    trouble with MMM-GoogleTrafficTimes
    traffic
    39 Posts 3 Posters 11.8k Views 3 Watching
      sdetweil @laschalkh
      @laschalkh there has got to be more than 1 line
      • L
        laschalkh
        ok, found that it created a log file for that process
        1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
        2 info using npm@6.9.0
        3 info using node@v10.16.0
        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
        5 info lifecycle magicmirror@2.13.0~prestart: magicmirror@2.13.0
        6 info lifecycle magicmirror@2.13.0~start: magicmirror@2.13.0
        7 verbose lifecycle magicmirror@2.13.0~start: unsafe-perm in lifecycle true
        8 verbose lifecycle magicmirror@2.13.0~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/
        node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bi
        n:/usr/local/games:/usr/games
        9 verbose lifecycle magicmirror@2.13.0~start: CWD: /home/pi/MagicMirror
        10 silly lifecycle magicmirror@2.13.0~start: Args: [ ‘-c’,
        10 silly lifecycle ‘DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “dev”’ ]
        11 info lifecycle magicmirror@2.13.0~start: Failed to exec start script
        12 verbose stack Error: magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/ele ctron.js "dev"
        12 verbose stack spawn ENOENT
        12 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/li
        b/spawn.js:48:18)
        12 verbose stack at ChildProcess.emit (events.js:198:13)
        12 verbose stack at maybeClose (internal/child_process.js:982:16)
        12 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        13 verbose pkgid magicmirror@2.13.0
        14 verbose cwd /home/pi/MagicMirror
        15 verbose Linux 4.19.97+
        16 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
        17 verbose node v10.16.0
        18 verbose npm v6.9.0
        19 error file sh
        20 error code ELIFECYCLE
        21 error errno ENOENT
        22 error syscall spawn
        23 error magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
        23 error spawn ENOENT
        24 error Failed at the magicmirror@2.13.0 start script.
        24 error This is probably not a problem with npm. There is likely additional logging output above.
        25 verbose exit [ 1, true ]
          sdetweil @laschalkh
          @laschalkh is this a pi 0?
          • L
            laschalkh
            yup, zero w
              sdetweil @laschalkh
              @laschalkh ok, lots of setup, or, remove that mm folder and run my install script
              see the instructions here
              • L
                laschalkh
                ok, the entire MagicMirror directory or just the modules?
                  sdetweil @laschalkh
                  @laschalkh the entire, rename it
                  the problem is there is no electron browser for armv6l (pi0/1) devices anymore, so you have to run split mode, server with chromium over the top
                  the script does all the work, so it looks like normal
                  • L
                    laschalkh
                    Hi Sam,
                    I went through and rebuilt my pi and then ran your install script. It says it’s installed and when I do a pm status I see the MagicMirror is online. I don’t see the mirror tho. Is there something else I need to do for that to come up on boot?
                    Thanks,
                    Kevin
                      sdetweil @laschalkh
                      @laschalkh pm2 logs – lines=100
                      in the status it shows how many times its been restarted
                      │ id  │ name            │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                      │ 1   │ MagicMirror     │ default     │ 2.13.0… │ fork    │ N/A      │ 0      │ 1    │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
                      that field next to uptime with the circle and arrow
                      pm2 stop 0 to stop it while u debug
                      • L
                        laschalkh
                        it looks ok, not complaining. Am I just missing the front end?
                        /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                        0|MagicMir |
                        0|MagicMir | > magicmirror@2.13.0 start /home/pi/MagicMirror
                        0|MagicMir | > ./run-start.sh $1
                        0|MagicMir |
                        0|MagicMir | [2020-10-15 17:13:43.975] [LOG] Starting MagicMirror: v2.13.0
                        0|MagicMir | [2020-10-15 17:13:44.068] [LOG] Loading config …
                        0|MagicMir | [2020-10-15 17:13:44.123] [LOG] Loading module helpers …
                        0|MagicMir | [2020-10-15 17:13:44.147] [LOG] No helper found for module: alert.
                        0|MagicMir | [2020-10-15 17:13:44.569] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-10-15 17:13:44.578] [LOG] Module helper loaded: updatenotification
                        0|MagicMir | [2020-10-15 17:13:44.590] [LOG] No helper found for module: clock.
                        0|MagicMir | [2020-10-15 17:13:48.255] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-10-15 17:13:48.263] [LOG] Module helper loaded: calendar
                        0|MagicMir | [2020-10-15 17:13:48.267] [LOG] No helper found for module: compliments.
                        0|MagicMir | [2020-10-15 17:13:48.270] [LOG] No helper found for module: currentweather.
                        0|MagicMir | [2020-10-15 17:13:48.283] [LOG] No helper found for module: weatherforecast.
                        0|MagicMir | [2020-10-15 17:13:48.482] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-10-15 17:13:48.490] [LOG] Module helper loaded: newsfeed
                        0|MagicMir | [2020-10-15 17:13:48.501] [LOG] All module helpers loaded.
                        0|MagicMir | [2020-10-15 17:13:49.375] [LOG] Starting server on port 8080 …
                        0|MagicMir | [2020-10-15 17:13:49.542] [LOG] Server started …
                        0|MagicMir | [2020-10-15 17:13:49.563] [LOG] Connecting socket for: updatenotification
                        0|MagicMir | [2020-10-15 17:13:49.569] [LOG] Connecting socket for: calendar
                        0|MagicMir | [2020-10-15 17:13:49.593] [LOG] Starting node helper for: calendar
                        0|MagicMir | [2020-10-15 17:13:49.601] [LOG] Connecting socket for: newsfeed
                        0|MagicMir | [2020-10-15 17:13:49.615] [LOG] Starting node helper for: newsfeed
                        0|MagicMir | [2020-10-15 17:13:49.617] [LOG] Sockets connected & modules started …
                        0|MagicMir | [2020-10-15 17:13:49.621] [LOG]
                        0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
                        0|MagicMir | [2020-10-15 17:14:28.183] [LOG] [SIGINT] Received. Shutting down server…
                        0|MagicMir | [2020-10-15 17:14:28.210] [LOG] Stopping module helper: updatenotification
                        0|MagicMir | [2020-10-15 17:14:28.218] [LOG] Stopping module helper: calendar
                        0|MagicMir | [2020-10-15 17:14:28.221] [LOG] Stopping module helper: newsfeed
                        0|MagicMir |
                        0|MagicMir |
                        0|MagicMir | [2020-10-15 17:14:40.950] [LOG] Starting MagicMirror: v2.13.0
                        0|MagicMir | [2020-10-15 17:14:41.041] [LOG] Loading config …
                        0|MagicMir | [2020-10-15 17:14:41.092] [LOG] Loading module helpers …
                        0|MagicMir | [2020-10-15 17:14:41.115] [LOG] No helper found for module: alert.
                        0|MagicMir | [2020-10-15 17:14:41.477] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-10-15 17:14:41.485] [LOG] Module helper loaded: updatenotification
                        0|MagicMir | [2020-10-15 17:14:41.489] [LOG] No helper found for module: clock.
                        0|MagicMir | [2020-10-15 17:14:45.097] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-10-15 17:14:45.104] [LOG] Module helper loaded: calendar
                        0|MagicMir | [2020-10-15 17:14:45.107] [LOG] No helper found for module: compliments.
                        0|MagicMir | [2020-10-15 17:14:45.110] [LOG] No helper found for module: currentweather.
                        0|MagicMir | [2020-10-15 17:14:45.123] [LOG] No helper found for module: weatherforecast.
                        0|MagicMir | [2020-10-15 17:14:45.302] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-10-15 17:14:45.309] [LOG] Module helper loaded: newsfeed
                        0|MagicMir | [2020-10-15 17:14:45.311] [LOG] All module helpers loaded.
                        0|MagicMir | [2020-10-15 17:14:46.068] [LOG] Starting server on port 8080 …
                        0|MagicMir | [2020-10-15 17:14:46.244] [LOG] Server started …
                        0|MagicMir | [2020-10-15 17:14:46.273] [LOG] Connecting socket for: updatenotification
                        0|MagicMir | [2020-10-15 17:14:46.292] [LOG] Connecting socket for: calendar
                        0|MagicMir | [2020-10-15 17:14:46.295] [LOG] Starting node helper for: calendar
                        0|MagicMir | [2020-10-15 17:14:46.299] [LOG] Connecting socket for: newsfeed
                        0|MagicMir | [2020-10-15 17:14:46.323] [LOG] Starting node helper for: newsfeed
                        0|MagicMir | [2020-10-15 17:14:46.330] [LOG] Sockets connected & modules started …
                        0|MagicMir | [2020-10-15 17:14:46.343] [LOG]
                        0|MagicMir |
                        0|MagicMir |
                        0|MagicMir | [2020-10-15 17:17:29.023] [LOG] Starting MagicMirror: v2.13.0
                        0|MagicMir | [2020-10-15 17:17:29.117] [LOG] Loading config …
                        0|MagicMir | [2020-10-15 17:17:29.195] [LOG] Loading module helpers …
                        0|MagicMir | [2020-10-15 17:17:29.218] [LOG] No helper found for module: alert.
                        0|MagicMir | [2020-10-15 17:17:29.614] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-10-15 17:17:29.623] [LOG] Module helper loaded: updatenotification
                        0|MagicMir | [2020-10-15 17:17:29.635] [LOG] No helper found for module: clock.
                        0|MagicMir | [2020-10-15 17:17:33.776] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-10-15 17:17:33.784] [LOG] Module helper loaded: calendar
                        0|MagicMir | [2020-10-15 17:17:33.787] [LOG] No helper found for module: compliments.
                        0|MagicMir | [2020-10-15 17:17:33.799] [LOG] No helper found for module: currentweather.
                        0|MagicMir | [2020-10-15 17:17:33.802] [LOG] No helper found for module: weatherforecast.
                        0|MagicMir | [2020-10-15 17:17:34.029] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-10-15 17:17:34.037] [LOG] Module helper loaded: newsfeed
                        0|MagicMir | [2020-10-15 17:17:34.039] [LOG] All module helpers loaded.
                        0|MagicMir | [2020-10-15 17:17:34.984] [LOG] Starting server on port 8080 …
                        0|MagicMir | [2020-10-15 17:17:35.147] [LOG] Server started …
                        0|MagicMir | [2020-10-15 17:17:35.176] [LOG] Connecting socket for: updatenotification
                        0|MagicMir | [2020-10-15 17:17:35.200] [LOG] Connecting socket for: calendar
                        0|MagicMir | [2020-10-15 17:17:35.203] [LOG] Starting node helper for: calendar
                        0|MagicMir | [2020-10-15 17:17:35.207] [LOG] Connecting socket for: newsfeed
                        0|MagicMir | [2020-10-15 17:17:35.235] [LOG] Starting node helper for: newsfeed
                        0|MagicMir | [2020-10-15 17:17:35.246] [LOG] Sockets connected & modules started …
                        0|MagicMir | [2020-10-15 17:17:35.249] [LOG]
                        0|MagicMir | [2020-10-15 17:26:21.269] [LOG] [SIGINT] Received. Shutting down server…
                        0|MagicMir | [2020-10-15 17:26:21.297] [LOG] Stopping module helper: updatenotification
                        0|MagicMir | [2020-10-15 17:26:21.309] [LOG] Stopping module helper: calendar
                        0|MagicMir | [2020-10-15 17:26:21.311] [LOG] Stopping module helper: newsfeed
                          sdetweil @laschalkh
                          @laschalkh ok do
                          ls -laF run-start.sh
                          uname -a
                          pgrep Xorg
                          which chromium-browser
                          sorry, for adding late
                          L 1 Reply Last reply
                          • L
                            laschalkh @sdetweil
                            np, I appreciate all the help. Here are the results:
                            pi@raspberrypi:~ $ cd MagicMirror/
                            pi@raspberrypi:~/MagicMirror $ ls -laF run-start.sh
                            -rwxr-xr-x 1 pi pi 2980 Oct 15 16:56 run-start.sh*
                            pi@raspberrypi:~/MagicMirror $ uname -a
                            Linux raspberrypi 5.4.51+ #1333 Mon Aug 10 16:38:02 BST 2020 armv6l GNU/Linux
                            pi@raspberrypi:~/MagicMirror $ pgrep Xorg
                            pi@raspberrypi:~/MagicMirror $ which chromium-browser
                              sdetweil @laschalkh
                              @laschalkh said in trouble with MMM-GoogleTrafficTimes:
                              pgrep Xorg
                              are both empty
                              which means you don’t have the graphical desktop running., looks like you are in cli mode
                              u MUST have the desktop to run MM…, browser requires graphics.
                              reflash the sd card with the full desktop image of buster
                              top left here
                              https://www.raspberrypi.org/downloads/raspberry-pi-os/
                              Raspberry Pi OS (32-bit) with desktop and recommended software
                              • L
                                laschalkh
                                ok, I’ll try it, but I may need to grab another pi. Not sure the zero can handle the full version
                                  sdetweil @laschalkh
                                  @laschalkh it will work, depends on what u want to do… i have one running all day every day, default modules
                                  • L
                                    laschalkh @sdetweil
                                    cool, I just want a couple modules so hopefully won’t b a problem. It’s flashing now so I’ll reach out after it’s running and installed
                                    • L
                                      laschalkh
                                      Hi Sam,
                                      ok, got it all running and it is working. Your script works very well. I tried adding MMM-GoogleMapsTraffic as well and that seems to kill the mirror. It says it can’t find the config file. As long as I leave that out, it’s working.
                                        sdetweil @laschalkh
                                        @laschalkh u might want my version of Googlemapstraffic, as the original is broken
                                        https://github.com/sdetweil/MMM-GoogleMapsTraffic
                                        • L
                                          laschalkh
                                          yea, that’s the one I’m trying. I just tried that module only and it’s not working. I ran the install again and it is warning about grunt styles not being installed. Seems like it’s missing parts.
                                            sdetweil @laschalkh
                                            @laschalkh thats noise
                                            you did the git clone
                                            cd
                                            and then npm install
                                            right?
                                            so, whats your config section look like… no one has had trouble installing it, it was a run problem I fixed…
