    Black screen after 2.13 update - tentatively resolved
    53 Posts 9 Posters 23.3k Views 9 Watching
      sdetweil @requiemmg
      @requiemmg do what it said. delete the electron folder and then redo npm install
        requiemmg
        Thanks for your help, Sam, this is very much appreciated.
        Ok, so I went into
        /MagicMirror/node_modules
        did a
        sudo rm -r electron
        went back to /MagicMirror
        and did an npm install
        This reinstalled electron. Unfortunately, I still got a black screen.
        So, I renamed MagicMirror
        made a git pull && npm install of the MagicMirror repo
        and moved my css, config and modules folder from the old directory.
        And I still get a black screen. :-(
          sdetweil @requiemmg
          @requiemmg and any message?
          • FoziF Offline
            Fozi Project Sponsor @requiemmg
            @requiemmg although I haven’t updated yet I‘d try @sdetweil script. That worked with each update for me
              requiemmg
              Sorry, no messages, just a black screen. Also tried the update script, which just gives me an “everything up to date”. :-(
                carlywarly
                Same here, no messages, just black screen.
                  sdetweil @carlywarly
                  @carlywarly @requiemmg in the window where u start MM… either npm start or pm2
                  if pm2, use pm2 logs --lines=???
                  where ??? is a number 15 is the default.
                  or open the developers window,
                  ctrl-shift-i, select the console tab and scroll up
                    requiemmg
                    pm2 logs --lines=20 throws an error (unknown option)
                    SO I did a npm start and copied both npm start output and the console window output. Here it is:
                    npm start log:
                    pi@SmartMirror2:~/MagicMirror $ npm start
                    > magicmirror@2.13.0 start /home/pi/MagicMirror
                    [2020-10-01 19:30:24.700] [LOG]    Starting MagicMirror: v2.13.0
                    [2020-10-01 19:30:24.712] [LOG]    Loading config ...
                    [2020-10-01 19:30:24.730] [LOG]    Loading module helpers ...
                    [2020-10-01 19:30:24.734] [LOG]    No helper found for module: MMM-pages.
                    [2020-10-01 19:30:24.736] [LOG]    No helper found for module: alert.
                    [2020-10-01 19:30:24.745] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:24.747] [LOG]    Module helper loaded: mmpm
                    [2020-10-01 19:30:24.843] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:24.844] [LOG]    Module helper loaded: updatenotification
                    [2020-10-01 19:30:25.437] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:25.438] [LOG]    Module helper loaded: newsfeed
                    [2020-10-01 19:30:25.439] [LOG]    No helper found for module: MMM-page-indicator.
                    [2020-10-01 19:30:25.440] [LOG]    No helper found for module: clock.
                    [2020-10-01 19:30:25.441] [LOG]    No helper found for module: MMM-Callmonitor-Current-Call.
                    [2020-10-01 19:30:26.288] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:26.289] [LOG]    Module helper loaded: MMM-Spotify
                    [2020-10-01 19:30:26.451] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:26.452] [LOG]    Module helper loaded: calendar
                    [2020-10-01 19:30:26.999] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:27.000] [LOG]    Module helper loaded: MMM-MyCommute
                    [2020-10-01 19:30:27.002] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:27.003] [LOG]    Module helper loaded: MMM-Vrr
                    [2020-10-01 19:30:27.566] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:27.567] [LOG]    Module helper loaded: MMM-AVStock
                    [2020-10-01 19:30:27.574] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:27.575] [LOG]    Module helper loaded: MMM-News
                    [2020-10-01 19:30:28.174] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:28.175] [LOG]    Module helper loaded: MMM-MovieListings
                    [2020-10-01 19:30:28.176] [LOG]    No helper found for module: MMM-PlexNowPlaying.
                    [2020-10-01 19:30:28.187] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:28.188] [LOG]    Module helper loaded: MMM-teamspeak3
                    [2020-10-01 19:30:28.525] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:28.526] [LOG]    Module helper loaded: MMM-FRITZ-Box-Callmonitor
                    [2020-10-01 19:30:29.077] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:29.078] [LOG]    Module helper loaded: MMM-DWD-WarnWeather
                    [2020-10-01 19:30:29.203] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:29.204] [LOG]    Module helper loaded: MMM-Fuel
                    [2020-10-01 19:30:29.205] [LOG]    No helper found for module: MMM-WeatherOrNot.
                    [2020-10-01 19:30:29.290] [LOG]    Initializing new module helper ...
                    [2020-10-01 19:30:29.291] [LOG]    Module helper loaded: MMM-Bring
                    [2020-10-01 19:30:29.291] [LOG]    All module helpers loaded.
                    [2020-10-01 19:30:29.471] [LOG]    Starting server on port 8080 ...
                    [2020-10-01 19:30:29.475] [INFO]   You're using a full whitelist configuration to allow for all IPs
                    [2020-10-01 19:30:29.485] [LOG]    Server started ...
                    [2020-10-01 19:30:29.487] [LOG]    Connecting socket for: mmpm
                    [2020-10-01 19:30:29.488] [LOG]    Starting module helper: mmpm
                    [2020-10-01 19:30:29.490] [LOG]    Connecting socket for: updatenotification
                    [2020-10-01 19:30:29.491] [LOG]    Connecting socket for: newsfeed
                    [2020-10-01 19:30:29.492] [LOG]    Starting node helper for: newsfeed
                    [2020-10-01 19:30:29.493] [LOG]    Connecting socket for: MMM-Spotify
                    [2020-10-01 19:30:29.494] [LOG]    Connecting socket for: calendar
                    [2020-10-01 19:30:29.495] [LOG]    Starting node helper for: calendar
                    [2020-10-01 19:30:29.496] [LOG]    Connecting socket for: MMM-MyCommute
                    [2020-10-01 19:30:29.497] [LOG]    ====================== Starting node_helper for module [MMM-MyCommute]
                    [2020-10-01 19:30:29.498] [LOG]    Connecting socket for: MMM-Vrr
                    [2020-10-01 19:30:29.499] [LOG]    Starting module helper: MMM-Vrr
                    [2020-10-01 19:30:29.500] [LOG]    Connecting socket for: MMM-AVStock
                    [2020-10-01 19:30:29.501] [LOG]    Connecting socket for: MMM-News
                    [2020-10-01 19:30:29.502] [LOG]    Connecting socket for: MMM-MovieListings
                    [2020-10-01 19:30:29.503] [LOG]    MMM-MovieListing helper started...
                    [2020-10-01 19:30:29.504] [LOG]    Connecting socket for: MMM-teamspeak3
                    [2020-10-01 19:30:29.505] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
                    [2020-10-01 19:30:29.506] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
                    [2020-10-01 19:30:29.507] [LOG]    Connecting socket for: MMM-DWD-WarnWeather
                    [2020-10-01 19:30:29.508] [LOG]    MMM-DWD-WarnWeather helper started...
                    [2020-10-01 19:30:29.508] [LOG]    Connecting socket for: MMM-Fuel
                    [2020-10-01 19:30:29.509] [LOG]    Starting module helper: MMM-Fuel
                    [2020-10-01 19:30:29.510] [LOG]    Connecting socket for: MMM-Bring
                    [2020-10-01 19:30:29.511] [LOG]    Sockets connected & modules started ...
                    [2020-10-01 19:30:29.656] [LOG]    Launching application.
                    [2020-10-01 19:32:30.032] [LOG]    Shutting down server...
                    [2020-10-01 19:32:30.034] [LOG]    Stopping module helper: mmpm
                    [2020-10-01 19:32:30.035] [LOG]    Stopping module helper: updatenotification
                    [2020-10-01 19:32:30.036] [LOG]    Stopping module helper: newsfeed
                    [2020-10-01 19:32:30.036] [LOG]    Stopping module helper: MMM-Spotify
                    [2020-10-01 19:32:30.037] [LOG]    Stopping module helper: calendar
                    [2020-10-01 19:32:30.037] [LOG]    Stopping module helper: MMM-MyCommute
                    [2020-10-01 19:32:30.038] [LOG]    Stopping module helper: MMM-Vrr
                    [2020-10-01 19:32:30.038] [LOG]    Stopping module helper: MMM-AVStock
                    [2020-10-01 19:32:30.039] [LOG]    Stopping module helper: MMM-News
                    [2020-10-01 19:32:30.040] [LOG]    Stopping module helper: MMM-MovieListings
                    [2020-10-01 19:32:30.040] [LOG]    Stopping module helper: MMM-teamspeak3
                    [2020-10-01 19:32:30.041] [LOG]    Stopping module helper: MMM-FRITZ-Box-Callmonitor
                    [2020-10-01 19:32:30.041] [LOG]    Stopping module helper: MMM-DWD-WarnWeather
                    [2020-10-01 19:32:30.042] [LOG]    Stopping module helper: MMM-Fuel
                    [2020-10-01 19:32:30.042] [LOG]    Stopping module helper: MMM-Bring
                    Console output
                    main.js:487 Initializing MagicMirror.
                    translator.js:129 Loading core translation file: translations/de.json
                    translator.js:154 Loading core translation fallback file: translations/en.json
                    loader.js:176 Load script: modules/MMM-pages//MMM-pages.js
                    module.js:513 Module registered: MMM-pages
                    loader.js:148 Bootstrapping module: MMM-pages
                    loader.js:153 Scripts loaded for: MMM-pages
                    loader.js:195 Load stylesheet: modules/MMM-pages/pages.css
                    loader.js:155 Styles loaded for: MMM-pages
                    loader.js:157 Translations loaded for: MMM-pages
                    loader.js:176 Load script: modules/default/alert//alert.js
                    module.js:513 Module registered: alert
                    loader.js:148 Bootstrapping module: alert
                    loader.js:176 Load script: modules/default/alert/notificationFx.js
                    loader.js:153 Scripts loaded for: alert
                    loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
                    loader.js:195 Load stylesheet: vendor/css/font-awesome.css
                    loader.js:155 Styles loaded for: alert
                    translator.js:100 alert - Load translation: translations/de.json
                    /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                      protocols.This exposes users of this app to unnecessary security risks.
                      Consider loading the following resources over HTTPS or FTPS.
                     - http://0.0.0.0:8080/css/main.css
                    - http://0.0.0.0:8080/fonts/roboto.css
                    - http://0.0.0.0:8080/socket.io/socket.io.js
                    - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                    - http://0.0.0.0:8080/js/defaults.js
                    - http://0.0.0.0:8080/config/config.js
                    - http://0.0.0.0:8080/vendor/vendor.js
                    - http://0.0.0.0:8080/modules/default/defaultmodules.js
                    - http://0.0.0.0:8080/js/logger.js
                    - http://0.0.0.0:8080/translations/translations.js
                    - http://0.0.0.0:8080/js/translator.js
                    - http://0.0.0.0:8080/js/class.js
                    - http://0.0.0.0:8080/js/module.js
                    - http://0.0.0.0:8080/js/loader.js
                    - http://0.0.0.0:8080/js/socketclient.js
                    - http://0.0.0.0:8080/js/main.js
                    - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                    - http://0.0.0.0:8080/translations/de.json
                    - http://0.0.0.0:8080/translations/en.json
                    - http://0.0.0.0:8080/modules/MMM-pages//MMM-pages.js
                    - http://0.0.0.0:8080/modules/MMM-pages/pages.css
                    - http://0.0.0.0:8080/modules/default/alert//alert.js
                    - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
                    - http://0.0.0.0:8080/modules/default/alert/notificationFx.css
                    - http://0.0.0.0:8080/vendor/css/font-awesome.css
                    - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
                    - http://0.0.0.0:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
                    For more information and help, consult
                    https://electronjs.org/docs/tutorial/security.
                     This warning will not show up
                    once the app is packaged.
                    warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
                    /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                        Policy set or a policy with "unsafe-eval" enabled. This exposes users of
                    (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145
                    translator.js:102 alert - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: alert
                    loader.js:176 Load script: modules/mmpm//mmpm.js
                    module.js:513 Module registered: mmpm
                    loader.js:148 Bootstrapping module: mmpm
                    loader.js:153 Scripts loaded for: mmpm
                    loader.js:155 Styles loaded for: mmpm
                    loader.js:157 Translations loaded for: mmpm
                    loader.js:176 Load script: modules/default/updatenotification//updatenotification.js
                    module.js:513 Module registered: updatenotification
                    loader.js:148 Bootstrapping module: updatenotification
                    loader.js:153 Scripts loaded for: updatenotification
                    loader.js:155 Styles loaded for: updatenotification
                    loader.js:157 Translations loaded for: updatenotification
                    loader.js:176 Load script: modules/default/newsfeed//newsfeed.js
                    module.js:513 Module registered: newsfeed
                    loader.js:148 Bootstrapping module: newsfeed
                    loader.js:176 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                    loader.js:153 Scripts loaded for: newsfeed
                    loader.js:155 Styles loaded for: newsfeed
                    loader.js:157 Translations loaded for: newsfeed
                    loader.js:176 Load script: modules/MMM-page-indicator//MMM-page-indicator.js
                    module.js:513 Module registered: MMM-page-indicator
                    loader.js:148 Bootstrapping module: MMM-page-indicator
                    loader.js:153 Scripts loaded for: MMM-page-indicator
                    loader.js:236 File already loaded: font-awesome.css
                    loader.js:195 Load stylesheet: modules/MMM-page-indicator/page-indicators.css
                    loader.js:155 Styles loaded for: MMM-page-indicator
                    loader.js:157 Translations loaded for: MMM-page-indicator
                    loader.js:176 Load script: modules/default/clock//clock.js
                    module.js:513 Module registered: clock
                    loader.js:148 Bootstrapping module: clock
                    loader.js:236 File already loaded: moment.js
                    loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                    loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js
                    loader.js:153 Scripts loaded for: clock
                    loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css
                    loader.js:155 Styles loaded for: clock
                    loader.js:157 Translations loaded for: clock
                    loader.js:176 Load script: modules/MMM-Callmonitor-Current-Call//MMM-Callmonitor-Current-Call.js
                    module.js:513 Module registered: MMM-Callmonitor-Current-Call
                    loader.js:148 Bootstrapping module: MMM-Callmonitor-Current-Call
                    loader.js:153 Scripts loaded for: MMM-Callmonitor-Current-Call
                    loader.js:155 Styles loaded for: MMM-Callmonitor-Current-Call
                    translator.js:100 MMM-Callmonitor-Current-Call - Load translation: translations/de.json
                    translator.js:102 MMM-Callmonitor-Current-Call - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-Callmonitor-Current-Call
                    loader.js:176 Load script: modules/MMM-Spotify//MMM-Spotify.js
                    module.js:513 Module registered: MMM-Spotify
                    loader.js:148 Bootstrapping module: MMM-Spotify
                    loader.js:195 Load stylesheet: https://cdn.materialdesignicons.com/5.2.45/css/materialdesignicons.min.css
                    loader.js:176 Load script: https://code.iconify.design/1/1.0.6/iconify.min.js
                    loader.js:153 Scripts loaded for: MMM-Spotify
                    loader.js:195 Load stylesheet: modules/MMM-Spotify/MMM-Spotify.css
                    loader.js:155 Styles loaded for: MMM-Spotify
                    loader.js:157 Translations loaded for: MMM-Spotify
                    loader.js:176 Load script: modules/default/calendar//calendar.js
                    module.js:513 Module registered: calendar
                    loader.js:148 Bootstrapping module: calendar
                    loader.js:153 Scripts loaded for: calendar
                    loader.js:195 Load stylesheet: modules/default/calendar/calendar.css
                    loader.js:155 Styles loaded for: calendar
                    loader.js:157 Translations loaded for: calendar
                    loader.js:176 Load script: modules/MMM-MyCommute//MMM-MyCommute.js
                    module.js:513 Module registered: MMM-MyCommute
                    loader.js:148 Bootstrapping module: MMM-MyCommute
                    loader.js:176 Load script: modules/MMM-MyCommute/node_modules/moment-duration-format/lib/moment-duration-format.js
                    loader.js:153 Scripts loaded for: MMM-MyCommute
                    loader.js:195 Load stylesheet: modules/MMM-MyCommute/MMM-MyCommute.css
                    loader.js:155 Styles loaded for: MMM-MyCommute
                    translator.js:102 MMM-MyCommute - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-MyCommute
                    loader.js:176 Load script: modules/MMM-Vrr//MMM-Vrr.js
                    module.js:505 Check MagicMirror version for module 'MMM-Vrr' - Minimum version:  2.1.0 - Current version: 2.13.0
                    module.js:507 Version is ok!
                    module.js:513 Module registered: MMM-Vrr
                    loader.js:148 Bootstrapping module: MMM-Vrr
                    loader.js:153 Scripts loaded for: MMM-Vrr
                    loader.js:195 Load stylesheet: modules/MMM-Vrr/MMM-Vrr.css
                    loader.js:155 Styles loaded for: MMM-Vrr
                    translator.js:100 MMM-Vrr - Load translation: translations/de.json
                    translator.js:102 MMM-Vrr - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-Vrr
                    loader.js:236 File already loaded: MMM-Vrr.css
                    loader.js:176 Load script: modules/MMM-AVStock//MMM-AVStock.js
                    module.js:513 Module registered: MMM-AVStock
                    loader.js:148 Bootstrapping module: MMM-AVStock
                    loader.js:176 Load script: modules/MMM-AVStock/node_modules/highcharts/highstock.js
                    loader.js:176 Load script: modules/MMM-AVStock/node_modules/highcharts/modules/no-data-to-display.js
                    loader.js:153 Scripts loaded for: MMM-AVStock
                    loader.js:195 Load stylesheet: modules/MMM-AVStock/MMM-AVStock.css
                    loader.js:155 Styles loaded for: MMM-AVStock
                    loader.js:157 Translations loaded for: MMM-AVStock
                    loader.js:176 Load script: modules/MMM-News//MMM-News.js
                    module.js:513 Module registered: MMM-News
                    loader.js:148 Bootstrapping module: MMM-News
                    loader.js:153 Scripts loaded for: MMM-News
                    loader.js:195 Load stylesheet: modules/MMM-News/MMM-News.css
                    loader.js:155 Styles loaded for: MMM-News
                    loader.js:157 Translations loaded for: MMM-News
                    loader.js:176 Load script: modules/MMM-MovieListings//MMM-MovieListings.js
                    module.js:513 Module registered: MMM-MovieListings
                    loader.js:148 Bootstrapping module: MMM-MovieListings
                    loader.js:153 Scripts loaded for: MMM-MovieListings
                    loader.js:195 Load stylesheet: modules/MMM-MovieListings/MMM-MovieListings.css
                    loader.js:155 Styles loaded for: MMM-MovieListings
                    translator.js:100 MMM-MovieListings - Load translation: translations/de.json
                    translator.js:102 MMM-MovieListings - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-MovieListings
                    loader.js:176 Load script: modules/MMM-PlexNowPlaying//MMM-PlexNowPlaying.js
                    module.js:505 Check MagicMirror version for module 'MMM-PlexNowPlaying' - Minimum version:  2.2.1 - Current version: 2.13.0
                    module.js:513 Module registered: MMM-PlexNowPlaying
                    loader.js:148 Bootstrapping module: MMM-PlexNowPlaying
                    loader.js:176 Load script: modules/MMM-PlexNowPlaying/scripts/axis.js
                    loader.js:153 Scripts loaded for: MMM-PlexNowPlaying
                    loader.js:195 Load stylesheet: modules/MMM-PlexNowPlaying/MMM-PlexNowPlaying.css
                    loader.js:155 Styles loaded for: MMM-PlexNowPlaying
                    translator.js:102 MMM-PlexNowPlaying - Load translation fallback: translations/en.json
                    loader.js:157 Translations loaded for: MMM-PlexNowPlaying
                    loader.js:176 Load script: modules/MMM-teamspeak3//MMM-teamspeak3.js
                    module.js:513 Module registered: MMM-teamspeak3
                    loader.js:148 Bootstrapping module: MMM-teamspeak3
                    loader.js:153 Scripts loaded for: MMM-teamspeak3
                    loader.js:155 Styles loaded for: MMM-teamspeak3
                    loader.js:157 Translations loaded for: MMM-teamspeak3
                    loader.js:176 Load script: modules/MMM-FRITZ-Box-Callmonitor//MMM-FRITZ-Box-Callmonitor.js
                    module.js:505 Check MagicMirror version for module 'MMM-FRITZ-Box-Callmonitor' - Minimum version:  2.0.0 - Current version: 2.13.0
                    module.js:513 Module registered: MMM-FRITZ-Box-Callmonitor
                    loader.js:148 Bootstrapping module: MMM-FRITZ-Box-Callmonitor
                    loader.js:153 Scripts loaded for: MMM-FRITZ-Box-Callmonitor
                    loader.js:195 Load stylesheet: modules/MMM-FRITZ-Box-Callmonitor/MMM-FRITZ-Box-Callmonitor.css
                    loader.js:155 Styles loaded for: MMM-FRITZ-Box-Callmonitor
                    translator.js:100 MMM-FRITZ-Box-Callmonitor - Load translation: translations/de.json
                    (index):5 Uncaught SyntaxError: Unexpected token / in JSON at position 79
                        at JSON.parse (<anonymous>)
                        at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
                    Commands where executed from a console on the pi desktop, not via ssh (unlike before).
                      sdetweil @requiemmg
                      @requiemmg said in Black screen after 2.13 update:
                      see this issue https://github.com/MichMich/MagicMirror/issues/2144
                      there is a bug in the fritzbox language files
                        requiemmg
                        Great, this fixed it. Thanks a lot!
                          carlywarly
                          @sdetweil said in Black screen after 2.13 update:
                          history of commands…
                          525 cd ./MagicMirror
                          526 git pull
                          527 sudo reboot
                          << black screen >>
                          528 sudo apt update
                          529 sudo apt upgrade
                          530 sudo reboot
                          531 cd /MagicMirror
                          532 cd node_modules/
                          533 ls
                          534 sudo rm -r electron
                          535 cd …
                          536 npm install
                          537 pm2 logs --lines=100
                          540 sudo reboot
                          << black screen >>
                          541 ifconfig
                          542 sudo reboot
                          543 history
                          Working again…??? I think it my pi possibly had a problem talking to the internet… maybe the reboot gods strike again???
                          BTW thx for the quick reply :)
                          CarlyWarly
                            @carlywarly cool, glad its working… but… sure would have been nice to see the error messages… shouldn’t black screen for a network problem…
                            but that usually means a module didn’t handle network failure and crashed and UI died
                              m0bed @carlywarly
                              @carlywarly thank you for your help. I tried all of the mentions commands bot still having a black screen.
                              on "pm2 logs --lines=100 i get this error message.
                              0|MagicMir | npm ERR! Linux 4.19.66-v7+
                              0|MagicMir | npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                              0|MagicMir | npm ERR! node v6.14.1
                              0|MagicMir | npm ERR! npm  v3.10.10
                              0|MagicMir | npm ERR! code ELIFECYCLE
                              0|MagicMir | npm ERR! magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                              0|MagicMir | npm ERR! Exit status 1
                              0|MagicMir | npm ERR! Failed at the magicmirror@2.13.0 start script 'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'.
                              0|MagicMir | npm ERR! Make sure you have the latest version of node.js and npm installed.
                              0|MagicMir | npm ERR! If you do, this is most likely a problem with the magicmirror package,
                              0|MagicMir | npm ERR! not with npm itself.
                              0|MagicMir | npm ERR! Tell the author that this fails on your system:
                              0|MagicMir | npm ERR!     DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                              0|MagicMir | npm ERR! You can get information on how to open an issue for this project with:
                              0|MagicMir | npm ERR!     npm bugs magicmirror
                              0|MagicMir | npm ERR! Or if that isn't available, you can get their info via:
                              0|MagicMir | npm ERR!     npm owner ls magicmirror
                              0|MagicMir | npm ERR! There is likely additional logging output above.
                              0|MagicMir |
                              0|MagicMir | npm ERR! Please include the following file with any support request:
                              0|MagicMir | npm ERR!     /home/pi/MagicMirror/npm-debug.log
                              0|MagicMir | Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                              0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                              Also after running “npm install” I get this messages:
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              npm WARN acorn-jsx@5.3.1 requires a peer of acorn@^6.0.0 || ^7.0.0 || ^8.0.0 but none was installed.
                              npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none was installed.
                              npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none was installed.
                              npm WARN ws@7.3.1 requires a peer of bufferutil@^4.0.1 but none was installed.
                              npm WARN ws@7.3.1 requires a peer of utf-8-validate@^5.0.2 but none was installed.
                              After a reboot the desktop starts, also some programm starts turning screen first white for 2 seconds then it turns black.
                              What can I do?
                              Daniel
                                m0bed @m0bed
                                @m0bed So, I changed my config found out that this modules dont work at the moment:
                                MMM-Homematic-Heaters
                                On the callmonitor I tried this help topic, but not working.
                                After deleting this two moduls form the config, every thing works fine, but still getting the messages from npm install.
                                Daniel
                                S spitzlbergerjS 2 Replies Last reply Reply Quote 0
                                  retroflex Project Sponsor Module Developer
                                  Found one more in module MMM-Vasttrafik-PublicTransport. I have created an issue for that:
                                  https://github.com/bureus/MMM-Vasttrafik-PublicTransport/issues/14
                                  • K Offline
                                    Klinge
                                    Found one more module too. In my case a black screen appears through the standard calendar module.
                                    my config is
                                                            header: "Termine",
        timeFormat: 'absolute',
        maximumEntries: 10,
        dateFormat: 'ddd DD MMM HH:mm',
        fullDayEventDateFormat: 'ddd DD MMM',
        showEnd: false,
        urgency: 0,
        getRelative: 0,
        symbol: "calendar-check",
        url: "https://calendar.google.com/calendar/ical/XXXXXXXXXXXXX/basic.ics"
        url: "https://calendar.google.com/calendar/ical/XXXXXXXXXXX/basic.ics"
                                    How can I create an issue for that?
                                    Or is there a problem in my config?
                                      sdetweil @Klinge
                                      @Klinge black screen
                                      look in two places,
                                      the window where you start mm,
                                      using npm start
                                      or
                                      pm2
                                      if pm2 use the command
                                      ??? is a number, default is 15
                                      also look in the developers window
                                      ctrl-shift-i and select the console tab and scroll up to see any errors
                                        sdetweil @m0bed
                                        @m0bed did u run npm install in all the module folders which have a package.json file?
                                        next time, use my upgrade script
                                        see here
                                        • K Offline
                                          Klinge
                                          @sdetweil said in Black screen after 2.13 update - tentatively resolved:
                                          When I run the pm2 logs, I got the following logs
                                          0|mm     | [2020-10-02 14:32:00.841] [LOG]    Module helper loaded: updatenotification
                                          0|mm     | [2020-10-02 14:32:00.843] [LOG]    No helper found for module: clock.
                                          0|mm     | [2020-10-02 14:32:01.602] [LOG]
                                          0|mm     | Initializing new module helper ...
                                          0|mm     | [2020-10-02 14:32:01.604] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                          0|mm     | [2020-10-02 14:32:01.620] [ERROR]
                                          0|mm     | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
                                          0|mm     | Require stack:
                                          0|mm     | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                                          0|mm     | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                                          0|mm     | - /home/pi/MagicMirror/js/app.js
                                          0|mm     | - /home/pi/MagicMirror/js/electron.js
                                          0|mm     | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                          0|mm     | -
                                          0|mm     | [2020-10-02 14:32:01.621] [LOG]    Loading module helpers ...
                                          0|mm     | [2020-10-02 14:32:01.623] [LOG]    No helper found for module: alert.
                                          0|mm     | [2020-10-02 14:32:01.627] [LOG]    Initializing new module helper ...
                                          0|mm     | [2020-10-02 14:32:01.629] [LOG]    Module helper loaded: updatenotification
                                          0|mm     | [2020-10-02 14:32:01.633] [LOG]    No helper found for module: clock.
                                          0|mm     | [2020-10-02 14:32:01.637] [LOG]    Initializing new module helper ...
                                          0|mm     | [2020-10-02 14:32:01.640] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                          0|mm     | [2020-10-02 14:32:01.649] [ERROR]
                                          0|mm     | App threw an error during load
                                          0|mm     | [2020-10-02 14:32:01.651] [ERROR]  Error: Cannot find module 'node-ical'
                                          0|mm     | -
                                          0|mm     |     at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                          0|mm     |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                          0|mm     |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                          0|mm     |     at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                          0|mm     |     at Module.require (internal/modules/cjs/loader.js:685:19)
                                          0|mm     |     at require (internal/modules/cjs/helpers.js:16:16)
                                          0|mm     |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                                          0|mm     |     at Module._compile (internal/modules/cjs/loader.js:786:30)
                                          0|mm     |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                          0|mm     |     at Module.load (internal/modules/cjs/loader.js:645:32)
                                          0|mm     | [2020-10-02 14:32:01.654] [ERROR]  Whoops! There was an uncaught exception...
                                          0|mm     | [2020-10-02 14:32:01.655] [ERROR]
                                          0|mm     | Error: Cannot find module 'node-ical'
                                          0|mm     | -
                                          0|mm     |     at Module.load (internal/modules/cjs/loader.js:645:32) {
                                          0|mm     |   code: 'MODULE_NOT_FOUND',
                                          0|mm     |   requireStack: [
                                          0|mm     |     '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                                          0|mm     |     '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                                          0|mm     |     '/home/pi/MagicMirror/js/app.js',
                                          0|mm     |     '/home/pi/MagicMirror/js/electron.js',
                                          0|mm     |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                          0|mm     |     undefined
                                          0|mm     |   ]
                                          0|mm     | }
                                          0|mm     | [2020-10-02 14:32:01.682] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          0|mm     | [2020-10-02 14:32:01.683] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          0|mm     | [2020-10-02 14:32:01.845] [LOG]
                                          0|mm     | Launching application.
                                            sdetweil @Klinge
                                            @Klinge looks like u did not run
                                            npm install
                                            after the git pull
                                            darksky looks like it will need one too
                                            or use the upgrade script with force at the end, instead of apply
                                            see here
