    Update auf 2.13.0
    65 Posts 4 Posters 31.6k Views 4 Watching
    • kusselinK
      kusselin
      no, nothing is good…sorry:
      i have a black screen :-(
      > magicmirror@2.13.0 start /home/pi/MagicMirror
      > ./run-start.sh $1
      [2020-11-15 18:39:25.557] [LOG]    Starting MagicMirror: v2.13.0
      [2020-11-15 18:39:25.648] [LOG]    Loading config ...
      [2020-11-15 18:39:25.691] [LOG]    Loading module helpers ...
      [2020-11-15 18:39:25.703] [LOG]    No helper found for module: alert.
      [2020-11-15 18:39:26.107] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:26.112] [LOG]    Module helper loaded: updatenotification
      [2020-11-15 18:39:26.117] [LOG]    No helper found for module: clock.
      [2020-11-15 18:39:30.439] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:30.444] [LOG]    Module helper loaded: calendar
      [2020-11-15 18:39:30.451] [LOG]    No helper found for module: MMM-OpenmapWeather.
      [2020-11-15 18:39:30.457] [LOG]    No helper found for module: weatherforecast.
      [2020-11-15 18:39:31.996] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:32.001] [LOG]    Module helper loaded: MMM-Remote-Control
      [2020-11-15 18:39:32.030] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:32.039] [LOG]    Module helper loaded: MMM-SoccerLiveScore
      [2020-11-15 18:39:32.059] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:32.062] [LOG]    Module helper loaded: MMM-Tankerkoenig
      [2020-11-15 18:39:32.069] [LOG]    No helper found for module: MMM-SmartWebDisplay.
      [2020-11-15 18:39:32.099] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:32.107] [LOG]    Module helper loaded: MMM-ioBroker
      [2020-11-15 18:39:33.022] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:33.024] [LOG]    Module helper loaded: MMM-FRITZ-Box-Callmonitor
      [2020-11-15 18:39:33.475] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:33.482] [LOG]    Module helper loaded: MMM-Fuel
      [2020-11-15 18:39:34.691] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:34.693] [LOG]    Module helper loaded: MMM-PublicTransportHafas
      [2020-11-15 18:39:34.696] [LOG]    No helper found for module: compliments.
      [2020-11-15 18:39:35.002] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:35.010] [LOG]    Module helper loaded: MMM-Tools
      [2020-11-15 18:39:35.216] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:35.222] [LOG]    Module helper loaded: newsfeed
      [2020-11-15 18:39:35.239] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:35.245] [LOG]    Module helper loaded: MMM-COVID19
      [2020-11-15 18:39:35.264] [LOG]    Initializing new module helper ...
      [2020-11-15 18:39:35.270] [LOG]    Module helper loaded: MMM-COVID19-AMPEL
      [2020-11-15 18:39:35.275] [LOG]    All module helpers loaded.
      [2020-11-15 18:39:36.247] [LOG]    Starting server on port 8080 ...
      [2020-11-15 18:39:36.295] [INFO]   You're using a full whitelist configuration to allow for all IPs
      [2020-11-15 18:39:36.338] [LOG]    Server started ...
      [2020-11-15 18:39:36.347] [LOG]    Connecting socket for: updatenotification
      [2020-11-15 18:39:36.355] [LOG]    Connecting socket for: calendar
      [2020-11-15 18:39:36.359] [LOG]    Starting node helper for: calendar
      [2020-11-15 18:39:36.363] [LOG]    Connecting socket for: MMM-Remote-Control
      [2020-11-15 18:39:36.370] [LOG]    Starting node helper for: MMM-Remote-Control
      [2020-11-15 18:39:36.418] [LOG]    Connecting socket for: MMM-SoccerLiveScore
      [2020-11-15 18:39:36.424] [LOG]    MMM-SoccerLiveScore helper started...
      [2020-11-15 18:39:36.427] [LOG]    Connecting socket for: MMM-Tankerkoenig
      [2020-11-15 18:39:36.430] [LOG]    Starting module helper: MMM-Tankerkoenig
      [2020-11-15 18:39:36.435] [LOG]    Connecting socket for: MMM-ioBroker
      [2020-11-15 18:39:36.441] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
      [2020-11-15 18:39:36.446] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
      [2020-11-15 18:39:36.451] [LOG]    Connecting socket for: MMM-Fuel
      [2020-11-15 18:39:36.456] [LOG]    Starting module helper: MMM-Fuel
      [2020-11-15 18:39:36.459] [LOG]    Connecting socket for: MMM-PublicTransportHafas
      [2020-11-15 18:39:36.462] [LOG]    Connecting socket for: MMM-Tools
      [2020-11-15 18:39:36.468] [LOG]    [Tools] MMM-Tools Version: 2.0.3
      [2020-11-15 18:39:36.472] [LOG]    Connecting socket for: newsfeed
      [2020-11-15 18:39:36.476] [LOG]    Starting node helper for: newsfeed
      [2020-11-15 18:39:36.480] [LOG]    Connecting socket for: MMM-COVID19
      [2020-11-15 18:39:36.484] [LOG]    Starting node helper for: MMM-COVID19
      [2020-11-15 18:39:36.489] [LOG]    Connecting socket for: MMM-COVID19-AMPEL
      [2020-11-15 18:39:36.492] [LOG]    Starting node helper for: MMM-COVID19-AMPEL
      [2020-11-15 18:39:36.494] [LOG]    Sockets connected & modules started ...
      [2020-11-15 18:39:36.538] [ERROR]  Whoops! There was an uncaught exception...
      [2020-11-15 18:39:36.543] [ERROR]  Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
          at Server.setupListenHandle [as _listen2] (net.js:1226:14)
          at listenInCluster (net.js:1274:12)
          at doListen (net.js:1413:7)
          at processTicksAndRejections (internal/process/task_queues.js:84:9) {
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '0.0.0.0',
        port: 8080
      [2020-11-15 18:39:36.573] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-11-15 18:39:36.576] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-11-15 18:39:38.359] [LOG]    Launching application.
      Username for 'https://github.com':
        sdetweil @kusselin
        @kusselin said in Update auf 2.13.0:
        mirror already running…
        can’t run two at the same time… (on the same port)
        • kusselinK
          kusselin
          @sdetweil said in Update auf 2.13.0:
          o.k. and what can i do now…?
          Sorry for my questions but i´m not the expert as you
            sdetweil @kusselin
            @kusselin if you use pm2 to start a boot,
            pm2 stop all
            then npm start to test
            • kusselinK
              kusselin
              pi@raspberrypi:~ $ pm2 stop all
              [PM2] Applying action stopProcessId on app [all](ids: 0)
              [PM2] [MagicMirror](0) ✓
              │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
              │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
              pi@raspberrypi:~ $ npm start
              npm ERR! code ENOENT
              npm ERR! syscall open
              npm ERR! errno -2
              npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
              npm ERR! enoent This is related to npm not being able to find a file.
              npm ERR! enoent
              npm ERR!     /home/pi/.npm/_logs/2020-11-15T18_01_08_239Z-debug.log
                sdetweil @kusselin
                @kusselin from the MagicMirror folder
                • kusselinK
                  kusselin
                  username for github.com?
                  what ist this?
                    sdetweil @kusselin
                    @kusselin the updateNotification module if u don’t use it, u can disable it.
                    add
                    module:"updatenotification",
                    disabled: true,       // < this line
                    • kusselinK
                      kusselin
                      the screen is always black :-(
                      i ihink i have to save the config and i have to install magic mirror new…
                      what do you think?
                      • kusselinK
                        kusselin
                        after a new installation…can i also copie the save config and all is good?
                        S 2 Replies Last reply
                          sdetweil @kusselin
                          @kusselin upgrade didn’t touch the config, it should be the same as before
                            sdetweil @kusselin
                            @kusselin if a NEW install, then u would have to reinstall all the modules and update the config
                            • kusselinK
                              kusselin
                              o.k i musst have to install all the modules again and then i can copie the config in the config folder…right?
                              And please can you send me a link how i can install about the console the ltest magic mirror please…
                              • kusselinK
                                kusselin
                                can you tell me why the screen is now black?
                                  sdetweil @kusselin
                                  @kusselin install is the same place u got the upgrade script
                                  why are u trying to install again??
                                  black screen
                                  probably one of the lang files with comments
                                  switch to the develop branch
                                  git checkout develop
                                  • kusselinK
                                    kusselin
                                    o.k. can you help me once again please that i have a picture…
                                    pi@raspberrypi:~ $ cd MagicMirror
                                    pi@raspberrypi:~/MagicMirror $ git checkout develop
                                    error: Pfadspezifikation 'develop' stimmt mit keinen git-bekannten Dateien überein.
                                      sdetweil @kusselin
                                      @kusselin see here
                                      https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix/2
                                      • kusselinK
                                        kusselin
                                        sorry…its not going with:
                                        git fetch origin develop:develop
                                        after a restart i see fast an white screen and the the black screen :-( and nothing happend
                                          sdetweil @kusselin
                                          @kusselin open the developers console, ctrl-shit-i on the mirror, or chrome from your pc if allowed,
                                          select the tab labeled ‘console’, and scroll up to see any errors…
                                          • kusselinK
                                            kusselin
                                            i can´t see a mistake…you?
                                            • 3 / 4
