    Could not resolve host
    6 Posts 2 Posters 2.4k Views 2 Watching
    • V Offline
      vvrangler
      Hello, I have seen few times in the logs the errors below.
      [2020-10-15 01:06:54.515] [ERROR]  fatal: unable to access 'https://github.com/Jopyth/MMM-Remote-Control.git/': Could not resolve host: github.com
      [2020-10-15 01:06:54.516] [ERROR]  fatal: unable to access 'https://github.com/BenRoe/MMM-SystemStats/': Could not resolve host: github.com
      [2020-10-15 01:06:54.516] [ERROR]  fatal: unable to access 'https://github.com/mykle1/MMM-Events/': Could not resolve host: github.com
      [2020-10-15 01:06:54.540] [ERROR]  fatal: unable to access 'https://github.com/jclarke0000/MMM-DarkSkyForecast.git/': Could not resolve host: github.com
      [2020-10-15 01:06:54.551] [ERROR]  fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/': Could not resolve host: github.com
      Does anyone know if this is more likely related to local internet connectivity or something external and if there are any ways to resolve it.
      Thank you kindly,
      Rick
        sdetweil @vvrangler
        @vvrangler this is the updatenotification module trying to check to see if there are updates to modules you use
        do you use pihole or somesuch?
        • V Offline
          vvrangler @sdetweil
          @sdetweil No, I do not run any DNS blocking tools locally.
            sdetweil @vvrangler
            @vvrangler hm… they all happened at the same time… network glitch…
            my internet dropped for about 1 minute yesterday… and then came back
            • V Offline
              vvrangler @sdetweil
              @sdetweil Yes, I am not very confident in my Internet sometimes! I work from home and I see my connection to the office drop for a few seconds on average every day. I am also trying to rule that out as a possible cause for some mysterious lockups where the MM and RPi appear to still be running but I lose VNC connectivity and eventually have to pull the plug to reboot :-(
                sdetweil @vvrangler
                @vvrangler i run all my sbcs on a battery (ups) to avoid power issues and mostly wired ethernet to avoid wifi issues…
                but see occasional unresponsive systems too
