    MMM-Trello black screen
    7 Posts 3 Posters 1.2k Views 3 Watching
    • T Offline
      trappettim
      Hi all,
      I have recently added MMM-Trello module to the MM and from that moment I get a black screen every time I try to start the MM. If I remove the module from the config file the MM starts correctly (without the Trello module obviously).
      I have started the MM in dev mode “run start dev” and this is the error:
      If I click where it says VM140:2 this is what it returns:
      Clicking instead on “translator.js:22” this is what it returns:
      APIkey, token and id list should be correct, because, correct me If I am wrong, I have tested it in my browser with this URL:
      https://api.trello.com/1/lists/MYLISTID/cards?key=MY_APYKEY&token=MY_TOKEN
      and it returns correctly all the cards in that list.
      What is weird is that not only the MMM-Trello module is not working, but I get a black screen like something crashes.
      Any thoughts??
      thanks…
        sdetweil @trappettim
        @trappettim see the 2.13 black screen topic at the top of the troubleshooting section
          did
          Bonjour
          Même problème après nouvelle installation V2.13 juste après installation module MMM-Trello .
          Le fichier config.js fonctionnait avec la version 2.12 .
          Merci d’avance
          Google Trad
          Hello
          Same problem after new V2.13 installation just after installing MMM-Trello module.
          The config.js file worked with version 2.12.
          Thank you in advance
            sdetweil @did
            @did said in MMM-Trello black screen:
            Hello
            Vous devez rechercher les fichiers de traduction dans le module et les corriger, ils ont un commentaire, ce n’est pas autorisé.
            Je ne sais pas pourquoi ce problème se produit maintenant sur 2.13
            https://forum.magicmirror.builders/topic/13774/2-13-back-screen
              did
              Merci sdetweil
              tout fonctionne .
              • T Offline
                trappettim
                Sorry sdetweil, I tried to follow your instructions but I couldnt understand which file I had to modify (I am obviously a beginner).
                Because almost every file has comments in it. do I have to delete all the comments in all the file in the module?
                Thanks a lot.
                  @trappettim see the report at the top of the troubleshooting section with the fix
