    trouble with MMM-GoogleTrafficTimes
    traffic
    39 Posts 3 Posters 11.8k Views 3 Watching
    • L
      laschalkh
      Hi Sam,
      I went through and rebuilt my pi and then ran your install script. It says it’s installed and when I do a pm status I see the MagicMirror is online. I don’t see the mirror tho. Is there something else I need to do for that to come up on boot?
      Thanks,
      Kevin
        sdetweil @laschalkh
        @laschalkh pm2 logs – lines=100
        in the status it shows how many times its been restarted
        │ id  │ name            │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
        │ 1   │ MagicMirror     │ default     │ 2.13.0… │ fork    │ N/A      │ 0      │ 1    │ stopped   │ 0%       │ 0b       │ sam      │ disabled │
        that field next to uptime with the circle and arrow
        pm2 stop 0 to stop it while u debug
        • L
          laschalkh
          it looks ok, not complaining. Am I just missing the front end?
          /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
          0|MagicMir |
          0|MagicMir | > magicmirror@2.13.0 start /home/pi/MagicMirror
          0|MagicMir | > ./run-start.sh $1
          0|MagicMir |
          0|MagicMir | [2020-10-15 17:13:43.975] [LOG] Starting MagicMirror: v2.13.0
          0|MagicMir | [2020-10-15 17:13:44.068] [LOG] Loading config …
          0|MagicMir | [2020-10-15 17:13:44.123] [LOG] Loading module helpers …
          0|MagicMir | [2020-10-15 17:13:44.147] [LOG] No helper found for module: alert.
          0|MagicMir | [2020-10-15 17:13:44.569] [LOG] Initializing new module helper …
          0|MagicMir | [2020-10-15 17:13:44.578] [LOG] Module helper loaded: updatenotification
          0|MagicMir | [2020-10-15 17:13:44.590] [LOG] No helper found for module: clock.
          0|MagicMir | [2020-10-15 17:13:48.255] [LOG] Initializing new module helper …
          0|MagicMir | [2020-10-15 17:13:48.263] [LOG] Module helper loaded: calendar
          0|MagicMir | [2020-10-15 17:13:48.267] [LOG] No helper found for module: compliments.
          0|MagicMir | [2020-10-15 17:13:48.270] [LOG] No helper found for module: currentweather.
          0|MagicMir | [2020-10-15 17:13:48.283] [LOG] No helper found for module: weatherforecast.
          0|MagicMir | [2020-10-15 17:13:48.482] [LOG] Initializing new module helper …
          0|MagicMir | [2020-10-15 17:13:48.490] [LOG] Module helper loaded: newsfeed
          0|MagicMir | [2020-10-15 17:13:48.501] [LOG] All module helpers loaded.
          0|MagicMir | [2020-10-15 17:13:49.375] [LOG] Starting server on port 8080 …
          0|MagicMir | [2020-10-15 17:13:49.542] [LOG] Server started …
          0|MagicMir | [2020-10-15 17:13:49.563] [LOG] Connecting socket for: updatenotification
          0|MagicMir | [2020-10-15 17:13:49.569] [LOG] Connecting socket for: calendar
          0|MagicMir | [2020-10-15 17:13:49.593] [LOG] Starting node helper for: calendar
          0|MagicMir | [2020-10-15 17:13:49.601] [LOG] Connecting socket for: newsfeed
          0|MagicMir | [2020-10-15 17:13:49.615] [LOG] Starting node helper for: newsfeed
          0|MagicMir | [2020-10-15 17:13:49.617] [LOG] Sockets connected & modules started …
          0|MagicMir | [2020-10-15 17:13:49.621] [LOG]
          0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
          0|MagicMir | [2020-10-15 17:14:28.183] [LOG] [SIGINT] Received. Shutting down server…
          0|MagicMir | [2020-10-15 17:14:28.210] [LOG] Stopping module helper: updatenotification
          0|MagicMir | [2020-10-15 17:14:28.218] [LOG] Stopping module helper: calendar
          0|MagicMir | [2020-10-15 17:14:28.221] [LOG] Stopping module helper: newsfeed
          0|MagicMir |
          0|MagicMir |
          0|MagicMir | [2020-10-15 17:14:40.950] [LOG] Starting MagicMirror: v2.13.0
          0|MagicMir | [2020-10-15 17:14:41.041] [LOG] Loading config …
          0|MagicMir | [2020-10-15 17:14:41.092] [LOG] Loading module helpers …
          0|MagicMir | [2020-10-15 17:14:41.115] [LOG] No helper found for module: alert.
          0|MagicMir | [2020-10-15 17:14:41.477] [LOG] Initializing new module helper …
          0|MagicMir | [2020-10-15 17:14:41.485] [LOG] Module helper loaded: updatenotification
          0|MagicMir | [2020-10-15 17:14:41.489] [LOG] No helper found for module: clock.
          0|MagicMir | [2020-10-15 17:14:45.097] [LOG] Initializing new module helper …
          0|MagicMir | [2020-10-15 17:14:45.104] [LOG] Module helper loaded: calendar
          0|MagicMir | [2020-10-15 17:14:45.107] [LOG] No helper found for module: compliments.
          0|MagicMir | [2020-10-15 17:14:45.110] [LOG] No helper found for module: currentweather.
          0|MagicMir | [2020-10-15 17:14:45.123] [LOG] No helper found for module: weatherforecast.
          0|MagicMir | [2020-10-15 17:14:45.302] [LOG] Initializing new module helper …
          0|MagicMir | [2020-10-15 17:14:45.309] [LOG] Module helper loaded: newsfeed
          0|MagicMir | [2020-10-15 17:14:45.311] [LOG] All module helpers loaded.
          0|MagicMir | [2020-10-15 17:14:46.068] [LOG] Starting server on port 8080 …
          0|MagicMir | [2020-10-15 17:14:46.244] [LOG] Server started …
          0|MagicMir | [2020-10-15 17:14:46.273] [LOG] Connecting socket for: updatenotification
          0|MagicMir | [2020-10-15 17:14:46.292] [LOG] Connecting socket for: calendar
          0|MagicMir | [2020-10-15 17:14:46.295] [LOG] Starting node helper for: calendar
          0|MagicMir | [2020-10-15 17:14:46.299] [LOG] Connecting socket for: newsfeed
          0|MagicMir | [2020-10-15 17:14:46.323] [LOG] Starting node helper for: newsfeed
          0|MagicMir | [2020-10-15 17:14:46.330] [LOG] Sockets connected & modules started …
          0|MagicMir | [2020-10-15 17:14:46.343] [LOG]
          0|MagicMir |
          0|MagicMir |
          0|MagicMir | [2020-10-15 17:17:29.023] [LOG] Starting MagicMirror: v2.13.0
          0|MagicMir | [2020-10-15 17:17:29.117] [LOG] Loading config …
          0|MagicMir | [2020-10-15 17:17:29.195] [LOG] Loading module helpers …
          0|MagicMir | [2020-10-15 17:17:29.218] [LOG] No helper found for module: alert.
          0|MagicMir | [2020-10-15 17:17:29.614] [LOG] Initializing new module helper …
          0|MagicMir | [2020-10-15 17:17:29.623] [LOG] Module helper loaded: updatenotification
          0|MagicMir | [2020-10-15 17:17:29.635] [LOG] No helper found for module: clock.
          0|MagicMir | [2020-10-15 17:17:33.776] [LOG] Initializing new module helper …
          0|MagicMir | [2020-10-15 17:17:33.784] [LOG] Module helper loaded: calendar
          0|MagicMir | [2020-10-15 17:17:33.787] [LOG] No helper found for module: compliments.
          0|MagicMir | [2020-10-15 17:17:33.799] [LOG] No helper found for module: currentweather.
          0|MagicMir | [2020-10-15 17:17:33.802] [LOG] No helper found for module: weatherforecast.
          0|MagicMir | [2020-10-15 17:17:34.029] [LOG] Initializing new module helper …
          0|MagicMir | [2020-10-15 17:17:34.037] [LOG] Module helper loaded: newsfeed
          0|MagicMir | [2020-10-15 17:17:34.039] [LOG] All module helpers loaded.
          0|MagicMir | [2020-10-15 17:17:34.984] [LOG] Starting server on port 8080 …
          0|MagicMir | [2020-10-15 17:17:35.147] [LOG] Server started …
          0|MagicMir | [2020-10-15 17:17:35.176] [LOG] Connecting socket for: updatenotification
          0|MagicMir | [2020-10-15 17:17:35.200] [LOG] Connecting socket for: calendar
          0|MagicMir | [2020-10-15 17:17:35.203] [LOG] Starting node helper for: calendar
          0|MagicMir | [2020-10-15 17:17:35.207] [LOG] Connecting socket for: newsfeed
          0|MagicMir | [2020-10-15 17:17:35.235] [LOG] Starting node helper for: newsfeed
          0|MagicMir | [2020-10-15 17:17:35.246] [LOG] Sockets connected & modules started …
          0|MagicMir | [2020-10-15 17:17:35.249] [LOG]
          0|MagicMir | [2020-10-15 17:26:21.269] [LOG] [SIGINT] Received. Shutting down server…
          0|MagicMir | [2020-10-15 17:26:21.297] [LOG] Stopping module helper: updatenotification
          0|MagicMir | [2020-10-15 17:26:21.309] [LOG] Stopping module helper: calendar
          0|MagicMir | [2020-10-15 17:26:21.311] [LOG] Stopping module helper: newsfeed
            sdetweil @laschalkh
            @laschalkh ok do
            ls -laF run-start.sh
            uname -a
            pgrep Xorg
            which chromium-browser
            sorry, for adding late
            L 1 Reply Last reply
            • L
              laschalkh @sdetweil
              np, I appreciate all the help. Here are the results:
              pi@raspberrypi:~ $ cd MagicMirror/
              pi@raspberrypi:~/MagicMirror $ ls -laF run-start.sh
              -rwxr-xr-x 1 pi pi 2980 Oct 15 16:56 run-start.sh*
              pi@raspberrypi:~/MagicMirror $ uname -a
              Linux raspberrypi 5.4.51+ #1333 Mon Aug 10 16:38:02 BST 2020 armv6l GNU/Linux
              pi@raspberrypi:~/MagicMirror $ pgrep Xorg
              pi@raspberrypi:~/MagicMirror $ which chromium-browser
                sdetweil @laschalkh
                @laschalkh said in trouble with MMM-GoogleTrafficTimes:
                pgrep Xorg
                are both empty
                which means you don’t have the graphical desktop running., looks like you are in cli mode
                u MUST have the desktop to run MM…, browser requires graphics.
                reflash the sd card with the full desktop image of buster
                top left here
                https://www.raspberrypi.org/downloads/raspberry-pi-os/
                Raspberry Pi OS (32-bit) with desktop and recommended software
                • L
                  laschalkh
                  ok, I’ll try it, but I may need to grab another pi. Not sure the zero can handle the full version
                    sdetweil @laschalkh
                    @laschalkh it will work, depends on what u want to do… i have one running all day every day, default modules
                    • L
                      laschalkh @sdetweil
                      cool, I just want a couple modules so hopefully won’t b a problem. It’s flashing now so I’ll reach out after it’s running and installed
                      • L
                        laschalkh
                        Hi Sam,
                        ok, got it all running and it is working. Your script works very well. I tried adding MMM-GoogleMapsTraffic as well and that seems to kill the mirror. It says it can’t find the config file. As long as I leave that out, it’s working.
                          sdetweil @laschalkh
                          @laschalkh u might want my version of Googlemapstraffic, as the original is broken
                          https://github.com/sdetweil/MMM-GoogleMapsTraffic
                          • L
                            laschalkh
                            yea, that’s the one I’m trying. I just tried that module only and it’s not working. I ran the install again and it is warning about grunt styles not being installed. Seems like it’s missing parts.
                              sdetweil @laschalkh
                              @laschalkh thats noise
                              you did the git clone
                              cd
                              and then npm install
                              right?
                              so, whats your config section look like… no one has had trouble installing it, it was a run problem I fixed…
                              • L
                                laschalkh
                                yup, went through and did the install and such
                                                        module: 'MMM-GoogleMapsTraffic',
                                                        position: 'bottom_left',
        key: '< my key>',
        lat: < my lat>,
        lng: < my long>,
        height: '300px',
        width: '300px'
        styledMapType: "transparent",
        disableDefaultUI: true,
        backgroundColor: 'hsla(0, 0%, 0%, 0)',
        markers: [
        lat: <my lat>,
        lng: <my long>,
        fillColor: '#9966ff'
                                  sdetweil @laschalkh
                                  @laschalkh how are u specifying lat/lng (in both places, right)
                                  like this (good)
                                  lat:30.4623841,
                                  or this (bad)
                                  lat:"30.4623841",
                                  • L
                                    laschalkh
                                    yup, not quoted
                                      sdetweil @laschalkh
                                      @laschalkh ok, so what is the error?
                                      • L
                                        laschalkh
                                        ./run-start.sh $1 “dev”
                                        [2020-10-16 11:15:36.565] [LOG] Starting MagicMirror: v2.13.0
                                        [2020-10-16 11:15:36.775] [LOG] Loading config …
                                        [2020-10-16 11:15:36.823] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:73
                                        styledMapType: “transparent”,
                                        SyntaxError: Unexpected identifier
                                        at Module._compile (internal/modules/cjs/loader.js:723:23)
                                        at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                                        at Module.require (internal/modules/cjs/loader.js:692:17)
                                        at require (internal/modules/cjs/helpers.js:25:18)
                                        at loadConfig (/home/pi/MagicMirror/js/app.js:70:12)
                                        at App.start (/home/pi/MagicMirror/js/app.js:217:3)
                                        at Object. (/home/pi/MagicMirror/serveronly/index.js:4:5)
                                        [2020-10-16 11:15:36.862] [LOG] Loading module helpers …
                                        [2020-10-16 11:15:37.496] [LOG] Initializing new module helper …
                                        [2020-10-16 11:15:37.507] [LOG] Module helper loaded: updatenotification
                                        [2020-10-16 11:15:37.525] [LOG] No helper found for module: helloworld.
                                        [2020-10-16 11:15:37.531] [LOG] All module helpers loaded.
                                        [2020-10-16 11:15:39.089] [LOG] Starting server on port 8080 …
                                        [2020-10-16 11:15:39.324] [LOG] Server started …
                                        [2020-10-16 11:15:39.335] [LOG] Connecting socket for: updatenotification
                                        [2020-10-16 11:15:39.346] [LOG] Sockets connected & modules started …
                                        [2020-10-16 11:15:39.354] [LOG]
                                          sdetweil @laschalkh
                                          rule number 1 debugging syntax errors:
                                          IF you see ’ Unexpected identifier’, find the line number
                                          config.js:73
                                          back up one line (72), and check for the missing , at the end
        width: '300px'                                   <  ---
                                          • L
                                            laschalkh
                                            I see it, damn, I’ve stared at that for way too long, rebooting…
