    trouble with MMM-GoogleTrafficTimes
    traffic
    39 Posts 3 Posters 9.2k Views 3 Watching
      sdetweil @laschalkh
      @laschalkh open the developers window
      ctrl-shift-i on the mirror keyboard, select the console tab and scroll up to see any errors
      • L Offline
        laschalkh @sdetweil
        Hi Sam, I tried that key sequence from the console. I’m not getting the interface.
        Thanks,
        Kevin
          sdetweil @laschalkh
          @laschalkh all at the same time
          • L Offline
            laschalkh @sdetweil
            Hi Sam,
            yea, I understand this would be pulling up the developer interface from the browser. But it’s not coming up. Is there another way to see those errors?
            Thanks,
            Kevin
              sdetweil @laschalkh
              @laschalkh you can restart MagicMirror by using
              npm start dev
              if you use.pm2, then stop that instance
              pm2 stop all
              • L Offline
                laschalkh @sdetweil
                Hi Sam, when I try to run npm start dev I get an error. Which directory does it expect to be run from? I tried in a few locations and nothing worked.
                Thanks,
                Kevin
                  sdetweil @laschalkh
                  @laschalkh always in the MagicMirror folder
                  • L Offline
                    laschalkh
                    ok, tried that and got the error:
                    Failed at the magicmirror@2.13.0 start script.
                      sdetweil @laschalkh
                      @laschalkh there has got to be more than 1 line
                      • L Offline
                        laschalkh
                        ok, found that it created a log file for that process
                        1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
                        2 info using npm@6.9.0
                        3 info using node@v10.16.0
                        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                        5 info lifecycle magicmirror@2.13.0~prestart: magicmirror@2.13.0
                        6 info lifecycle magicmirror@2.13.0~start: magicmirror@2.13.0
                        7 verbose lifecycle magicmirror@2.13.0~start: unsafe-perm in lifecycle true
                        8 verbose lifecycle magicmirror@2.13.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/
                        node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bi
                        n:/usr/local/games:/usr/games
                        9 verbose lifecycle magicmirror@2.13.0~start: CWD: /home/pi/MagicMirror
                        10 silly lifecycle magicmirror@2.13.0~start: Args: [ ‘-c’,
                        10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “dev”’ ]
                        11 info lifecycle magicmirror@2.13.0~start: Failed to exec start script
                        12 verbose stack Error: magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/ele ctron.js "dev"
                        12 verbose stack spawn ENOENT
                        12 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/li
                        b/spawn.js:48:18)
                        12 verbose stack at ChildProcess.emit (events.js:198:13)
                        12 verbose stack at maybeClose (internal/child_process.js:982:16)
                        12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                        13 verbose pkgid magicmirror@2.13.0
                        14 verbose cwd /home/pi/MagicMirror
                        15 verbose Linux 4.19.97+
                        16 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
                        17 verbose node v10.16.0
                        18 verbose npm v6.9.0
                        19 error file sh
                        20 error code ELIFECYCLE
                        21 error errno ENOENT
                        22 error syscall spawn
                        23 error magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                        23 error spawn ENOENT
                        24 error Failed at the magicmirror@2.13.0 start script.
                        24 error This is probably not a problem with npm. There is likely additional logging output above.
                        25 verbose exit [ 1, true ]
                        • 1 / 4
