[Electron] : black screen
however I did not want to update given all the problems encountered with this update …
I do :
npm installin MM folder and a reboot but the problem still here… -
@RIKKO14 what is the error?
@sdetweil I still have a black screen and a problem of Electron.
my pm2 logs --lines=100 :pi@raspberrypi:~ $ pm2 logs --lines=100 [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 100 lines: PM2 | 2020-10-15T23:50:59: PM2 log: pid=24690 msg=process killed PM2 | 2020-10-15T23:50:59: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-15T23:50:59: PM2 log: App [mm:0] online PM2 | 2020-10-16T00:04:33: PM2 log: Stopping app:mm id:0 PM2 | 2020-10-16T00:04:34: PM2 log: pid=24871 msg=failed to kill - retrying in 100ms PM2 | 2020-10-16T00:04:34: PM2 log: pid=24871 msg=failed to kill - retrying in 100ms PM2 | 2020-10-16T00:04:34: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-10-16T00:04:34: PM2 log: pid=24871 msg=process killed PM2 | 2020-10-16T00:04:34: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T00:04:34: PM2 log: App [mm:0] online PM2 | 2020-10-16T00:35:27: PM2 log: Stopping app:mm id:0 PM2 | 2020-10-16T00:35:28: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-10-16T00:35:28: PM2 log: pid=25346 msg=process killed PM2 | 2020-10-16T00:35:28: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T00:35:28: PM2 log: App [mm:0] online PM2 | 2020-10-16T00:35:52: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT] PM2 | 2020-10-16T00:35:52: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T00:35:52: PM2 log: App [mm:0] online PM2 | 2020-10-16T00:35:53: PM2 log: Stopping app:mm id:0 PM2 | 2020-10-16T00:35:53: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-10-16T00:35:53: PM2 log: pid=25895 msg=process killed PM2 | 2020-10-16T00:35:53: PM2 log: PM2 successfully stopped PM2 | 2020-10-16T00:36:03: PM2 log: =============================================================================== PM2 | 2020-10-16T00:36:03: PM2 log: --- New PM2 Daemon started ---------------------------------------------------- PM2 | 2020-10-16T00:36:03: PM2 log: Time : Fri Oct 16 2020 00:36:03 GMT+0200 (GMT+02:00) PM2 | 2020-10-16T00:36:03: PM2 log: PM2 version : 4.4.1 PM2 | 2020-10-16T00:36:03: PM2 log: Node.js version : 10.22.1 PM2 | 2020-10-16T00:36:03: PM2 log: Current arch : arm PM2 | 2020-10-16T00:36:03: PM2 log: PM2 home : /home/pi/.pm2 PM2 | 2020-10-16T00:36:03: PM2 log: PM2 PID file : /home/pi/.pm2/pm2.pid PM2 | 2020-10-16T00:36:03: PM2 log: RPC socket file : /home/pi/.pm2/rpc.sock PM2 | 2020-10-16T00:36:03: PM2 log: BUS socket file : /home/pi/.pm2/pub.sock PM2 | 2020-10-16T00:36:03: PM2 log: Application log path : /home/pi/.pm2/logs PM2 | 2020-10-16T00:36:03: PM2 log: Worker Interval : 30000 PM2 | 2020-10-16T00:36:03: PM2 log: Process dump file : /home/pi/.pm2/dump.pm2 PM2 | 2020-10-16T00:36:03: PM2 log: Concurrent actions : 2 PM2 | 2020-10-16T00:36:03: PM2 log: SIGTERM timeout : 1600 PM2 | 2020-10-16T00:36:03: PM2 log: =============================================================================== PM2 | 2020-10-16T00:36:03: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T00:36:03: PM2 log: App [mm:0] online PM2 | 2020-10-16T00:52:35: PM2 log: Stopping app:mm id:0 PM2 | 2020-10-16T00:52:35: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-10-16T00:52:35: PM2 log: pid=570 msg=process killed PM2 | 2020-10-16T00:52:35: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T00:52:35: PM2 log: App [mm:0] online PM2 | 2020-10-16T00:56:01: PM2 log: Stopping app:mm id:0 PM2 | 2020-10-16T00:56:01: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-10-16T00:56:01: PM2 log: pid=1655 msg=process killed PM2 | 2020-10-16T00:56:01: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T00:56:01: PM2 log: App [mm:0] online PM2 | 2020-10-16T00:56:26: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT] PM2 | 2020-10-16T00:56:26: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T00:56:26: PM2 log: App [mm:0] online PM2 | 2020-10-16T00:56:27: PM2 log: Stopping app:mm id:0 PM2 | 2020-10-16T00:56:27: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-10-16T00:56:27: PM2 log: pid=1881 msg=process killed PM2 | 2020-10-16T00:56:27: PM2 log: PM2 successfully stopped PM2 | 2020-10-16T00:56:36: PM2 log: =============================================================================== PM2 | 2020-10-16T00:56:36: PM2 log: --- New PM2 Daemon started ---------------------------------------------------- PM2 | 2020-10-16T00:56:36: PM2 log: Time : Fri Oct 16 2020 00:56:36 GMT+0200 (GMT+02:00) PM2 | 2020-10-16T00:56:36: PM2 log: PM2 version : 4.4.1 PM2 | 2020-10-16T00:56:36: PM2 log: Node.js version : 10.22.1 PM2 | 2020-10-16T00:56:36: PM2 log: Current arch : arm PM2 | 2020-10-16T00:56:36: PM2 log: PM2 home : /home/pi/.pm2 PM2 | 2020-10-16T00:56:36: PM2 log: PM2 PID file : /home/pi/.pm2/pm2.pid PM2 | 2020-10-16T00:56:36: PM2 log: RPC socket file : /home/pi/.pm2/rpc.sock PM2 | 2020-10-16T00:56:36: PM2 log: BUS socket file : /home/pi/.pm2/pub.sock PM2 | 2020-10-16T00:56:36: PM2 log: Application log path : /home/pi/.pm2/logs PM2 | 2020-10-16T00:56:36: PM2 log: Worker Interval : 30000 PM2 | 2020-10-16T00:56:36: PM2 log: Process dump file : /home/pi/.pm2/dump.pm2 PM2 | 2020-10-16T00:56:36: PM2 log: Concurrent actions : 2 PM2 | 2020-10-16T00:56:36: PM2 log: SIGTERM timeout : 1600 PM2 | 2020-10-16T00:56:36: PM2 log: =============================================================================== PM2 | 2020-10-16T00:56:36: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T00:56:36: PM2 log: App [mm:0] online PM2 | 2020-10-16T09:24:10: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT] PM2 | 2020-10-16T09:24:10: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T09:24:10: PM2 log: App [mm:0] online PM2 | 2020-10-16T09:24:11: PM2 log: Stopping app:mm id:0 PM2 | 2020-10-16T09:24:11: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-10-16T09:24:11: PM2 log: pid=4365 msg=process killed PM2 | 2020-10-16T09:24:11: PM2 log: PM2 successfully stopped PM2 | 2020-10-16T09:24:20: PM2 log: =============================================================================== PM2 | 2020-10-16T09:24:20: PM2 log: --- New PM2 Daemon started ---------------------------------------------------- PM2 | 2020-10-16T09:24:20: PM2 log: Time : Fri Oct 16 2020 09:24:20 GMT+0200 (GMT+02:00) PM2 | 2020-10-16T09:24:20: PM2 log: PM2 version : 4.4.1 PM2 | 2020-10-16T09:24:20: PM2 log: Node.js version : 10.22.1 PM2 | 2020-10-16T09:24:20: PM2 log: Current arch : arm PM2 | 2020-10-16T09:24:20: PM2 log: PM2 home : /home/pi/.pm2 PM2 | 2020-10-16T09:24:20: PM2 log: PM2 PID file : /home/pi/.pm2/pm2.pid PM2 | 2020-10-16T09:24:20: PM2 log: RPC socket file : /home/pi/.pm2/rpc.sock PM2 | 2020-10-16T09:24:20: PM2 log: BUS socket file : /home/pi/.pm2/pub.sock PM2 | 2020-10-16T09:24:20: PM2 log: Application log path : /home/pi/.pm2/logs PM2 | 2020-10-16T09:24:20: PM2 log: Worker Interval : 30000 PM2 | 2020-10-16T09:24:20: PM2 log: Process dump file : /home/pi/.pm2/dump.pm2 PM2 | 2020-10-16T09:24:20: PM2 log: Concurrent actions : 2 PM2 | 2020-10-16T09:24:20: PM2 log: SIGTERM timeout : 1600 PM2 | 2020-10-16T09:24:20: PM2 log: =============================================================================== PM2 | 2020-10-16T09:24:20: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-10-16T09:24:20: PM2 log: App [mm:0] online /home/pi/.pm2/logs/mm-error.log last 100 lines: 0|mm | at Module.load (internal/modules/cjs/loader.js:645:32) 0|mm | [2020-10-16 00:56:49.646] [ERROR] Whoops! There was an uncaught exception... 0|mm | [2020-10-16 00:56:49.647] [ERROR] Error: Cannot find module 'node-ical' 0|mm | Require stack: 0|mm | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js 0|mm | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js 0|mm | - /home/pi/MagicMirror/js/app.js 0|mm | - /home/pi/MagicMirror/js/electron.js 0|mm | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js 0|mm | - 0|mm | at Module._resolveFilename (internal/modules/cjs/loader.js:627:15) 0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16) 0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) 0|mm | at Function.Module._load (internal/modules/cjs/loader.js:531:27) 0|mm | at Module.require (internal/modules/cjs/loader.js:685:19) 0|mm | at require (internal/modules/cjs/helpers.js:16:16) 0|mm | at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14) 0|mm | at Module._compile (internal/modules/cjs/loader.js:786:30) 0|mm | at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) 0|mm | at Module.load (internal/modules/cjs/loader.js:645:32) { 0|mm | code: 'MODULE_NOT_FOUND', 0|mm | requireStack: [ 0|mm | '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js', 0|mm | '/home/pi/MagicMirror/modules/default/calendar/node_helper.js', 0|mm | '/home/pi/MagicMirror/js/app.js', 0|mm | '/home/pi/MagicMirror/js/electron.js', 0|mm | '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js', 0|mm | undefined 0|mm | ] 0|mm | } 0|mm | [2020-10-16 00:56:49.652] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [2020-10-16 00:56:49.652] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | npm ERR! code ELIFECYCLE 0|mm | npm ERR! errno 1 0|mm | npm ERR! magicmirror@2.14.0-develop start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js` 0|mm | npm ERR! Exit status 1 0|mm | npm ERR! 0|mm | npm ERR! Failed at the magicmirror@2.14.0-develop start script. 0|mm | npm ERR! This is probably not a problem with npm. There is likely additional logging output above. 0|mm | 0|mm | npm ERR! A complete log of this run can be found in: 0|mm | npm ERR! /home/pi/.npm/_logs/2020-10-16T07_24_10_332Z-debug.log 0|mm | [2020-10-16 09:24:34.287] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical' 0|mm | Require stack: 0|mm | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js 0|mm | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js 0|mm | - /home/pi/MagicMirror/js/app.js 0|mm | - /home/pi/MagicMirror/js/electron.js 0|mm | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js 0|mm | - 0|mm | [2020-10-16 09:24:34.303] [ERROR] App threw an error during load 0|mm | [2020-10-16 09:24:34.304] [ERROR] Error: Cannot find module 'node-ical' 0|mm | Require stack: 0|mm | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js 0|mm | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js 0|mm | - /home/pi/MagicMirror/js/app.js 0|mm | - /home/pi/MagicMirror/js/electron.js 0|mm | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js 0|mm | - 0|mm | at Module._resolveFilename (internal/modules/cjs/loader.js:627:15) 0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16) 0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) 0|mm | at Function.Module._load (internal/modules/cjs/loader.js:531:27) 0|mm | at Module.require (internal/modules/cjs/loader.js:685:19) 0|mm | at require (internal/modules/cjs/helpers.js:16:16) 0|mm | at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14) 0|mm | at Module._compile (internal/modules/cjs/loader.js:786:30) 0|mm | at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) 0|mm | at Module.load (internal/modules/cjs/loader.js:645:32) 0|mm | [2020-10-16 09:24:34.307] [ERROR] Whoops! There was an uncaught exception... 0|mm | [2020-10-16 09:24:34.307] [ERROR] Error: Cannot find module 'node-ical' 0|mm | Require stack: 0|mm | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js 0|mm | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js 0|mm | - /home/pi/MagicMirror/js/app.js 0|mm | - /home/pi/MagicMirror/js/electron.js 0|mm | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js 0|mm | - 0|mm | at Module._resolveFilename (internal/modules/cjs/loader.js:627:15) 0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16) 0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) 0|mm | at Function.Module._load (internal/modules/cjs/loader.js:531:27) 0|mm | at Module.require (internal/modules/cjs/loader.js:685:19) 0|mm | at require (internal/modules/cjs/helpers.js:16:16) 0|mm | at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14) 0|mm | at Module._compile (internal/modules/cjs/loader.js:786:30) 0|mm | at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) 0|mm | at Module.load (internal/modules/cjs/loader.js:645:32) { 0|mm | code: 'MODULE_NOT_FOUND', 0|mm | requireStack: [ 0|mm | '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js', 0|mm | '/home/pi/MagicMirror/modules/default/calendar/node_helper.js', 0|mm | '/home/pi/MagicMirror/js/app.js', 0|mm | '/home/pi/MagicMirror/js/electron.js', 0|mm | '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js', 0|mm | undefined 0|mm | ] 0|mm | } 0|mm | [2020-10-16 09:24:34.316] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [2020-10-16 09:24:34.317] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues /home/pi/.pm2/logs/mm-out.log last 100 lines: 0|mm | [2020-10-16 00:52:41.518] [LOG] Launching application. 0|mm | 0|mm | > magicmirror@2.14.0-develop start /home/pi/MagicMirror 0|mm | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|mm | 0|mm | [2020-10-16 00:56:03.770] [LOG] Starting MagicMirror: v2.14.0-develop 0|mm | [2020-10-16 00:56:03.778] [LOG] Loading config ... 0|mm | [2020-10-16 00:56:03.785] [LOG] Loading module helpers ... 0|mm | [2020-10-16 00:56:03.787] [LOG] No helper found for module: alert. 0|mm | [2020-10-16 00:56:03.833] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:03.834] [LOG] Module helper loaded: updatenotification 0|mm | [2020-10-16 00:56:06.505] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:06.505] [LOG] Module helper loaded: MMM-GoogleAssistant 0|mm | [2020-10-16 00:56:07.591] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:07.591] [LOG] Module helper loaded: MMM-Assistant2Display 0|mm | [2020-10-16 00:56:07.848] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:07.849] [LOG] Module helper loaded: MMM-UpdateNotification 0|mm | [2020-10-16 00:56:07.854] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:07.855] [LOG] Module helper loaded: MMM-DHT-Sensor 0|mm | [2020-10-16 00:56:07.855] [LOG] No helper found for module: clock. 0|mm | [2020-10-16 00:56:07.864] [LOG] Loading module helpers ... 0|mm | [2020-10-16 00:56:07.865] [LOG] No helper found for module: alert. 0|mm | [2020-10-16 00:56:07.865] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:07.866] [LOG] Module helper loaded: updatenotification 0|mm | [2020-10-16 00:56:07.867] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:07.867] [LOG] Module helper loaded: MMM-GoogleAssistant 0|mm | [2020-10-16 00:56:07.867] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:07.868] [LOG] Module helper loaded: MMM-Assistant2Display 0|mm | [2020-10-16 00:56:07.868] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:07.869] [LOG] Module helper loaded: MMM-UpdateNotification 0|mm | [2020-10-16 00:56:07.869] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:07.870] [LOG] Module helper loaded: MMM-DHT-Sensor 0|mm | [2020-10-16 00:56:07.870] [LOG] No helper found for module: clock. 0|mm | [2020-10-16 00:56:07.972] [LOG] Launching application. 0|mm | 0|mm | > magicmirror@2.14.0-develop start /home/pi/MagicMirror 0|mm | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|mm | 0|mm | [2020-10-16 00:56:42.884] [LOG] Starting MagicMirror: v2.14.0-develop 0|mm | [2020-10-16 00:56:42.911] [LOG] Loading config ... 0|mm | [2020-10-16 00:56:42.920] [LOG] Loading module helpers ... 0|mm | [2020-10-16 00:56:42.923] [LOG] No helper found for module: alert. 0|mm | [2020-10-16 00:56:43.001] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:43.002] [LOG] Module helper loaded: updatenotification 0|mm | [2020-10-16 00:56:47.278] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:47.280] [LOG] Module helper loaded: MMM-GoogleAssistant 0|mm | [2020-10-16 00:56:49.147] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:49.147] [LOG] Module helper loaded: MMM-Assistant2Display 0|mm | [2020-10-16 00:56:49.589] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:49.589] [LOG] Module helper loaded: MMM-UpdateNotification 0|mm | [2020-10-16 00:56:49.618] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:49.618] [LOG] Module helper loaded: MMM-DHT-Sensor 0|mm | [2020-10-16 00:56:49.620] [LOG] No helper found for module: clock. 0|mm | [2020-10-16 00:56:49.635] [LOG] Loading module helpers ... 0|mm | [2020-10-16 00:56:49.636] [LOG] No helper found for module: alert. 0|mm | [2020-10-16 00:56:49.636] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:49.637] [LOG] Module helper loaded: updatenotification 0|mm | [2020-10-16 00:56:49.637] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:49.638] [LOG] Module helper loaded: MMM-GoogleAssistant 0|mm | [2020-10-16 00:56:49.638] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:49.639] [LOG] Module helper loaded: MMM-Assistant2Display 0|mm | [2020-10-16 00:56:49.639] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:49.640] [LOG] Module helper loaded: MMM-UpdateNotification 0|mm | [2020-10-16 00:56:49.640] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 00:56:49.640] [LOG] Module helper loaded: MMM-DHT-Sensor 0|mm | [2020-10-16 00:56:49.641] [LOG] No helper found for module: clock. 0|mm | [2020-10-16 00:56:49.950] [LOG] Launching application. 0|mm | 0|mm | > magicmirror@2.14.0-develop start /home/pi/MagicMirror 0|mm | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|mm | 0|mm | [2020-10-16 09:24:27.338] [LOG] Starting MagicMirror: v2.14.0-develop 0|mm | [2020-10-16 09:24:27.364] [LOG] Loading config ... 0|mm | [2020-10-16 09:24:27.376] [LOG] Loading module helpers ... 0|mm | [2020-10-16 09:24:27.379] [LOG] No helper found for module: alert. 0|mm | [2020-10-16 09:24:27.456] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:27.457] [LOG] Module helper loaded: updatenotification 0|mm | [2020-10-16 09:24:31.742] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:31.743] [LOG] Module helper loaded: MMM-GoogleAssistant 0|mm | [2020-10-16 09:24:33.721] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:33.724] [LOG] Module helper loaded: MMM-Assistant2Display 0|mm | [2020-10-16 09:24:34.210] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:34.211] [LOG] Module helper loaded: MMM-UpdateNotification 0|mm | [2020-10-16 09:24:34.262] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:34.263] [LOG] Module helper loaded: MMM-DHT-Sensor 0|mm | [2020-10-16 09:24:34.265] [LOG] No helper found for module: clock. 0|mm | [2020-10-16 09:24:34.288] [LOG] Loading module helpers ... 0|mm | [2020-10-16 09:24:34.289] [LOG] No helper found for module: alert. 0|mm | [2020-10-16 09:24:34.291] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:34.291] [LOG] Module helper loaded: updatenotification 0|mm | [2020-10-16 09:24:34.292] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:34.293] [LOG] Module helper loaded: MMM-GoogleAssistant 0|mm | [2020-10-16 09:24:34.294] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:34.295] [LOG] Module helper loaded: MMM-Assistant2Display 0|mm | [2020-10-16 09:24:34.296] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:34.296] [LOG] Module helper loaded: MMM-UpdateNotification 0|mm | [2020-10-16 09:24:34.297] [LOG] Initializing new module helper ... 0|mm | [2020-10-16 09:24:34.298] [LOG] Module helper loaded: MMM-DHT-Sensor 0|mm | [2020-10-16 09:24:34.299] [LOG] No helper found for module: clock. 0|mm | [2020-10-16 09:24:34.680] [LOG] Launching application.and this is an extraction of the red lines (so, the problem) of pm2 logs --lines =100 :
0|mm | npm ERR! /home/pi/.npm/_logs/2020-10-16T07_24_10_332Z-debug.log 0|mm | [2020-10-16 09:24:34.287] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical' 0|mm | Require stack: 0|mm | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js 0|mm | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js 0|mm | - /home/pi/MagicMirror/js/app.js 0|mm | - /home/pi/MagicMirror/js/electron.js 0|mm | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js 0|mm | - -
should I do that ? :
cd ~/MagicMirror rm -rf node_modules/electron npm install electron@6.1.12I see you request to someone to do that…
@RIKKO14 over and over it says library package node-ical is missing.
after you switch to the develop branch you MUST run npm install from the MagicMirror folder
@sdetweil so this is what i wrote in the terminal :
pi@raspberrypi:~ $ cd ~/MagicMirror pi@raspberrypi:~/MagicMirror $ npm install npm ERR! code EISGIT npm ERR! path /home/pi/MagicMirror/node_modules/ical npm ERR! git /home/pi/MagicMirror/node_modules/ical: Appears to be a git repo or submodule. npm ERR! git /home/pi/MagicMirror/node_modules/ical npm ERR! git Refusing to remove it. Update manually, npm ERR! git or move it out of the way first. npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2020-10-16T13_54_17_756Z-debug.log pi@raspberrypi:~/MagicMirror $ run npm install bash: run : commande introuvablecd ~/MagicMirror/,npm installrun npm installbut there is a bash return :bash : run : commande introuvable -
@sdetweil it’s work,
T.H.A.N.K Y.O.U !!!
