    trouble with MMM-GoogleTrafficTimes
    traffic
    39 Posts 3 Posters 11.2k Views 3 Watching
    • L Offline
      laschalkh
      ok, I’ll try it, but I may need to grab another pi. Not sure the zero can handle the full version
        sdetweil @laschalkh
        @laschalkh it will work, depends on what u want to do… i have one running all day every day, default modules
        • L Offline
          laschalkh @sdetweil
          cool, I just want a couple modules so hopefully won’t b a problem. It’s flashing now so I’ll reach out after it’s running and installed
          • L Offline
            laschalkh
            Hi Sam,
            ok, got it all running and it is working. Your script works very well. I tried adding MMM-GoogleMapsTraffic as well and that seems to kill the mirror. It says it can’t find the config file. As long as I leave that out, it’s working.
              sdetweil @laschalkh
              @laschalkh u might want my version of Googlemapstraffic, as the original is broken
              https://github.com/sdetweil/MMM-GoogleMapsTraffic
              • L Offline
                laschalkh
                yea, that’s the one I’m trying. I just tried that module only and it’s not working. I ran the install again and it is warning about grunt styles not being installed. Seems like it’s missing parts.
                  sdetweil @laschalkh
                  @laschalkh thats noise
                  you did the git clone
                  cd
                  and then npm install
                  right?
                  so, whats your config section look like… no one has had trouble installing it, it was a run problem I fixed…
                  • L Offline
                    laschalkh
                    yup, went through and did the install and such
                                            module: 'MMM-GoogleMapsTraffic',
                                            position: 'bottom_left',
                                                    key: '< my key>',
                                                    lat: < my lat>,
                                                    lng: < my long>,
                                                    height: '300px',
                                                    width: '300px'
                                                    styledMapType: "transparent",
                                                    disableDefaultUI: true,
                                                    backgroundColor: 'hsla(0, 0%, 0%, 0)',
                                                    markers: [
        lat: <my lat>,
        lng: <my long>,
        fillColor: '#9966ff'
                      sdetweil @laschalkh
                      @laschalkh how are u specifying lat/lng (in both places, right)
                      like this (good)
                      lat:30.4623841,
                      or this (bad)
                      lat:"30.4623841",
                      • L Offline
                        laschalkh
                        yup, not quoted
                          sdetweil @laschalkh
                          @laschalkh ok, so what is the error?
                          • L Offline
                            laschalkh
                            magicmirror@2.13.0 start /home/pi/MagicMirror
                            ./run-start.sh $1 “dev”
                            [2020-10-16 11:15:36.565] [LOG] Starting MagicMirror: v2.13.0
                            [2020-10-16 11:15:36.775] [LOG] Loading config …
                            [2020-10-16 11:15:36.823] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:73
                            styledMapType: “transparent”,
                            SyntaxError: Unexpected identifier
                            at Module._compile (internal/modules/cjs/loader.js:723:23)
                            at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                            at Module.require (internal/modules/cjs/loader.js:692:17)
                            at require (internal/modules/cjs/helpers.js:25:18)
                            at loadConfig (/home/pi/MagicMirror/js/app.js:70:12)
                            at App.start (/home/pi/MagicMirror/js/app.js:217:3)
                            at Object. (/home/pi/MagicMirror/serveronly/index.js:4:5)
                            [2020-10-16 11:15:36.862] [LOG] Loading module helpers …
                            [2020-10-16 11:15:37.496] [LOG] Initializing new module helper …
                            [2020-10-16 11:15:37.507] [LOG] Module helper loaded: updatenotification
                            [2020-10-16 11:15:37.525] [LOG] No helper found for module: helloworld.
                            [2020-10-16 11:15:37.531] [LOG] All module helpers loaded.
                            [2020-10-16 11:15:39.089] [LOG] Starting server on port 8080 …
                            [2020-10-16 11:15:39.324] [LOG] Server started …
                            [2020-10-16 11:15:39.335] [LOG] Connecting socket for: updatenotification
                            [2020-10-16 11:15:39.346] [LOG] Sockets connected & modules started …
                            [2020-10-16 11:15:39.354] [LOG]
                              sdetweil @laschalkh
                              @laschalkh said in trouble with MMM-GoogleTrafficTimes:
                              rule number 1 debugging syntax errors:
                              IF you see ’ Unexpected identifier’, find the line number
                              config.js:73
                              back up one line (72), and check for the missing , at the end
                                                              width: '300px'                                   <  ---
                              • L Offline
                                laschalkh
                                I see it, damn, I’ve stared at that for way too long, rebooting…
                                  sdetweil @laschalkh
                                  @laschalkh you don’t need to reboot all the time, just restart mm…
                                  • L Offline
                                    laschalkh
                                    it’s working now. Thank you for all of the help!
                                    Kevin
                                      mrhurley
                                      I have been playing around with this and it works well. However, it doesn’t like when you trying to get times for another travel mode. It will change the icons, but the times are always for driving. I played with the file and forced the cycling mode but then it won’t show up on the screen. I think the issue is the Distance Matrix API returns unexpected information for the other modes.
                                      Can someone help point me in the right direction? Thanks
