    trouble with MMM-GoogleTrafficTimes
    traffic
    39 Posts 3 Posters 9.2k Views 3 Watching
    • L Offline
      laschalkh @sdetweil
      Hi Sam,
      yea, I understand this would be pulling up the developer interface from the browser. But it’s not coming up. Is there another way to see those errors?
      Thanks,
      Kevin
        sdetweil @laschalkh
        @laschalkh you can restart MagicMirror by using
        npm start dev
        if you use.pm2, then stop that instance
        pm2 stop all
        • L Offline
          laschalkh @sdetweil
          Hi Sam, when I try to run npm start dev I get an error. Which directory does it expect to be run from? I tried in a few locations and nothing worked.
          Thanks,
          Kevin
            sdetweil @laschalkh
            @laschalkh always in the MagicMirror folder
            • L Offline
              laschalkh
              ok, tried that and got the error:
              Failed at the magicmirror@2.13.0 start script.
                sdetweil @laschalkh
                @laschalkh there has got to be more than 1 line
                • L Offline
                  laschalkh
                  ok, found that it created a log file for that process
                  1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
                  2 info using npm@6.9.0
                  3 info using node@v10.16.0
                  4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                  5 info lifecycle magicmirror@2.13.0~prestart: magicmirror@2.13.0
                  6 info lifecycle magicmirror@2.13.0~start: magicmirror@2.13.0
                  7 verbose lifecycle magicmirror@2.13.0~start: unsafe-perm in lifecycle true
                  8 verbose lifecycle magicmirror@2.13.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/
                  node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bi
                  n:/usr/local/games:/usr/games
                  9 verbose lifecycle magicmirror@2.13.0~start: CWD: /home/pi/MagicMirror
                  10 silly lifecycle magicmirror@2.13.0~start: Args: [ ‘-c’,
                  10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “dev”’ ]
                  11 info lifecycle magicmirror@2.13.0~start: Failed to exec start script
                  12 verbose stack Error: magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/ele ctron.js "dev"
                  12 verbose stack spawn ENOENT
                  12 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/li
                  b/spawn.js:48:18)
                  12 verbose stack at ChildProcess.emit (events.js:198:13)
                  12 verbose stack at maybeClose (internal/child_process.js:982:16)
                  12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                  13 verbose pkgid magicmirror@2.13.0
                  14 verbose cwd /home/pi/MagicMirror
                  15 verbose Linux 4.19.97+
                  16 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
                  17 verbose node v10.16.0
                  18 verbose npm v6.9.0
                  19 error file sh
                  20 error code ELIFECYCLE
                  21 error errno ENOENT
                  22 error syscall spawn
                  23 error magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                  23 error spawn ENOENT
                  24 error Failed at the magicmirror@2.13.0 start script.
                  24 error This is probably not a problem with npm. There is likely additional logging output above.
                  25 verbose exit [ 1, true ]
                    sdetweil @laschalkh
                    @laschalkh is this a pi 0?
                    • L Offline
                      laschalkh
                      yup, zero w
                        sdetweil @laschalkh
                        @laschalkh ok, lots of setup, or, remove that mm folder and run my install script
                        see the instructions here
                        • 4 / 4
