    Update auf 2.13.0
    65 Posts 4 Posters 21.6k Views 4 Watching
    • kusselinK Offline
      kusselin
      habe eben probiert das update zu machen mit folgendem Befehl:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      dann kommt aber folgende Melsung:
      pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetwe                 il/MagicMirror_scripts/master/upgrade-script.sh)" apply
      No LSB modules are available.
      doing test run = false
      update log will be in /home/pi/MagicMirror/installers/upgrade.log
      saving custom.css
      upgrading from version 2.9.0 to 2.13.0
      fetching latest revisions
      error: cannot lock ref 'refs/tags/v2.12.0': unable to resolve reference 'refs/ta                 gs/v2.12.0': reference broken
      From https://github.com/MichMich/MagicMirror
       ! [new tag]           v2.12.0    -> v2.12.0  (unable to update local ref)
      MagicMirror git fetch failed
      restoring custom.css
      Wo ist mein Fehler?
      Gruss
        sdetweil @kusselin
        @kusselin let me look. can u send me the upgrade.log from the installers folder?
        my email in this same userid at gmail
        • kusselinK Offline
          kusselin
          @sdetweil said in Update auf 2.13.0:
          Upgrade started - So Nov 15 12:26:19 CET 2020
          system is Linux raspberrypi 5.4.72-v7+ #1356 SMP Thu Oct 22 13:56:54 BST 2020 armv7l GNU/Linux
          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
          user requested to apply changes
          saving custom.css
          remote name = origin
          git fetch rc=1
          removing git alias
          Upgrade ended - So Nov 15 12:26:23 CET 2020
          Upgrade started - So Nov 15 12:26:55 CET 2020
          saving custom.css
          git fetch rc=1
          removing git alias
          Upgrade ended - So Nov 15 12:26:59 CET 2020
          Upgrade started - So Nov 15 12:27:33 CET 2020
          doing test run = true, NO updates will be applied!
          saving custom.css
          git fetch rc=1
          removing git alias
          Upgrade ended - So Nov 15 12:27:37 CET 2020
            sdetweil @kusselin
            @kusselin try this
            git remote prune origin
            then run in test mode (no apply param)
            • kusselinK Offline
              kusselin
              hi sdetweil schau hier:
              pi@raspberrypi:~/MagicMirror $ git remote prune origin
              pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              saving custom.css
              error: cannot lock ref 'refs/tags/v2.12.0': unable to resolve reference 'refs/tags/v2.12.0': reference broken
              das gleiche wieder :-(
                sdetweil @kusselin
                @kusselin said in Update auf 2.13.0:
                reference broken
                ok, one more time
                git gc --prune=now
                then script again
                • kusselinK Offline
                  kusselin
                  pi@raspberrypi:~ $ cd MagicMirror
                  pi@raspberrypi:~/MagicMirror $ git gc --prune=now
                  fatal: bad object refs/tags/v2.12.0
                  fatal: failed to run repack
                  saving custom.css
                    sdetweil
                    ok, another try
                    git remote set-head origin --auto
                    git gc --prune=now
                    • kusselinK Offline
                      kusselin
                      saving custom.css
                      Wo ist das Problem…ist klar…bei mir läuft nie was auf Anhieb :-(
                      der Pi ist auf aktuellem Stand mit update && upgrade
                        sdetweil
                        something has happened to the git repo, it has lost a reference
                        we are trying to clean it up
                        one more time (note there is a dot in front of git/)
                        mv .git/refs/remotes/origin/HEAD /tmp
                        git gc --prune=now
                        • 6
                        • 7
                        • 7 / 7
