    moving configfile and modules
    copy config modules old t
    4 Posts 2 Posters 975 Views 2 Watching
      dnj0104
      Hello!
      My first question here but maybe not last.
      Problem: My rpi3b+ made a crash with a config of a magicmirror I was satisfied with.
      But I was in luck, I made a copy of the home>MagicMirror folder and saved it on my windows-laptop
      I made a fresh install of raspbian buster latest, and yesterday I installed a fresh image of Magicmirror.
      So everything is saved…I believe.
      Question: can I take the modules and everything from my copy of magicmirror that I saved and just drag n drop into the fresh copy of MagicMirror? Or I have to install the Modules again and, just copy the configfiles from the MMcopy. Or is it to start from beginning?
      I ask here first before doing things.
      Help Please…
      Greetings
      David.
        sdetweil @dnj0104
        @dnj0104 i think U can copy the module folders and the config file…
        you ‘should’ do
        rm -rf node_modules
        npm install
        in any module folder that contains a package.json file to insure the various dependencies match the MM as it is installed now
          dnj0104 @sdetweil
          @sdetweil said in moving configfile and modules:
          you ‘should’ do
          rm -rf node_modules
          npm install
          hmm okey, I move modules and the the config.js fiel from old copy from my windows-pc to my rpi where i will run magicmirror
          After copiyng is made I run:
          rm -rf node_modules
          npm install
          to check if things is okey.
          ps Im a noob, so if you can please explain as I was five year old :)
            sdetweil @dnj0104
            @dnj0104 after copying the module folder
            as part of a module, they may use libraries, which are not installed by Magic Mirror
            the module instructions (mostly) say
            after git clone
            cd (change directory) into module folder
            then run npm install
            So, we need to replicate that
            the module files are there
            how do you know if u need to do this step
            if inside the module folder there is a file called package.json
            then we need to do the npm install, BUT we may have junk loaded already
            SO, we need to delete where the libs are stored, node_modules folder
            (we are IN the module folder, right)?
            # remove the libraries folder and all its contents
            rm -rf node_modules
            # rebuild the library folder
            npm install
