    [Electron] : black screen
    28 Posts 2 Posters 7.7k Views 2 Watching
      RIKKO14
      @sdetweil said in [Electron] : black screen:
      node_modules/,bin/electron-rebuild
      I’m very sorry but i don’t anderstand what I must write if the problem is about MMM-soccer…
        cd modules/MMM-Soccer
        ../../node_modules/.bin/electron-rebuild
        get into the MMM-Soccer folder
        then
        execute the electron-rebuild from back up the tree towards the MagicMirror base folder
        you can do that without moving, same as one windows
          RIKKO14
          i wrote this :
          pi@raspberrypi:~/MagicMirror/modules/MMM-soccer $ cd ~/MagicMirror
          pi@raspberrypi:~/MagicMirror $ npm install electron-rebuild
          npm ERR! code EISGIT
          npm ERR! path /home/pi/MagicMirror/node_modules/ical
          npm ERR! git /home/pi/MagicMirror/node_modules/ical: Appears to be a git repo or submodule.
          npm ERR! git Refusing to remove it. Update manually,
          npm ERR! git or move it out of the way first.
          npm ERR!     /home/pi/.npm/_logs/2020-10-15T22_25_39_745Z-debug.log```
          and after ?
            sdetweil @RIKKO14
            @RIKKO14 i know, you are in the wrong place… I gave u the exact commands to enter
              RIKKO14
              I still do not understand…
              pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror/modules/MMM-soccer/node_modules/,bin/electron-rebuild
              bash: cd: /home/pi/MagicMirror/modules/MMM-soccer/node_modules/,bin/electron-rebuild: Aucun fichier ou dossier de ce type
                sdetweil @RIKKO14
                @RIKKO14 said in [Electron] : black screen:
                you are here
                ~/MagicMirror
                do these commands
                  RIKKO14
                  sorry but :
                  pi@raspberrypi:~/MagicMirror $ cd modules/MMM-Soccer
                  bash: cd: modules/MMM-Soccer: Aucun fichier ou dossier de ce type
                  so when I wrote cd modules/MMM-Soccer after cd~ /MagicMirror
                  it’s a “bash” return…
                    RIKKO14
                    I removed MMM-soccer but I have the same problem with Electron
                      RIKKO14
                      with pm2 logs --lines=100
                      the problem is (it’s wrote in red) :
                      0|mm       | [2020-10-16 00:36:17.353] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
                      0|mm       | Require stack:
                      0|mm       | - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                      0|mm       | - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                      0|mm       | - /home/pi/MagicMirror/js/app.js
                      0|mm       | - /home/pi/MagicMirror/js/electron.js
                      0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                        sdetweil @RIKKO14
                        @RIKKO14 looks like u updated to the temporary 2.13, but did not run
                        npm install
                        in the MagicMirror folder
                          RIKKO14
                          however I did not want to update given all the problems encountered with this update …
                          I do : npm install in MM folder and a reboot but the problem still here…
                            sdetweil @RIKKO14
                            @RIKKO14 what is the error?
                              RIKKO14
                              @sdetweil I still have a black screen and a problem of Electron.
                              my pm2 logs --lines=100 :
                              pi@raspberrypi:~ $ pm2 logs --lines=100
                              PM2        | 2020-10-15T23:50:59: PM2 log: pid=24690 msg=process killed
                              PM2        | 2020-10-15T23:50:59: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-15T23:50:59: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T00:04:33: PM2 log: Stopping app:mm id:0
                              PM2        | 2020-10-16T00:04:34: PM2 log: pid=24871 msg=failed to kill - retrying in 100ms
                              PM2        | 2020-10-16T00:04:34: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-10-16T00:04:34: PM2 log: pid=24871 msg=process killed
                              PM2        | 2020-10-16T00:04:34: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T00:04:34: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T00:35:27: PM2 log: Stopping app:mm id:0
                              PM2        | 2020-10-16T00:35:28: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-10-16T00:35:28: PM2 log: pid=25346 msg=process killed
                              PM2        | 2020-10-16T00:35:28: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T00:35:28: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T00:35:52: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
                              PM2        | 2020-10-16T00:35:52: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T00:35:52: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T00:35:53: PM2 log: Stopping app:mm id:0
                              PM2        | 2020-10-16T00:35:53: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-10-16T00:35:53: PM2 log: pid=25895 msg=process killed
                              PM2        | 2020-10-16T00:35:53: PM2 log: PM2 successfully stopped
                              PM2        | 2020-10-16T00:36:03: PM2 log: ===============================================================================
                              PM2        | 2020-10-16T00:36:03: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                              PM2        | 2020-10-16T00:36:03: PM2 log: Time                 : Fri Oct 16 2020 00:36:03 GMT+0200 (GMT+02:00)
                              PM2        | 2020-10-16T00:36:03: PM2 log: PM2 version          : 4.4.1
                              PM2        | 2020-10-16T00:36:03: PM2 log: Node.js version      : 10.22.1
                              PM2        | 2020-10-16T00:36:03: PM2 log: Current arch         : arm
                              PM2        | 2020-10-16T00:36:03: PM2 log: PM2 home             : /home/pi/.pm2
                              PM2        | 2020-10-16T00:36:03: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                              PM2        | 2020-10-16T00:36:03: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                              PM2        | 2020-10-16T00:36:03: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                              PM2        | 2020-10-16T00:36:03: PM2 log: Application log path : /home/pi/.pm2/logs
                              PM2        | 2020-10-16T00:36:03: PM2 log: Worker Interval      : 30000
                              PM2        | 2020-10-16T00:36:03: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                              PM2        | 2020-10-16T00:36:03: PM2 log: Concurrent actions   : 2
                              PM2        | 2020-10-16T00:36:03: PM2 log: SIGTERM timeout      : 1600
                              PM2        | 2020-10-16T00:36:03: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T00:36:03: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T00:52:35: PM2 log: Stopping app:mm id:0
                              PM2        | 2020-10-16T00:52:35: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-10-16T00:52:35: PM2 log: pid=570 msg=process killed
                              PM2        | 2020-10-16T00:52:35: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T00:52:35: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T00:56:01: PM2 log: Stopping app:mm id:0
                              PM2        | 2020-10-16T00:56:01: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-10-16T00:56:01: PM2 log: pid=1655 msg=process killed
                              PM2        | 2020-10-16T00:56:01: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T00:56:01: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T00:56:26: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
                              PM2        | 2020-10-16T00:56:26: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T00:56:26: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T00:56:27: PM2 log: Stopping app:mm id:0
                              PM2        | 2020-10-16T00:56:27: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-10-16T00:56:27: PM2 log: pid=1881 msg=process killed
                              PM2        | 2020-10-16T00:56:27: PM2 log: PM2 successfully stopped
                              PM2        | 2020-10-16T00:56:36: PM2 log: ===============================================================================
                              PM2        | 2020-10-16T00:56:36: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                              PM2        | 2020-10-16T00:56:36: PM2 log: Time                 : Fri Oct 16 2020 00:56:36 GMT+0200 (GMT+02:00)
                              PM2        | 2020-10-16T00:56:36: PM2 log: PM2 version          : 4.4.1
                              PM2        | 2020-10-16T00:56:36: PM2 log: Node.js version      : 10.22.1
                              PM2        | 2020-10-16T00:56:36: PM2 log: Current arch         : arm
                              PM2        | 2020-10-16T00:56:36: PM2 log: PM2 home             : /home/pi/.pm2
                              PM2        | 2020-10-16T00:56:36: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                              PM2        | 2020-10-16T00:56:36: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                              PM2        | 2020-10-16T00:56:36: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                              PM2        | 2020-10-16T00:56:36: PM2 log: Application log path : /home/pi/.pm2/logs
                              PM2        | 2020-10-16T00:56:36: PM2 log: Worker Interval      : 30000
                              PM2        | 2020-10-16T00:56:36: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                              PM2        | 2020-10-16T00:56:36: PM2 log: Concurrent actions   : 2
                              PM2        | 2020-10-16T00:56:36: PM2 log: SIGTERM timeout      : 1600
                              PM2        | 2020-10-16T00:56:36: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T00:56:36: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T09:24:10: PM2 log: App [mm:0] exited with code [1] via signal [SIGINT]
                              PM2        | 2020-10-16T09:24:10: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T09:24:10: PM2 log: App [mm:0] online
                              PM2        | 2020-10-16T09:24:11: PM2 log: Stopping app:mm id:0
                              PM2        | 2020-10-16T09:24:11: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                              PM2        | 2020-10-16T09:24:11: PM2 log: pid=4365 msg=process killed
                              PM2        | 2020-10-16T09:24:11: PM2 log: PM2 successfully stopped
                              PM2        | 2020-10-16T09:24:20: PM2 log: ===============================================================================
                              PM2        | 2020-10-16T09:24:20: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                              PM2        | 2020-10-16T09:24:20: PM2 log: Time                 : Fri Oct 16 2020 09:24:20 GMT+0200 (GMT+02:00)
                              PM2        | 2020-10-16T09:24:20: PM2 log: PM2 version          : 4.4.1
                              PM2        | 2020-10-16T09:24:20: PM2 log: Node.js version      : 10.22.1
                              PM2        | 2020-10-16T09:24:20: PM2 log: Current arch         : arm
                              PM2        | 2020-10-16T09:24:20: PM2 log: PM2 home             : /home/pi/.pm2
                              PM2        | 2020-10-16T09:24:20: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                              PM2        | 2020-10-16T09:24:20: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                              PM2        | 2020-10-16T09:24:20: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                              PM2        | 2020-10-16T09:24:20: PM2 log: Application log path : /home/pi/.pm2/logs
                              PM2        | 2020-10-16T09:24:20: PM2 log: Worker Interval      : 30000
                              PM2        | 2020-10-16T09:24:20: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                              PM2        | 2020-10-16T09:24:20: PM2 log: Concurrent actions   : 2
                              PM2        | 2020-10-16T09:24:20: PM2 log: SIGTERM timeout      : 1600
                              PM2        | 2020-10-16T09:24:20: PM2 log: App [mm:0] starting in -fork mode-
                              PM2        | 2020-10-16T09:24:20: PM2 log: App [mm:0] online
                              0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32)
                              0|mm       | [2020-10-16 00:56:49.646] [ERROR]  Whoops! There was an uncaught exception...
                              0|mm       | [2020-10-16 00:56:49.647] [ERROR]  Error: Cannot find module 'node-ical'
                              0|mm       | -
                              0|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                              0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                              0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                              0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                              0|mm       |     at Module.require (internal/modules/cjs/loader.js:685:19)
                              0|mm       |     at require (internal/modules/cjs/helpers.js:16:16)
                              0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                              0|mm       |     at Module._compile (internal/modules/cjs/loader.js:786:30)
                              0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                              0|mm       |     at Module.load (internal/modules/cjs/loader.js:645:32) {
                              0|mm       |   code: 'MODULE_NOT_FOUND',
                              0|mm       |   requireStack: [
                              0|mm       |     '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                              0|mm       |     '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                              0|mm       |     '/home/pi/MagicMirror/js/app.js',
                              0|mm       |     '/home/pi/MagicMirror/js/electron.js',
                              0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                              0|mm       |     undefined
                              0|mm       |   ]
                              0|mm       | }
                              0|mm       | [2020-10-16 00:56:49.652] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              0|mm       | [2020-10-16 00:56:49.652] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              0|mm       | npm ERR! code ELIFECYCLE
                              0|mm       | npm ERR! errno 1
                              0|mm       | npm ERR! magicmirror@2.14.0-develop start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                              0|mm       | npm ERR! Exit status 1
                              0|mm       | npm ERR!
                              0|mm       | npm ERR! Failed at the magicmirror@2.14.0-develop start script.
                              0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                              0|mm       |
                              0|mm       | npm ERR! A complete log of this run can be found in:
                              0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-10-16T07_24_10_332Z-debug.log
                              0|mm       | [2020-10-16 09:24:34.287] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-ical'
                              0|mm       | -
                              0|mm       | [2020-10-16 09:24:34.303] [ERROR]  App threw an error during load
                              0|mm       | [2020-10-16 09:24:34.304] [ERROR]  Error: Cannot find module 'node-ical'
                              0|mm       | -
                              0|mm       | [2020-10-16 09:24:34.307] [ERROR]  Whoops! There was an uncaught exception...
                              0|mm       | [2020-10-16 09:24:34.307] [ERROR]  Error: Cannot find module 'node-ical'
                              0|mm       | -
                              0|mm       |     undefined
                              0|mm       |   ]
                              0|mm       | }
                              0|mm       | [2020-10-16 09:24:34.316] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              0|mm       | [2020-10-16 09:24:34.317] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              0|mm       | [2020-10-16 00:52:41.518] [LOG]    Launching application.
                              0|mm       |
                              0|mm       | > magicmirror@2.14.0-develop start /home/pi/MagicMirror
                              0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                              0|mm       |
                              0|mm       | [2020-10-16 00:56:03.770] [LOG]    Starting MagicMirror: v2.14.0-develop
                              0|mm       | [2020-10-16 00:56:03.778] [LOG]    Loading config ...
                              0|mm       | [2020-10-16 00:56:03.785] [LOG]    Loading module helpers ...
                              0|mm       | [2020-10-16 00:56:03.787] [LOG]    No helper found for module: alert.
                              0|mm       | [2020-10-16 00:56:03.833] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:03.834] [LOG]    Module helper loaded: updatenotification
                              0|mm       | [2020-10-16 00:56:06.505] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:06.505] [LOG]    Module helper loaded: MMM-GoogleAssistant
                              0|mm       | [2020-10-16 00:56:07.591] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:07.591] [LOG]    Module helper loaded: MMM-Assistant2Display
                              0|mm       | [2020-10-16 00:56:07.848] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:07.849] [LOG]    Module helper loaded: MMM-UpdateNotification
                              0|mm       | [2020-10-16 00:56:07.854] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:07.855] [LOG]    Module helper loaded: MMM-DHT-Sensor
                              0|mm       | [2020-10-16 00:56:07.855] [LOG]    No helper found for module: clock.
                              0|mm       | [2020-10-16 00:56:07.864] [LOG]    Loading module helpers ...
                              0|mm       | [2020-10-16 00:56:07.865] [LOG]    No helper found for module: alert.
                              0|mm       | [2020-10-16 00:56:07.865] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:07.866] [LOG]    Module helper loaded: updatenotification
                              0|mm       | [2020-10-16 00:56:07.867] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:07.867] [LOG]    Module helper loaded: MMM-GoogleAssistant
                              0|mm       | [2020-10-16 00:56:07.868] [LOG]    Module helper loaded: MMM-Assistant2Display
                              0|mm       | [2020-10-16 00:56:07.868] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:07.869] [LOG]    Module helper loaded: MMM-UpdateNotification
                              0|mm       | [2020-10-16 00:56:07.869] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:07.870] [LOG]    Module helper loaded: MMM-DHT-Sensor
                              0|mm       | [2020-10-16 00:56:07.870] [LOG]    No helper found for module: clock.
                              0|mm       | [2020-10-16 00:56:07.972] [LOG]    Launching application.
                              0|mm       |
                              0|mm       |
                              0|mm       | [2020-10-16 00:56:42.884] [LOG]    Starting MagicMirror: v2.14.0-develop
                              0|mm       | [2020-10-16 00:56:42.911] [LOG]    Loading config ...
                              0|mm       | [2020-10-16 00:56:42.920] [LOG]    Loading module helpers ...
                              0|mm       | [2020-10-16 00:56:42.923] [LOG]    No helper found for module: alert.
                              0|mm       | [2020-10-16 00:56:43.001] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:43.002] [LOG]    Module helper loaded: updatenotification
                              0|mm       | [2020-10-16 00:56:47.278] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:47.280] [LOG]    Module helper loaded: MMM-GoogleAssistant
                              0|mm       | [2020-10-16 00:56:49.147] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:49.147] [LOG]    Module helper loaded: MMM-Assistant2Display
                              0|mm       | [2020-10-16 00:56:49.589] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:49.589] [LOG]    Module helper loaded: MMM-UpdateNotification
                              0|mm       | [2020-10-16 00:56:49.618] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:49.618] [LOG]    Module helper loaded: MMM-DHT-Sensor
                              0|mm       | [2020-10-16 00:56:49.620] [LOG]    No helper found for module: clock.
                              0|mm       | [2020-10-16 00:56:49.635] [LOG]    Loading module helpers ...
                              0|mm       | [2020-10-16 00:56:49.636] [LOG]    No helper found for module: alert.
                              0|mm       | [2020-10-16 00:56:49.636] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:49.637] [LOG]    Module helper loaded: updatenotification
                              0|mm       | [2020-10-16 00:56:49.637] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:49.638] [LOG]    Module helper loaded: MMM-GoogleAssistant
                              0|mm       | [2020-10-16 00:56:49.638] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:49.639] [LOG]    Module helper loaded: MMM-Assistant2Display
                              0|mm       | [2020-10-16 00:56:49.639] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:49.640] [LOG]    Module helper loaded: MMM-UpdateNotification
                              0|mm       | [2020-10-16 00:56:49.640] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 00:56:49.640] [LOG]    Module helper loaded: MMM-DHT-Sensor
                              0|mm       | [2020-10-16 00:56:49.641] [LOG]    No helper found for module: clock.
                              0|mm       | [2020-10-16 00:56:49.950] [LOG]    Launching application.
                              0|mm       |
                              0|mm       |
                              0|mm       | [2020-10-16 09:24:27.338] [LOG]    Starting MagicMirror: v2.14.0-develop
                              0|mm       | [2020-10-16 09:24:27.364] [LOG]    Loading config ...
                              0|mm       | [2020-10-16 09:24:27.376] [LOG]    Loading module helpers ...
                              0|mm       | [2020-10-16 09:24:27.379] [LOG]    No helper found for module: alert.
                              0|mm       | [2020-10-16 09:24:27.456] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:27.457] [LOG]    Module helper loaded: updatenotification
                              0|mm       | [2020-10-16 09:24:31.742] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:31.743] [LOG]    Module helper loaded: MMM-GoogleAssistant
                              0|mm       | [2020-10-16 09:24:33.721] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:33.724] [LOG]    Module helper loaded: MMM-Assistant2Display
                              0|mm       | [2020-10-16 09:24:34.210] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:34.211] [LOG]    Module helper loaded: MMM-UpdateNotification
                              0|mm       | [2020-10-16 09:24:34.262] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:34.263] [LOG]    Module helper loaded: MMM-DHT-Sensor
                              0|mm       | [2020-10-16 09:24:34.265] [LOG]    No helper found for module: clock.
                              0|mm       | [2020-10-16 09:24:34.288] [LOG]    Loading module helpers ...
                              0|mm       | [2020-10-16 09:24:34.289] [LOG]    No helper found for module: alert.
                              0|mm       | [2020-10-16 09:24:34.291] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:34.291] [LOG]    Module helper loaded: updatenotification
                              0|mm       | [2020-10-16 09:24:34.292] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:34.293] [LOG]    Module helper loaded: MMM-GoogleAssistant
                              0|mm       | [2020-10-16 09:24:34.294] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:34.295] [LOG]    Module helper loaded: MMM-Assistant2Display
                              0|mm       | [2020-10-16 09:24:34.296] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:34.296] [LOG]    Module helper loaded: MMM-UpdateNotification
                              0|mm       | [2020-10-16 09:24:34.297] [LOG]    Initializing new module helper ...
                              0|mm       | [2020-10-16 09:24:34.298] [LOG]    Module helper loaded: MMM-DHT-Sensor
                              0|mm       | [2020-10-16 09:24:34.299] [LOG]    No helper found for module: clock.
                              0|mm       | [2020-10-16 09:24:34.680] [LOG]    Launching application.
                              and this is an extraction of the red lines (so, the problem) of pm2 logs --lines =100 :
                              0|mm       | -
                                RIKKO14
                                should I do that ? :
                                rm -rf node_modules/electron
                                npm install electron@6.1.12
                                I see you request to someone to do that…
                                  sdetweil @RIKKO14
                                  @RIKKO14 over and over it says library package node-ical is missing.
                                  after you switch to the develop branch you MUST run npm install from the MagicMirror folder
                                    RIKKO14
                                    @sdetweil so this is what i wrote in the terminal :
                                    npm ERR!     /home/pi/.npm/_logs/2020-10-16T13_54_17_756Z-debug.log
                                    pi@raspberrypi:~/MagicMirror $ run npm install
                                    bash: run : commande introuvable
                                    cd ~/MagicMirror/ , npm install run npm install but there is a bash return : bash : run : commande introuvable
                                      sdetweil @RIKKO14
                                      @RIKKO14 ok
                                      do this
                                      rm -rf ~/MagicMirror/node_modules/ical
                                      then run the npm install again
                                        RIKKO14
                                        @sdetweil it’s work,
                                        T.H.A.N.K Y.O.U !!!
