    [Electron] : black screen
    28 Posts 2 Posters 7.7k Views 2 Watching
      RIKKO14
      I removed MMM-soccer but I have the same problem with Electron
        RIKKO14
        with pm2 logs --lines=100
        the problem is (it’s wrote in red) :
        0|mm       | [2020-10-16 00:36:17.353] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
        0|mm       | Require stack:
        0|mm       | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
        0|mm       | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
        0|mm       | - /home/pi/MagicMirror/js/app.js
        0|mm       | - /home/pi/MagicMirror/js/electron.js
        0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
          sdetweil @RIKKO14
          @RIKKO14 looks like u updated to the temporary 2.13, but did not run
          npm install
          in the MagicMirror folder
            RIKKO14
            however I did not want to update given all the problems encountered with this update …
            I do : npm install in MM folder and a reboot but the problem still here…
              sdetweil @RIKKO14
              @RIKKO14 what is the error?
                RIKKO14
                @sdetweil I still have a black screen and a problem of Electron.
                my pm2 logs --lines=100 :
                pi@raspberrypi:~ $ pm2 logs --lines=100
                PM2        | 2020-10-15T23:50:59: PM2 log: pid=24690 msg=process killed
                PM2        | 2020-10-15T23:50:59: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-15T23:50:59: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T00:04:33: PM2 log: Stopping app:mm id:0
                PM2        | 2020-10-16T00:04:34: PM2 log: pid=24871 msg=failed to kill - retrying in 100ms
                PM2        | 2020-10-16T00:04:34: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-10-16T00:04:34: PM2 log: pid=24871 msg=process killed
                PM2        | 2020-10-16T00:04:34: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T00:04:34: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T00:35:27: PM2 log: Stopping app:mm id:0
                PM2        | 2020-10-16T00:35:28: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-10-16T00:35:28: PM2 log: pid=25346 msg=process killed
                PM2        | 2020-10-16T00:35:28: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T00:35:28: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T00:35:52: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
                PM2        | 2020-10-16T00:35:52: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T00:35:52: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T00:35:53: PM2 log: Stopping app:mm id:0
                PM2        | 2020-10-16T00:35:53: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-10-16T00:35:53: PM2 log: pid=25895 msg=process killed
                PM2        | 2020-10-16T00:35:53: PM2 log: PM2 successfully stopped
                PM2        | 2020-10-16T00:36:03: PM2 log: ===============================================================================
                PM2        | 2020-10-16T00:36:03: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                PM2        | 2020-10-16T00:36:03: PM2 log: Time                 : Fri Oct 16 2020 00:36:03 GMT+0200 (GMT+02:00)
                PM2        | 2020-10-16T00:36:03: PM2 log: PM2 version          : 4.4.1
                PM2        | 2020-10-16T00:36:03: PM2 log: Node.js version      : 10.22.1
                PM2        | 2020-10-16T00:36:03: PM2 log: Current arch         : arm
                PM2        | 2020-10-16T00:36:03: PM2 log: PM2 home             : /home/pi/.pm2
                PM2        | 2020-10-16T00:36:03: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                PM2        | 2020-10-16T00:36:03: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                PM2        | 2020-10-16T00:36:03: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                PM2        | 2020-10-16T00:36:03: PM2 log: Application log path : /home/pi/.pm2/logs
                PM2        | 2020-10-16T00:36:03: PM2 log: Worker Interval      : 30000
                PM2        | 2020-10-16T00:36:03: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                PM2        | 2020-10-16T00:36:03: PM2 log: Concurrent actions   : 2
                PM2        | 2020-10-16T00:36:03: PM2 log: SIGTERM timeout      : 1600
                PM2        | 2020-10-16T00:36:03: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T00:36:03: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T00:52:35: PM2 log: Stopping app:mm id:0
                PM2        | 2020-10-16T00:52:35: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-10-16T00:52:35: PM2 log: pid=570 msg=process killed
                PM2        | 2020-10-16T00:52:35: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T00:52:35: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T00:56:01: PM2 log: Stopping app:mm id:0
                PM2        | 2020-10-16T00:56:01: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-10-16T00:56:01: PM2 log: pid=1655 msg=process killed
                PM2        | 2020-10-16T00:56:01: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T00:56:01: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T00:56:26: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
                PM2        | 2020-10-16T00:56:26: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T00:56:26: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T00:56:27: PM2 log: Stopping app:mm id:0
                PM2        | 2020-10-16T00:56:27: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-10-16T00:56:27: PM2 log: pid=1881 msg=process killed
                PM2        | 2020-10-16T00:56:27: PM2 log: PM2 successfully stopped
                PM2        | 2020-10-16T00:56:36: PM2 log: ===============================================================================
                PM2        | 2020-10-16T00:56:36: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                PM2        | 2020-10-16T00:56:36: PM2 log: Time                 : Fri Oct 16 2020 00:56:36 GMT+0200 (GMT+02:00)
                PM2        | 2020-10-16T00:56:36: PM2 log: PM2 version          : 4.4.1
                PM2        | 2020-10-16T00:56:36: PM2 log: Node.js version      : 10.22.1
                PM2        | 2020-10-16T00:56:36: PM2 log: Current arch         : arm
                PM2        | 2020-10-16T00:56:36: PM2 log: PM2 home             : /home/pi/.pm2
                PM2        | 2020-10-16T00:56:36: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                PM2        | 2020-10-16T00:56:36: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                PM2        | 2020-10-16T00:56:36: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                PM2        | 2020-10-16T00:56:36: PM2 log: Application log path : /home/pi/.pm2/logs
                PM2        | 2020-10-16T00:56:36: PM2 log: Worker Interval      : 30000
                PM2        | 2020-10-16T00:56:36: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                PM2        | 2020-10-16T00:56:36: PM2 log: Concurrent actions   : 2
                PM2        | 2020-10-16T00:56:36: PM2 log: SIGTERM timeout      : 1600
                PM2        | 2020-10-16T00:56:36: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T00:56:36: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T09:24:10: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
                PM2        | 2020-10-16T09:24:10: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T09:24:10: PM2 log: App [mm:0] online
                PM2        | 2020-10-16T09:24:11: PM2 log: Stopping app:mm id:0
                PM2        | 2020-10-16T09:24:11: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                PM2        | 2020-10-16T09:24:11: PM2 log: pid=4365 msg=process killed
                PM2        | 2020-10-16T09:24:11: PM2 log: PM2 successfully stopped
                PM2        | 2020-10-16T09:24:20: PM2 log: ===============================================================================
                PM2        | 2020-10-16T09:24:20: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                PM2        | 2020-10-16T09:24:20: PM2 log: Time                 : Fri Oct 16 2020 09:24:20 GMT+0200 (GMT+02:00)
                PM2        | 2020-10-16T09:24:20: PM2 log: PM2 version          : 4.4.1
                PM2        | 2020-10-16T09:24:20: PM2 log: Node.js version      : 10.22.1
                PM2        | 2020-10-16T09:24:20: PM2 log: Current arch         : arm
                PM2        | 2020-10-16T09:24:20: PM2 log: PM2 home             : /home/pi/.pm2
                PM2        | 2020-10-16T09:24:20: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                PM2        | 2020-10-16T09:24:20: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                PM2        | 2020-10-16T09:24:20: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                PM2        | 2020-10-16T09:24:20: PM2 log: Application log path : /home/pi/.pm2/logs
                PM2        | 2020-10-16T09:24:20: PM2 log: Worker Interval      : 30000
                PM2        | 2020-10-16T09:24:20: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                PM2        | 2020-10-16T09:24:20: PM2 log: Concurrent actions   : 2
                PM2        | 2020-10-16T09:24:20: PM2 log: SIGTERM timeout      : 1600
                PM2        | 2020-10-16T09:24:20: PM2 log: App [mm:0] starting in -fork mode-
                PM2        | 2020-10-16T09:24:20: PM2 log: App [mm:0] online
                0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32)
                0|mm       | [2020-10-16 00:56:49.646] [ERROR]  Whoops! There was an uncaught exception...
                0|mm       | [2020-10-16 00:56:49.647] [ERROR]  Error: Cannot find module 'node-ical'
                0|mm       | -
                0|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                0|mm       |     at Module.require (internal/modules/cjs/loader.js:685:19)
                0|mm       |     at require (internal/modules/cjs/helpers.js:16:16)
                0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                0|mm       |     at Module._compile (internal/modules/cjs/loader.js:786:30)
                0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32) {
                0|mm       |   code: 'MODULE_NOT_FOUND',
                0|mm       |   requireStack: [
                0|mm       |     '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                0|mm       |     '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                0|mm       |     '/home/pi/MagicMirror/js/app.js',
                0|mm       |     '/home/pi/MagicMirror/js/electron.js',
                0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                0|mm       |     undefined
                0|mm       |   ]
                0|mm       | }
                0|mm       | [2020-10-16 00:56:49.652] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm       | [2020-10-16 00:56:49.652] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm       | npm ERR! code ELIFECYCLE
                0|mm       | npm ERR! errno 1
                0|mm       | npm ERR! magicmirror@2.14.0-develop start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                0|mm       | npm ERR! Exit status 1
                0|mm       | npm ERR!
                0|mm       | npm ERR! Failed at the magicmirror@2.14.0-develop start script.
                0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                0|mm       |
                0|mm       | npm ERR! A complete log of this run can be found in:
                0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-10-16T07_24_10_332Z-debug.log
                0|mm       | [2020-10-16 09:24:34.287] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
                0|mm       | -
                0|mm       | [2020-10-16 09:24:34.303] [ERROR]  App threw an error during load
                0|mm       | [2020-10-16 09:24:34.304] [ERROR]  Error: Cannot find module 'node-ical'
                0|mm       | -
                0|mm       | [2020-10-16 09:24:34.307] [ERROR]  Whoops! There was an uncaught exception...
                0|mm       | [2020-10-16 09:24:34.307] [ERROR]  Error: Cannot find module 'node-ical'
                0|mm       | -
                0|mm       |     undefined
                0|mm       |   ]
                0|mm       | }
                0|mm       | [2020-10-16 09:24:34.316] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm       | [2020-10-16 09:24:34.317] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm       | [2020-10-16 00:52:41.518] [LOG]    Launching application.
                0|mm       |
                0|mm       | > magicmirror@2.14.0-develop start /home/pi/MagicMirror
                0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                0|mm       |
                0|mm       | [2020-10-16 00:56:03.770] [LOG]    Starting MagicMirror: v2.14.0-develop
                0|mm       | [2020-10-16 00:56:03.778] [LOG]    Loading config ...
                0|mm       | [2020-10-16 00:56:03.785] [LOG]    Loading module helpers ...
                0|mm       | [2020-10-16 00:56:03.787] [LOG]    No helper found for module: alert.
                0|mm       | [2020-10-16 00:56:03.833] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:03.834] [LOG]    Module helper loaded: updatenotification
                0|mm       | [2020-10-16 00:56:06.505] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:06.505] [LOG]    Module helper loaded: MMM-GoogleAssistant
                0|mm       | [2020-10-16 00:56:07.591] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:07.591] [LOG]    Module helper loaded: MMM-Assistant2Display
                0|mm       | [2020-10-16 00:56:07.848] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:07.849] [LOG]    Module helper loaded: MMM-UpdateNotification
                0|mm       | [2020-10-16 00:56:07.854] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:07.855] [LOG]    Module helper loaded: MMM-DHT-Sensor
                0|mm       | [2020-10-16 00:56:07.855] [LOG]    No helper found for module: clock.
                0|mm       | [2020-10-16 00:56:07.864] [LOG]    Loading module helpers ...
                0|mm       | [2020-10-16 00:56:07.865] [LOG]    No helper found for module: alert.
                0|mm       | [2020-10-16 00:56:07.865] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:07.866] [LOG]    Module helper loaded: updatenotification
                0|mm       | [2020-10-16 00:56:07.867] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:07.867] [LOG]    Module helper loaded: MMM-GoogleAssistant
                0|mm       | [2020-10-16 00:56:07.868] [LOG]    Module helper loaded: MMM-Assistant2Display
                0|mm       | [2020-10-16 00:56:07.868] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:07.869] [LOG]    Module helper loaded: MMM-UpdateNotification
                0|mm       | [2020-10-16 00:56:07.869] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:07.870] [LOG]    Module helper loaded: MMM-DHT-Sensor
                0|mm       | [2020-10-16 00:56:07.870] [LOG]    No helper found for module: clock.
                0|mm       | [2020-10-16 00:56:07.972] [LOG]    Launching application.
                0|mm       |
                0|mm       |
                0|mm       | [2020-10-16 00:56:42.884] [LOG]    Starting MagicMirror: v2.14.0-develop
                0|mm       | [2020-10-16 00:56:42.911] [LOG]    Loading config ...
                0|mm       | [2020-10-16 00:56:42.920] [LOG]    Loading module helpers ...
                0|mm       | [2020-10-16 00:56:42.923] [LOG]    No helper found for module: alert.
                0|mm       | [2020-10-16 00:56:43.001] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:43.002] [LOG]    Module helper loaded: updatenotification
                0|mm       | [2020-10-16 00:56:47.278] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:47.280] [LOG]    Module helper loaded: MMM-GoogleAssistant
                0|mm       | [2020-10-16 00:56:49.147] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:49.147] [LOG]    Module helper loaded: MMM-Assistant2Display
                0|mm       | [2020-10-16 00:56:49.589] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:49.589] [LOG]    Module helper loaded: MMM-UpdateNotification
                0|mm       | [2020-10-16 00:56:49.618] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:49.618] [LOG]    Module helper loaded: MMM-DHT-Sensor
                0|mm       | [2020-10-16 00:56:49.620] [LOG]    No helper found for module: clock.
                0|mm       | [2020-10-16 00:56:49.635] [LOG]    Loading module helpers ...
                0|mm       | [2020-10-16 00:56:49.636] [LOG]    No helper found for module: alert.
                0|mm       | [2020-10-16 00:56:49.636] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:49.637] [LOG]    Module helper loaded: updatenotification
                0|mm       | [2020-10-16 00:56:49.637] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:49.638] [LOG]    Module helper loaded: MMM-GoogleAssistant
                0|mm       | [2020-10-16 00:56:49.638] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:49.639] [LOG]    Module helper loaded: MMM-Assistant2Display
                0|mm       | [2020-10-16 00:56:49.639] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:49.640] [LOG]    Module helper loaded: MMM-UpdateNotification
                0|mm       | [2020-10-16 00:56:49.640] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 00:56:49.640] [LOG]    Module helper loaded: MMM-DHT-Sensor
                0|mm       | [2020-10-16 00:56:49.641] [LOG]    No helper found for module: clock.
                0|mm       | [2020-10-16 00:56:49.950] [LOG]    Launching application.
                0|mm       |
                0|mm       |
                0|mm       | [2020-10-16 09:24:27.338] [LOG]    Starting MagicMirror: v2.14.0-develop
                0|mm       | [2020-10-16 09:24:27.364] [LOG]    Loading config ...
                0|mm       | [2020-10-16 09:24:27.376] [LOG]    Loading module helpers ...
                0|mm       | [2020-10-16 09:24:27.379] [LOG]    No helper found for module: alert.
                0|mm       | [2020-10-16 09:24:27.456] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:27.457] [LOG]    Module helper loaded: updatenotification
                0|mm       | [2020-10-16 09:24:31.742] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:31.743] [LOG]    Module helper loaded: MMM-GoogleAssistant
                0|mm       | [2020-10-16 09:24:33.721] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:33.724] [LOG]    Module helper loaded: MMM-Assistant2Display
                0|mm       | [2020-10-16 09:24:34.210] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:34.211] [LOG]    Module helper loaded: MMM-UpdateNotification
                0|mm       | [2020-10-16 09:24:34.262] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:34.263] [LOG]    Module helper loaded: MMM-DHT-Sensor
                0|mm       | [2020-10-16 09:24:34.265] [LOG]    No helper found for module: clock.
                0|mm       | [2020-10-16 09:24:34.288] [LOG]    Loading module helpers ...
                0|mm       | [2020-10-16 09:24:34.289] [LOG]    No helper found for module: alert.
                0|mm       | [2020-10-16 09:24:34.291] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:34.291] [LOG]    Module helper loaded: updatenotification
                0|mm       | [2020-10-16 09:24:34.292] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:34.293] [LOG]    Module helper loaded: MMM-GoogleAssistant
                0|mm       | [2020-10-16 09:24:34.294] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:34.295] [LOG]    Module helper loaded: MMM-Assistant2Display
                0|mm       | [2020-10-16 09:24:34.296] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:34.296] [LOG]    Module helper loaded: MMM-UpdateNotification
                0|mm       | [2020-10-16 09:24:34.297] [LOG]    Initializing new module helper ...
                0|mm       | [2020-10-16 09:24:34.298] [LOG]    Module helper loaded: MMM-DHT-Sensor
                0|mm       | [2020-10-16 09:24:34.299] [LOG]    No helper found for module: clock.
                0|mm       | [2020-10-16 09:24:34.680] [LOG]    Launching application.
                and this is an extraction of the red lines (so, the problem) of pm2 logs --lines =100 :
                0|mm       | -
                  RIKKO14
                  should I do that ? :
                  rm -rf node_modules/electron
                  npm install electron@6.1.12
                  I see you request to someone to do that…
                    sdetweil @RIKKO14
                    @RIKKO14 over and over it says library package node-ical is missing.
                    after you switch to the develop branch you MUST run npm install from the MagicMirror folder
                      RIKKO14
                      @sdetweil so this is what i wrote in the terminal :
                      pi@raspberrypi:~/MagicMirror $ npm install
                      npm ERR! code EISGIT
                      npm ERR! path /home/pi/MagicMirror/node_modules/ical
                      npm ERR! git /home/pi/MagicMirror/node_modules/ical: Appears to be a git repo or submodule.
                      npm ERR! git Refusing to remove it. Update manually,
                      npm ERR! git or move it out of the way first.
                      npm ERR!     /home/pi/.npm/_logs/2020-10-16T13_54_17_756Z-debug.log
                      pi@raspberrypi:~/MagicMirror $ run npm install
                      bash: run : commande introuvable
                      cd ~/MagicMirror/ , npm install run npm install but there is a bash return : bash : run : commande introuvable
                        sdetweil @RIKKO14
                        @RIKKO14 ok
                        do this
                        rm -rf ~/MagicMirror/node_modules/ical
                        then run the npm install again
                          RIKKO14
                          @sdetweil it’s work,
                          T.H.A.N.K Y.O.U !!!
