    Update auf 2.13.0
    65 Posts 4 Posters 30.2k Views 4 Watching
    • kusselinK Offline
      kusselin
      @sdetweil said in Update auf 2.13.0:
      git checkout develop
      o.k. can you help me once again please that i have a picture…
      pi@raspberrypi:~ $ cd MagicMirror
      pi@raspberrypi:~/MagicMirror $ git checkout develop
      error: Pfadspezifikation 'develop' stimmt mit keinen git-bekannten Dateien überein.
        sdetweil @kusselin
        @kusselin see here
        https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix/2
        • kusselinK Offline
          kusselin
          sorry…its not going with:
          git fetch origin develop:develop
          after a restart i see fast an white screen and the the black screen :-( and nothing happend
            sdetweil @kusselin
            @kusselin open the developers console, ctrl-shit-i on the mirror, or chrome from your pc if allowed,
            select the tab labeled ‘console’, and scroll up to see any errors…
            • kusselinK Offline
              kusselin
              i can´t see a mistake…you?
                sdetweil @kusselin
                @kusselin select the tab labeled ‘console’,
                • kusselinK Offline
                  kusselin
                  i haven´t it
                    sdetweil @kusselin
                    @kusselin this is ON the mirror system right?
                    or you did
                    address: "0.0.0.0",
                    ipWhitelist:[],
                    or your pi, so you can open browser from pc
                    • kusselinK Offline
                      kusselin
                      Initializing MagicMirror. main.js:487:8
                      Loading core translation file: translations/de.json translator.js:129:9
                      Loading core translation fallback file: translations/en.json translator.js:154:9
                      Load script: modules/default/alert//alert.js loader.js:176:9
                      Module registered: alert module.js:513:6
                      Bootstrapping module: alert loader.js:148:7
                      Load script: modules/default/alert/notificationFx.js loader.js:176:9
                      Scripts loaded for: alert loader.js:153:8
                      Load stylesheet: modules/default/alert/notificationFx.css loader.js:195:9
                      Load stylesheet: vendor/css/font-awesome.css loader.js:195:9
                      Styles loaded for: alert loader.js:155:9
                      alert - Load translation: translations/de.json translator.js:100:9
                      alert - Load translation fallback: translations/en.json translator.js:102:9
                      Translations loaded for: alert loader.js:157:10
                      Load script: modules/default/updatenotification//updatenotification.js loader.js:176:9
                      Module registered: updatenotification module.js:513:6
                      Bootstrapping module: updatenotification loader.js:148:7
                      Scripts loaded for: updatenotification loader.js:153:8
                      Styles loaded for: updatenotification loader.js:155:9
                      Translations loaded for: updatenotification loader.js:157:10
                      Load script: modules/default/clock//clock.js loader.js:176:9
                      Module registered: clock module.js:513:6
                      Bootstrapping module: clock loader.js:148:7
                      Load script: vendor/node_modules/moment/min/moment-with-locales.js loader.js:176:9
                      Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js loader.js:176:9
                      Load script: vendor/node_modules/suncalc/suncalc.js loader.js:176:9
                      Scripts loaded for: clock loader.js:153:8
                      Load stylesheet: modules/default/clock/clock_styles.css loader.js:195:9
                      Styles loaded for: clock loader.js:155:9
                      Translations loaded for: clock loader.js:157:10
                      Load script: modules/default/calendar//calendar.js loader.js:176:9
                      Module registered: calendar module.js:513:6
                      Bootstrapping module: calendar loader.js:148:7
                      File already loaded: moment.js loader.js:236:9
                      Scripts loaded for: calendar loader.js:153:8
                      Load stylesheet: modules/default/calendar/calendar.css loader.js:195:9
                      File already loaded: font-awesome.css loader.js:236:9
                      Styles loaded for: calendar loader.js:155:9
                      Translations loaded for: calendar loader.js:157:10
                      File already loaded: calendar.css loader.js:236:9
                      Load script: modules/MMM-OpenmapWeather//MMM-OpenmapWeather.js loader.js:176:9
                      Module registered: MMM-OpenmapWeather module.js:513:6
                      Bootstrapping module: MMM-OpenmapWeather loader.js:148:7
                      Scripts loaded for: MMM-OpenmapWeather loader.js:153:8
                      Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css loader.js:195:9
                      Load stylesheet: modules/MMM-OpenmapWeather/MMM-OpenmapWeather.css loader.js:195:9
                      Styles loaded for: MMM-OpenmapWeather loader.js:155:9
                      Translations loaded for: MMM-OpenmapWeather loader.js:157:10
                      Load script: modules/default/weatherforecast//weatherforecast.js loader.js:176:9
                      Module registered: weatherforecast module.js:513:6
                      Bootstrapping module: weatherforecast loader.js:148:7
                      Scripts loaded for: weatherforecast loader.js:153:8
                      File already loaded: weather-icons.css loader.js:236:9
                      Load stylesheet: modules/default/weatherforecast/weatherforecast.css loader.js:195:9
                      Styles loaded for: weatherforecast loader.js:155:9
                      Translations loaded for: weatherforecast loader.js:157:10
                      Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js loader.js:176:9
                      Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.4.0 - Current version: 2.13.0 module.js:505:7
                      Version is ok! module.js:507:8
                      Module registered: MMM-Remote-Control module.js:513:6
                      Bootstrapping module: MMM-Remote-Control loader.js:148:7
                      Scripts loaded for: MMM-Remote-Control loader.js:153:8
                      Load stylesheet: modules/MMM-Remote-Control/remote-control.css loader.js:195:9
                      Styles loaded for: MMM-Remote-Control loader.js:155:9
                      Translations loaded for: MMM-Remote-Control loader.js:157:10
                      Load script: modules/MMM-SoccerLiveScore//MMM-SoccerLiveScore.js loader.js:176:9
                      Module registered: MMM-SoccerLiveScore module.js:513:6
                      Bootstrapping module: MMM-SoccerLiveScore loader.js:148:7
                      Scripts loaded for: MMM-SoccerLiveScore loader.js:153:8
                      Load stylesheet: modules/MMM-SoccerLiveScore/MMM-SoccerLiveScore.css loader.js:195:9
                      Styles loaded for: MMM-SoccerLiveScore loader.js:155:9
                      Translations loaded for: MMM-SoccerLiveScore loader.js:157:10
                      Load script: modules/MMM-Tankerkoenig//MMM-Tankerkoenig.js loader.js:176:9
                      Check MagicMirror version for module 'MMM-Tankerkoenig' - Minimum version:  2.2.0 - Current version: 2.13.0 module.js:505:7
                      Module registered: MMM-Tankerkoenig module.js:513:6
                      Bootstrapping module: MMM-Tankerkoenig loader.js:148:7
                      Scripts loaded for: MMM-Tankerkoenig loader.js:153:8
                      Load stylesheet: modules/MMM-Tankerkoenig/MMM-Tankerkoenig.css loader.js:195:9
                      Styles loaded for: MMM-Tankerkoenig loader.js:155:9
                      MMM-Tankerkoenig - Load translation: i18n/de.json translator.js:100:9
                      MMM-Tankerkoenig - Load translation fallback: i18n/en.json translator.js:102:9
                      Translations loaded for: MMM-Tankerkoenig loader.js:157:10
                      Load script: modules/MMM-SmartWebDisplay//MMM-SmartWebDisplay.js loader.js:176:9
                      Module registered: MMM-SmartWebDisplay module.js:513:6
                      Bootstrapping module: MMM-SmartWebDisplay loader.js:148:7
                      Scripts loaded for: MMM-SmartWebDisplay loader.js:153:8
                      Load stylesheet: modules/MMM-SmartWebDisplay/MMM-SmartWebDisplay.css loader.js:195:9
                      Styles loaded for: MMM-SmartWebDisplay loader.js:155:9
                      Translations loaded for: MMM-SmartWebDisplay loader.js:157:10
                      Load script: modules/MMM-ioBroker//MMM-ioBroker.js loader.js:176:9
                      Module registered: MMM-ioBroker module.js:513:6
                      Bootstrapping module: MMM-ioBroker loader.js:148:7
                      Scripts loaded for: MMM-ioBroker loader.js:153:8
                      Load stylesheet: modules/MMM-ioBroker/MMM-ioBroker.css loader.js:195:9
                      Styles loaded for: MMM-ioBroker loader.js:155:9
                      Translations loaded for: MMM-ioBroker loader.js:157:10
                      Load script: modules/MMM-FRITZ-Box-Callmonitor//MMM-FRITZ-Box-Callmonitor.js loader.js:176:9
                      Check MagicMirror version for module 'MMM-FRITZ-Box-Callmonitor' - Minimum version:  2.0.0 - Current version: 2.13.0 module.js:505:7
                      Module registered: MMM-FRITZ-Box-Callmonitor module.js:513:6
                      Bootstrapping module: MMM-FRITZ-Box-Callmonitor loader.js:148:7
                      Scripts loaded for: MMM-FRITZ-Box-Callmonitor loader.js:153:8
                      Load stylesheet: modules/MMM-FRITZ-Box-Callmonitor/MMM-FRITZ-Box-Callmonitor.css loader.js:195:9
                      Styles loaded for: MMM-FRITZ-Box-Callmonitor loader.js:155:9
                      MMM-FRITZ-Box-Callmonitor - Load translation: translations/de.json translator.js:100:9
                      Uncaught SyntaxError: JSON.parse: expected double-quoted property name at line 5 column 3 of the JSON data
                          onreadystatechange http://192.168.200.151:8080/js/translator.js:22
                      translator.js:22:19
                        sdetweil @kusselin
                        @kusselin said in Update auf 2.13.0:
                        yes, this is the translation file error
                        edit the MMM-FRITZ-Box-Callmonitor/translations/de.json and remove the comment
                          // keep the error messages short
                        • kusselinK Offline
                          kusselin
                          Hi Sam,
                          this is the de.json in the translation folder of MM-Fritzbox Callmonitor:
                            "title": "Eingehender Anruf",
                            "noCall": "Keine kürzlichen Anrufe.",
                            "calllist_parse_error": "Anrufliste unlesbar.",
                            "phonebook_parse_error": "Telefonbuch unlesbar.",
                            "vcf_parse_error": "vCard unlesbar.",
                            "login_error": "Logindaten falsch?",
                            "network_error": "FRITZ!Box nicht erreichbar.",
                            "unknown_error": "Unbekannter Fehler."
                          and what musst i do now and edit? Sorry for my questions…and you thanks
                          • kusselinK Offline
                            kusselin
                            o.k…the newest stand. I have deinstalled the MM-Callmonitor an now i can see the MM on my screen.
                            Thanks a lot sdetweil.
                              sdetweil @kusselin
                              @kusselin on your paste of the de.json
                              Remove the line that starts with
                              Comments are not allowed in json
                              • kusselinK Offline
                                kusselin
                                o.k. danke
                                  anderios Banned
                                  hi, i think, i have the config and I have to install magic mirror new
                                    sdetweil @anderios
                                    @anderios what?
                                    To install, use the install script, see here
                                      anderios Banned
                                      Hi guys, so much useful information. I have a brain explosion, and I did not expect to find all this here.
                                      I was already in despair, I thought that I would order an assignment on the Internet and use the services of the marketing assignment help service.
                                      But now I understand that I can do everything myself. Guys, thank you for creating this forum and share such useful information.
                                      How glad I am that I decided to drop by for a few minutes and wasted my time for that. Many thanks to everyone.
                                      • 3 / 4
