    About raspberry Pi audio input and audio output
    11 Posts 2 Posters 3.5k Views 2 Watching
    • B
      biswajeet
      Hi. I have made a change in audio input and audio output. I have set the audio input which is a 3.5mm jack microphone which is connected to the USB adapter and the output is on HDMI as my display has in-built speakers. So my main doubt is that will my changes be saved after I reboot the raspberry pi. I mean after I have done changes in audio input and audio output then will it be the same after I reboot the raspberry pi. Suppose, If the changes will not be saved after rebooting the pi, then next what steps I need to follow to make my audio input and audio output changes permanent. Please help me with this issue. Thanks in advance.
      Stay safe
        sdetweil @biswajeet
        @biswajeet what changes did u make, where?
        • B
          biswajeet
          I have made the changes in audio input and audio output. I am having a doubt that will the changes be saved even after rebooting the pi.
            sdetweil @biswajeet
            @biswajeet said in About raspberry Pi audio input and audio output:
            i meant, HOW did u do that? what FILES (things that might be persistent) did u change?
            • B
              biswajeet
              I have changed it by clicking on the top right audio icon
                sdetweil @biswajeet
                @biswajeet i ‘believe’ these ‘settings’ are persistent,…
                I would reboot and see
                • B
                  biswajeet
                  @sdetweil Very much thanks for looking after my issue. And yeah I have another question that I am adding alexa to my mirror so will it work after I reboot the pi?
                    sdetweil @biswajeet
                    @biswajeet i would hope so…
                    • B
                      biswajeet
                      Do you have any tutorials on youtube or any other websites. I mean do you make any tutorial videos on youtube or any other platform.
                      • B
                        biswajeet
                        And is there any way to watch youtube videos directly through the mirror without even casting through the mobile?
                          sdetweil @biswajeet
                          @biswajeet yes, there are modules that do that , see the 3rd party list
                          https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                          some modules (GoogleAssistant) add that to their capabilities thru extensions (Assistant2Display)
