    Update auf 2.13.0
    65 Posts 4 Posters 31.6k Views 4 Watching
      sdetweil @kusselin
      @kusselin this is ON the mirror system right?
      or you did
      address: "0.0.0.0",
      ipWhitelist:[],
      or your pi, so you can open browser from pc
      • kusselinK
        kusselin
        Initializing MagicMirror. main.js:487:8
        Loading core translation file: translations/de.json translator.js:129:9
        Loading core translation fallback file: translations/en.json translator.js:154:9
        Load script: modules/default/alert//alert.js loader.js:176:9
        Module registered: alert module.js:513:6
        Bootstrapping module: alert loader.js:148:7
        Load script: modules/default/alert/notificationFx.js loader.js:176:9
        Scripts loaded for: alert loader.js:153:8
        Load stylesheet: modules/default/alert/notificationFx.css loader.js:195:9
        Load stylesheet: vendor/css/font-awesome.css loader.js:195:9
        Styles loaded for: alert loader.js:155:9
        alert - Load translation: translations/de.json translator.js:100:9
        alert - Load translation fallback: translations/en.json translator.js:102:9
        Translations loaded for: alert loader.js:157:10
        Load script: modules/default/updatenotification//updatenotification.js loader.js:176:9
        Module registered: updatenotification module.js:513:6
        Bootstrapping module: updatenotification loader.js:148:7
        Scripts loaded for: updatenotification loader.js:153:8
        Styles loaded for: updatenotification loader.js:155:9
        Translations loaded for: updatenotification loader.js:157:10
        Load script: modules/default/clock//clock.js loader.js:176:9
        Module registered: clock module.js:513:6
        Bootstrapping module: clock loader.js:148:7
        Load script: vendor/node_modules/moment/min/moment-with-locales.js loader.js:176:9
        Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js loader.js:176:9
        Load script: vendor/node_modules/suncalc/suncalc.js loader.js:176:9
        Scripts loaded for: clock loader.js:153:8
        Load stylesheet: modules/default/clock/clock_styles.css loader.js:195:9
        Styles loaded for: clock loader.js:155:9
        Translations loaded for: clock loader.js:157:10
        Load script: modules/default/calendar//calendar.js loader.js:176:9
        Module registered: calendar module.js:513:6
        Bootstrapping module: calendar loader.js:148:7
        File already loaded: moment.js loader.js:236:9
        Scripts loaded for: calendar loader.js:153:8
        Load stylesheet: modules/default/calendar/calendar.css loader.js:195:9
        File already loaded: font-awesome.css loader.js:236:9
        Styles loaded for: calendar loader.js:155:9
        Translations loaded for: calendar loader.js:157:10
        File already loaded: calendar.css loader.js:236:9
        Load script: modules/MMM-OpenmapWeather//MMM-OpenmapWeather.js loader.js:176:9
        Module registered: MMM-OpenmapWeather module.js:513:6
        Bootstrapping module: MMM-OpenmapWeather loader.js:148:7
        Scripts loaded for: MMM-OpenmapWeather loader.js:153:8
        Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css loader.js:195:9
        Load stylesheet: modules/MMM-OpenmapWeather/MMM-OpenmapWeather.css loader.js:195:9
        Styles loaded for: MMM-OpenmapWeather loader.js:155:9
        Translations loaded for: MMM-OpenmapWeather loader.js:157:10
        Load script: modules/default/weatherforecast//weatherforecast.js loader.js:176:9
        Module registered: weatherforecast module.js:513:6
        Bootstrapping module: weatherforecast loader.js:148:7
        Scripts loaded for: weatherforecast loader.js:153:8
        File already loaded: weather-icons.css loader.js:236:9
        Load stylesheet: modules/default/weatherforecast/weatherforecast.css loader.js:195:9
        Styles loaded for: weatherforecast loader.js:155:9
        Translations loaded for: weatherforecast loader.js:157:10
        Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js loader.js:176:9
        Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.4.0 - Current version: 2.13.0 module.js:505:7
        Version is ok! module.js:507:8
        Module registered: MMM-Remote-Control module.js:513:6
        Bootstrapping module: MMM-Remote-Control loader.js:148:7
        Scripts loaded for: MMM-Remote-Control loader.js:153:8
        Load stylesheet: modules/MMM-Remote-Control/remote-control.css loader.js:195:9
        Styles loaded for: MMM-Remote-Control loader.js:155:9
        Translations loaded for: MMM-Remote-Control loader.js:157:10
        Load script: modules/MMM-SoccerLiveScore//MMM-SoccerLiveScore.js loader.js:176:9
        Module registered: MMM-SoccerLiveScore module.js:513:6
        Bootstrapping module: MMM-SoccerLiveScore loader.js:148:7
        Scripts loaded for: MMM-SoccerLiveScore loader.js:153:8
        Load stylesheet: modules/MMM-SoccerLiveScore/MMM-SoccerLiveScore.css loader.js:195:9
        Styles loaded for: MMM-SoccerLiveScore loader.js:155:9
        Translations loaded for: MMM-SoccerLiveScore loader.js:157:10
        Load script: modules/MMM-Tankerkoenig//MMM-Tankerkoenig.js loader.js:176:9
        Check MagicMirror version for module 'MMM-Tankerkoenig' - Minimum version:  2.2.0 - Current version: 2.13.0 module.js:505:7
        Module registered: MMM-Tankerkoenig module.js:513:6
        Bootstrapping module: MMM-Tankerkoenig loader.js:148:7
        Scripts loaded for: MMM-Tankerkoenig loader.js:153:8
        Load stylesheet: modules/MMM-Tankerkoenig/MMM-Tankerkoenig.css loader.js:195:9
        Styles loaded for: MMM-Tankerkoenig loader.js:155:9
        MMM-Tankerkoenig - Load translation: i18n/de.json translator.js:100:9
        MMM-Tankerkoenig - Load translation fallback: i18n/en.json translator.js:102:9
        Translations loaded for: MMM-Tankerkoenig loader.js:157:10
        Load script: modules/MMM-SmartWebDisplay//MMM-SmartWebDisplay.js loader.js:176:9
        Module registered: MMM-SmartWebDisplay module.js:513:6
        Bootstrapping module: MMM-SmartWebDisplay loader.js:148:7
        Scripts loaded for: MMM-SmartWebDisplay loader.js:153:8
        Load stylesheet: modules/MMM-SmartWebDisplay/MMM-SmartWebDisplay.css loader.js:195:9
        Styles loaded for: MMM-SmartWebDisplay loader.js:155:9
        Translations loaded for: MMM-SmartWebDisplay loader.js:157:10
        Load script: modules/MMM-ioBroker//MMM-ioBroker.js loader.js:176:9
        Module registered: MMM-ioBroker module.js:513:6
        Bootstrapping module: MMM-ioBroker loader.js:148:7
        Scripts loaded for: MMM-ioBroker loader.js:153:8
        Load stylesheet: modules/MMM-ioBroker/MMM-ioBroker.css loader.js:195:9
        Styles loaded for: MMM-ioBroker loader.js:155:9
        Translations loaded for: MMM-ioBroker loader.js:157:10
        Load script: modules/MMM-FRITZ-Box-Callmonitor//MMM-FRITZ-Box-Callmonitor.js loader.js:176:9
        Check MagicMirror version for module 'MMM-FRITZ-Box-Callmonitor' - Minimum version:  2.0.0 - Current version: 2.13.0 module.js:505:7
        Module registered: MMM-FRITZ-Box-Callmonitor module.js:513:6
        Bootstrapping module: MMM-FRITZ-Box-Callmonitor loader.js:148:7
        Scripts loaded for: MMM-FRITZ-Box-Callmonitor loader.js:153:8
        Load stylesheet: modules/MMM-FRITZ-Box-Callmonitor/MMM-FRITZ-Box-Callmonitor.css loader.js:195:9
        Styles loaded for: MMM-FRITZ-Box-Callmonitor loader.js:155:9
        MMM-FRITZ-Box-Callmonitor - Load translation: translations/de.json translator.js:100:9
        Uncaught SyntaxError: JSON.parse: expected double-quoted property name at line 5 column 3 of the JSON data
            onreadystatechange http://192.168.200.151:8080/js/translator.js:22
        translator.js:22:19
          sdetweil @kusselin
          @kusselin said in Update auf 2.13.0:
          yes, this is the translation file error
          edit the MMM-FRITZ-Box-Callmonitor/translations/de.json and remove the comment
            // keep the error messages short
          • kusselinK
            kusselin
            @sdetweil said in Update auf 2.13.0:
            Hi Sam,
            this is the de.json in the translation folder of MM-Fritzbox Callmonitor:
              "title": "Eingehender Anruf",
              "noCall": "Keine kürzlichen Anrufe.",
              "calllist_parse_error": "Anrufliste unlesbar.",
              "phonebook_parse_error": "Telefonbuch unlesbar.",
              "vcf_parse_error": "vCard unlesbar.",
              "login_error": "Logindaten falsch?",
              "network_error": "FRITZ!Box nicht erreichbar.",
              "unknown_error": "Unbekannter Fehler."
            and what musst i do now and edit? Sorry for my questions…and you thanks
            • kusselinK
              kusselin
              o.k…the newest stand. I have deinstalled the MM-Callmonitor an now i can see the MM on my screen.
              Thanks a lot sdetweil.
                sdetweil @kusselin
                @kusselin on your paste of the de.json
                Remove the line that starts with
                Comments are not allowed in json
                • kusselinK
                  kusselin
                  o.k. danke
                  • A
                    anderios Banned
                    hi, i think, i have the config and I have to install magic mirror new
                      sdetweil @anderios
                      @anderios what?
                      To install, use the install script, see here
                      • A
                        anderios Banned
                        Hi guys, so much useful information. I have a brain explosion, and I did not expect to find all this here.
                        I was already in despair, I thought that I would order an assignment on the Internet and use the services of the marketing assignment help service.
                        But now I understand that I can do everything myself. Guys, thank you for creating this forum and share such useful information.
                        How glad I am that I decided to drop by for a few minutes and wasted my time for that. Many thanks to everyone.
                        • 4 / 4
