    Calendar iCAL not working since 2.13 update
    7 Posts 2 Posters 1.3k Views 2 Watching
      SdR
      Everything worked fine regarding my O365 caledar items via iCal, but since the update to version 2.13 it stopped working. It is not an internet connection issues as suggested and when following the link in my config file as HTTPS it downloads the .ical file… don’t really understand it as it has always worked… below the error log where it does states some issues regading ‘iana’;
      [2020-10-04 14:47:48.881] [ERROR]  (node:800) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-10-04 14:47:48.882] [ERROR]  (node:800) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-10-04 14:47:50.611] [ERROR]  Whoops! There was an uncaught exception...
      [2020-10-04 14:47:50.613] [ERROR]  TypeError: Cannot read property 'iana' of undefined
          at getIanaTZFromMS (/home/pi/MagicMirror/node_modules/node-ical/ical.js:108:30)
          at /home/pi/MagicMirror/node_modules/node-ical/ical.js:175:23
          at Object.DTSTART (/home/pi/MagicMirror/node_modules/node-ical/ical.js:457:32)
          at Object.handleObject (/home/pi/MagicMirror/node_modules/node-ical/ical.js:483:39)
          at Object.parseLines (/home/pi/MagicMirror/node_modules/node-ical/ical.js:534:18)
          at Object.parseICS (/home/pi/MagicMirror/node_modules/node-ical/ical.js:590:18)
          at Object.sync.parseICS (/home/pi/MagicMirror/node_modules/node-ical/node-ical.js:190:15)
          at Object.autodetect.parseICS (/home/pi/MagicMirror/node_modules/node-ical/node-ical.js:221:17)
          at Request._callback (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:79:22)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
      [2020-10-04 14:47:50.617] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-10-04 14:47:50.618] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-10-04 14:53:24.284] [ERROR]  Whoops! There was an uncaught exception...
      [2020-10-04 14:53:24.284] [ERROR]  TypeError: Cannot read property 'iana' of undefined
      [2020-10-04 14:53:24.285] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-10-04 14:53:24.285] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        sdetweil @SdR
        @SdR weird. I made the changes, which included changing over to node-ical
        but somehow a bunch of you are getting a downlevel version during install.
        0.12.1 is the current version. 0.12.0 has the bug u are reporting…
        so a workaround
        cd ~/MagicMirror/modules
        mv node-ical old-node-ical
        git clone https://github.com/jens-maus/node-ical.git
        cd node-ical
        npm install
        then restart MagicMirror
        I’d love to see your ics file, as the error indicates an unregistered windows timezone name
          sdetweil
          looks likes its my fault, i’ve opened a topic in the troubleshooting section
          https://forum.magicmirror.builders/topic/13770/2-13-calendar-fix-for-office-365-users
            SdR
            This did not solve the issue… mv command did not work as there was nothing to rename.
            so cloned it and ran install and it created a folder under ‘modules’ which was not there before.
            rebooted and still the same result
              sdetweil @SdR
              @SdR
              wrong folder
              sorry, my instruction in the linked topic were wrong. I have corrected them
                SdR
                I was just mentioning that :D but you already noticed…
                I have done accordingly, and now it works fine again…after a reboot…
                Tnx!
                  sdetweil @SdR
                  @SdR shouldn’t have needed the reboot.
                  if using pm2 to start mm
                  just use the command
                  pm2 restart 0
