    MMM-GoogleCast ne fonctionne plus
    2 Posts 2 Posters 459 Views 2 Watching
      did
      Bonjour
      Je n’arrive pas à faire fonctionner MMM-GoogleCast après réinstallation de mon MagicMirror, j’ai bien lu les recommandations sur le Github :ICI
      This is because this changed in the latest version of pyChromecast. If you checkout the branch 'develop', run the script, finish the configuration steps and checkout 'master' again, you will have this working.
      Another solution is to downgrade the pyChromecast version. Of course, as this is present in the develop branch, this will be fixed in the future, when I finish working in the upcoming version.
      Je ne sais pas ou est la version développement ou vers quel version il faut “downgrade” .
      Merci d’avance pour votre aide
      ps : ce forum est très cool .Bravo
      Hello
      I cannot get MMM-GoogleCast to work after reinstalling my MagicMirror, I have read the recommendations on the Github: [HERE] (https://github.com/ferferga/MMM-GoogleCast/issues/21)
      I don’t know where the development version is or which version to “downgrade” to.
      thank you in advance for your help
      ps: this forum is very cool. Bravo
      • lavolp3L Offline
        lavolp3 Module Developer @did
        @did said in MMM-GoogleCast ne fonctionne plus:
        and it even magically edits your posts :-)
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
