js:487 Initializing MagicMirror.
              translator.js:129 Loading core translation file: translations/de.json
              translator.js:154 Loading core translation fallback file: translations/en.json
              loader.js:176 Load script: modules/MMM-pages//MMM-pages.js
              module.js:513 Module registered: MMM-pages
              loader.js:148 Bootstrapping module: MMM-pages
              loader.js:153 Scripts loaded for: MMM-pages
              loader.js:195 Load stylesheet: modules/MMM-pages/pages.css
              loader.js:155 Styles loaded for: MMM-pages
              loader.js:157 Translations loaded for: MMM-pages
              loader.js:176 Load script: modules/default/alert//alert.js
              module.js:513 Module registered: alert
              loader.js:148 Bootstrapping module: alert
              loader.js:176 Load script: modules/default/alert/notificationFx.js
              loader.js:153 Scripts loaded for: alert
              loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
              loader.js:195 Load stylesheet: vendor/css/font-awesome.css
              loader.js:155 Styles loaded for: alert
              translator.js:100 alert - Load translation: translations/de.json
              /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                protocols.This exposes users of this app to unnecessary security risks.
                Consider loading the following resources over HTTPS or FTPS.
               - http://0.0.0.0:8080/css/main.css
              - http://0.0.0.0:8080/fonts/roboto.css
              - http://0.0.0.0:8080/socket.io/socket.io.js
              - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
              - http://0.0.0.0:8080/js/defaults.js
              - http://0.0.0.0:8080/config/config.js
              - http://0.0.0.0:8080/vendor/vendor.js
              - http://0.0.0.0:8080/modules/default/defaultmodules.js
              - http://0.0.0.0:8080/js/logger.js
              - http://0.0.0.0:8080/translations/translations.js
              - http://0.0.0.0:8080/js/translator.js
              - http://0.0.0.0:8080/js/class.js
              - http://0.0.0.0:8080/js/module.js
              - http://0.0.0.0:8080/js/loader.js
              - http://0.0.0.0:8080/js/socketclient.js
              - http://0.0.0.0:8080/js/main.js
              - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
              - http://0.0.0.0:8080/translations/de.json
              - http://0.0.0.0:8080/translations/en.json
              - http://0.0.0.0:8080/modules/MMM-pages//MMM-pages.js
              - http://0.0.0.0:8080/modules/MMM-pages/pages.css
              - http://0.0.0.0:8080/modules/default/alert//alert.js
              - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
              - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
              - http://0.0.0.0:8080/vendor/css/font-awesome.css
              - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
              - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
              For more information and help, consult
              https://electronjs.org/docs/tutorial/security.
               This warning will not show up
              once the app is packaged.
              warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
              /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                  Policy set or a policy with "unsafe-eval" enabled. This exposes users of
              (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145
              translator.js:102 alert - Load translation fallback: translations/en.json
              loader.js:157 Translations loaded for: alert
              loader.js:176 Load script: modules/mmpm//mmpm.js
              module.js:513 Module registered: mmpm
              loader.js:148 Bootstrapping module: mmpm
              loader.js:153 Scripts loaded for: mmpm
              loader.js:155 Styles loaded for: mmpm
              loader.js:157 Translations loaded for: mmpm
              loader.js:176 Load script: modules/default/updatenotification//updatenotification.js
              module.js:513 Module registered: updatenotification
              loader.js:148 Bootstrapping module: updatenotification
              loader.js:153 Scripts loaded for: updatenotification
              loader.js:155 Styles loaded for: updatenotification
              loader.js:157 Translations loaded for: updatenotification
              loader.js:176 Load script: modules/default/newsfeed//newsfeed.js
              module.js:513 Module registered: newsfeed
              loader.js:148 Bootstrapping module: newsfeed
              loader.js:176 Load script: vendor/node_modules/moment/min/moment-with-locales.js
              loader.js:153 Scripts loaded for: newsfeed
              loader.js:155 Styles loaded for: newsfeed
              loader.js:157 Translations loaded for: newsfeed
              loader.js:176 Load script: modules/MMM-page-indicator//MMM-page-indicator.js
              module.js:513 Module registered: MMM-page-indicator
              loader.js:148 Bootstrapping module: MMM-page-indicator
              loader.js:153 Scripts loaded for: MMM-page-indicator
              loader.js:236 File already loaded: font-awesome.css
              loader.js:195 Load stylesheet: modules/MMM-page-indicator/page-indicators.css
              loader.js:155 Styles loaded for: MMM-page-indicator
              loader.js:157 Translations loaded for: MMM-page-indicator
              loader.js:176 Load script: modules/default/clock//clock.js
              module.js:513 Module registered: clock
              loader.js:148 Bootstrapping module: clock
              loader.js:236 File already loaded: moment.js
              loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
              loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js
              loader.js:153 Scripts loaded for: clock
              loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css
              loader.js:155 Styles loaded for: clock
              loader.js:157 Translations loaded for: clock
              loader.js:176 Load script: modules/MMM-Callmonitor-Current-Call//MMM-Callmonitor-Current-Call.js
              module.js:513 Module registered: MMM-Callmonitor-Current-Call
              loader.js:148 Bootstrapping module: MMM-Callmonitor-Current-Call
              loader.js:153 Scripts loaded for: MMM-Callmonitor-Current-Call
              loader.js:155 Styles loaded for: MMM-Callmonitor-Current-Call
              translator.js:100 MMM-Callmonitor-Current-Call - Load translation: translations/de.json
              translator.js:102 MMM-Callmonitor-Current-Call - Load translation fallback: translations/en.json
              loader.js:157 Translations loaded for: MMM-Callmonitor-Current-Call
              loader.js:176 Load script: modules/MMM-Spotify//MMM-Spotify.js
              module.js:513 Module registered: MMM-Spotify
              loader.js:148 Bootstrapping module: MMM-Spotify
              loader.js:195 Load stylesheet: https://cdn.materialdesignicons.com/5.2.45/css/materialdesignicons.min.css
              loader.js:176 Load script: https://code.iconify.design/1/1.0.6/iconify.min.js
              loader.js:153 Scripts loaded for: MMM-Spotify
              loader.js:195 Load stylesheet: modules/MMM-Spotify/MMM-Spotify.css
              loader.js:155 Styles loaded for: MMM-Spotify
              loader.js:157 Translations loaded for: MMM-Spotify
              loader.js:176 Load script: modules/default/calendar//calendar.js
              module.js:513 Module registered: calendar
              loader.js:148 Bootstrapping module: calendar
              loader.js:153 Scripts loaded for: calendar
              loader.js:195 Load stylesheet: modules/default/calendar/calendar.css
              loader.js:155 Styles loaded for: calendar
              loader.js:157 Translations loaded for: calendar
              loader.js:176 Load script: modules/MMM-MyCommute//MMM-MyCommute.js
              module.js:513 Module registered: MMM-MyCommute
              loader.js:148 Bootstrapping module: MMM-MyCommute
              loader.js:176 Load script: modules/MMM-MyCommute/node_modules/moment-duration-format/lib/moment-duration-format.js
              loader.js:153 Scripts loaded for: MMM-MyCommute
              loader.js:195 Load stylesheet: modules/MMM-MyCommute/MMM-MyCommute.css
              loader.js:155 Styles loaded for: MMM-MyCommute
              translator.js:102 MMM-MyCommute - Load translation fallback: translations/en.json
              loader.js:157 Translations loaded for: MMM-MyCommute
              loader.js:176 Load script: modules/MMM-Vrr//MMM-Vrr.js
              module.js:505 Check MagicMirror version for module 'MMM-Vrr' - Minimum version:  2.1.0 - Current version: 2.13.0
              module.js:507 Version is ok!
              module.js:513 Module registered: MMM-Vrr
              loader.js:148 Bootstrapping module: MMM-Vrr
              loader.js:153 Scripts loaded for: MMM-Vrr
              loader.js:195 Load stylesheet: modules/MMM-Vrr/MMM-Vrr.css
              loader.js:155 Styles loaded for: MMM-Vrr
              translator.js:100 MMM-Vrr - Load translation: translations/de.json
              translator.js:102 MMM-Vrr - Load translation fallback: translations/en.json
              loader.js:157 Translations loaded for: MMM-Vrr
              loader.js:236 File already loaded: MMM-Vrr.css
              loader.js:176 Load script: modules/MMM-AVStock//MMM-AVStock.js
              module.js:513 Module registered: MMM-AVStock
              loader.js:148 Bootstrapping module: MMM-AVStock
              loader.js:176 Load script: modules/MMM-AVStock/node_modules/highcharts/highstock.js
              loader.js:176 Load script: modules/MMM-AVStock/node_modules/highcharts/modules/no-data-to-display.js
              loader.js:153 Scripts loaded for: MMM-AVStock
              loader.js:195 Load stylesheet: modules/MMM-AVStock/MMM-AVStock.css
              loader.js:155 Styles loaded for: MMM-AVStock
              loader.js:157 Translations loaded for: MMM-AVStock
              loader.js:176 Load script: modules/MMM-News//MMM-News.js
              module.js:513 Module registered: MMM-News
              loader.js:148 Bootstrapping module: MMM-News
              loader.js:153 Scripts loaded for: MMM-News
              loader.js:195 Load stylesheet: modules/MMM-News/MMM-News.css
              loader.js:155 Styles loaded for: MMM-News
              loader.js:157 Translations loaded for: MMM-News
              loader.js:176 Load script: modules/MMM-MovieListings//MMM-MovieListings.js
              module.js:513 Module registered: MMM-MovieListings
              loader.js:148 Bootstrapping module: MMM-MovieListings
              loader.js:153 Scripts loaded for: MMM-MovieListings
              loader.js:195 Load stylesheet: modules/MMM-MovieListings/MMM-MovieListings.css
              loader.js:155 Styles loaded for: MMM-MovieListings
              translator.js:100 MMM-MovieListings - Load translation: translations/de.json
              translator.js:102 MMM-MovieListings - Load translation fallback: translations/en.json
              loader.js:157 Translations loaded for: MMM-MovieListings
              loader.js:176 Load script: modules/MMM-PlexNowPlaying//MMM-PlexNowPlaying.js
              module.js:505 Check MagicMirror version for module 'MMM-PlexNowPlaying' - Minimum version:  2.2.1 - Current version: 2.13.0
              module.js:513 Module registered: MMM-PlexNowPlaying
              loader.js:148 Bootstrapping module: MMM-PlexNowPlaying
              loader.js:176 Load script: modules/MMM-PlexNowPlaying/scripts/axis.js
              loader.js:153 Scripts loaded for: MMM-PlexNowPlaying
              loader.js:195 Load stylesheet: modules/MMM-PlexNowPlaying/MMM-PlexNowPlaying.css
              loader.js:155 Styles loaded for: MMM-PlexNowPlaying
              translator.js:102 MMM-PlexNowPlaying - Load translation fallback: translations/en.json
              loader.js:157 Translations loaded for: MMM-PlexNowPlaying
              loader.js:176 Load script: modules/MMM-teamspeak3//MMM-teamspeak3.js
              module.js:513 Module registered: MMM-teamspeak3
              loader.js:148 Bootstrapping module: MMM-teamspeak3
              loader.js:153 Scripts loaded for: MMM-teamspeak3
              loader.js:155 Styles loaded for: MMM-teamspeak3
              loader.js:157 Translations loaded for: MMM-teamspeak3
              loader.js:176 Load script: modules/MMM-FRITZ-Box-Callmonitor//MMM-FRITZ-Box-Callmonitor.js
              module.js:505 Check MagicMirror version for module 'MMM-FRITZ-Box-Callmonitor' - Minimum version:  2.0.0 - Current version: 2.13.0
              module.js:513 Module registered: MMM-FRITZ-Box-Callmonitor
              loader.js:148 Bootstrapping module: MMM-FRITZ-Box-Callmonitor
              loader.js:153 Scripts loaded for: MMM-FRITZ-Box-Callmonitor
              loader.js:195 Load stylesheet: modules/MMM-FRITZ-Box-Callmonitor/MMM-FRITZ-Box-Callmonitor.css
              loader.js:155 Styles loaded for: MMM-FRITZ-Box-Callmonitor
              translator.js:100 MMM-FRITZ-Box-Callmonitor - Load translation: translations/de.json
              (index):5 Uncaught SyntaxError: Unexpected token / in JSON at position 79
                  at JSON.parse (<anonymous>)
                  at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
              Commands where executed from a console on the pi desktop, not via ssh (unlike before).
                sdetweil @requiemmg
                @requiemmg said in Black screen after 2.13 update:
                see this issue https://github.com/MichMich/MagicMirror/issues/2144
                there is a bug in the fritzbox language files
                  requiemmg
                  Great, this fixed it. Thanks a lot!
                  • C Offline
                    carlywarly
                    @sdetweil said in Black screen after 2.13 update:
                    history of commands…
                    525 cd ./MagicMirror
                    526 git pull
                    527 sudo reboot
                    << black screen >>
                    528 sudo apt update
                    529 sudo apt upgrade
                    530 sudo reboot
                    531 cd /MagicMirror
                    532 cd node_modules/
                    533 ls
                    534 sudo rm -r electron
                    535 cd …
                    536 npm install
                    537 pm2 logs --lines=100
                    540 sudo reboot
                    << black screen >>
                    541 ifconfig
                    542 sudo reboot
                    543 history
                    Working again…??? I think it my pi possibly had a problem talking to the internet… maybe the reboot gods strike again???
                    BTW thx for the quick reply :)
                    CarlyWarly
                      @carlywarly cool, glad its working… but… sure would have been nice to see the error messages… shouldn’t black screen for a network problem…
                      but that usually means a module didn’t handle network failure and crashed and UI died
                        m0bed @carlywarly
                        @carlywarly thank you for your help. I tried all of the mentions commands bot still having a black screen.
                        on "pm2 logs --lines=100 i get this error message.
                        0|MagicMir | npm ERR! Linux 4.19.66-v7+
                        0|MagicMir | npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                        0|MagicMir | npm ERR! node v6.14.1
                        0|MagicMir | npm ERR! npm  v3.10.10
                        0|MagicMir | npm ERR! code ELIFECYCLE
                        0|MagicMir | npm ERR! magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                        0|MagicMir | npm ERR! Exit status 1
                        0|MagicMir | npm ERR! Failed at the magicmirror@2.13.0 start script 'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'.
                        0|MagicMir | npm ERR! Make sure you have the latest version of node.js and npm installed.
                        0|MagicMir | npm ERR! If you do, this is most likely a problem with the magicmirror package,
                        0|MagicMir | npm ERR! not with npm itself.
                        0|MagicMir | npm ERR! Tell the author that this fails on your system:
                        0|MagicMir | npm ERR!     DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                        0|MagicMir | npm ERR! You can get information on how to open an issue for this project with:
                        0|MagicMir | npm ERR!     npm bugs magicmirror
                        0|MagicMir | npm ERR! Or if that isn't available, you can get their info via:
                        0|MagicMir | npm ERR!     npm owner ls magicmirror
                        0|MagicMir | npm ERR! There is likely additional logging output above.
                        0|MagicMir |
                        0|MagicMir | npm ERR! Please include the following file with any support request:
                        0|MagicMir | npm ERR!     /home/pi/MagicMirror/npm-debug.log
                        0|MagicMir | Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                        0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                        Also after running “npm install” I get this messages:
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm WARN acorn-jsx@5.3.1 requires a peer of acorn@^6.0.0 || ^7.0.0 || ^8.0.0 but none was installed.
                        npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none was installed.
                        npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none was installed.
                        npm WARN ws@7.3.1 requires a peer of bufferutil@^4.0.1 but none was installed.
                        npm WARN ws@7.3.1 requires a peer of utf-8-validate@^5.0.2 but none was installed.
                        After a reboot the desktop starts, also some programm starts turning screen first white for 2 seconds then it turns black.
                        What can I do?
                        Daniel
                        • 6
                        • 6 / 6
