    Update auf 2.13.0
    65 Posts 4 Posters 31.6k Views 4 Watching
    • kusselinK
      kusselin
      o.k. but one question…must i update my magic mirror? now it runs good…an i know there is a statement:
      “NEVER CHANGE A RUNNING SYSTEM”
      what you say?
        sdetweil @kusselin
        @kusselin you do NOT HAVE to update, unless u have a problem , or unless u need a new feature…
        • kusselinK
          kusselin
          i risk it … with “SAVE” now …pleas wait while updating… i will get back to you soon
          How long does the update while?
            sdetweil @kusselin
            @kusselin maybe 30 minutes
            • kusselinK
              kusselin
              ui …ok. thats a house number…
              i will back then
              for you first thanks a lot :-)
              • kusselinK
                kusselin
                look…can you say something about this installation now?
                pi@raspberrypi:~/MagicMirror $ bash -c  "$(curl -sL https://raw.githubuserconten        t.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                No LSB modules are available.
                doing test run = false
                saving custom.css
                upgrading from version 2.9.0 to 2.13.0
                fetching latest revisions
                there are 2 local files that are different than the master repo
                   modules/default/compliments/compliments.js
                   package-lock.json
                any *-lock.json files do not need to be saved
                do you want to save these files for later   (Y/n)?Y
                > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stam        p
                > node ./msg.js
                Attention
                    Console-stamp version 3.0.0 Release Candidate is out. Install by using the t        ag '@next'. NB: Breaking changes.
                    For more details goto: https://www.npmjs.com/package/console-stamp/v/next
                > electron@6.1.12 postinstall /home/pi/MagicMirror/node_modules/electron
                > node install.js
                Downloading tmp-16303-1-SHASUMS256.txt-6.1.12
                [============================================>] 100.0% of 5.62 kB (5.62 kB/s)
                > magicmirror@2.13.0 install /home/pi/MagicMirror
                " && cd vendor && npm install --loglevel=error
                added 3 packages from 3 contributors, removed 62 packages, updated 17 packages and audited 24 packages in 38.077s
                1 package is looking for funding
                  run `npm fund` for details
                found 0 vulnerabilities
                > magicmirror@2.13.0 postinstall /home/pi/MagicMirror
                > npm run install-fonts && echo "MagicMirror installation finished successfully!
                > magicmirror@2.13.0 install-fonts /home/pi/MagicMirror
                > echo "Installing fonts ...
                " && cd fonts && npm install --loglevel=error
                updated 1 package and audited 1 package in 8.1s
                added 81 packages from 60 contributors, removed 340 packages, updated 119 packages and audited 1164 packages in 928.05s
                9 packages are looking for funding
                found 3 low severity vulnerabilities
                  run `npm audit fix` to fix them, or `npm audit` for details
                processing for module MMM-Remote-Control please wait
                npm notice created a lockfile as package-lock.json. You should commit this file.
                added 30 packages from 24 contributors and audited 30 packages in 22.948s
                processing complete for module MMM-Remote-Control
                processing for module MMM-SoccerLiveScore please wait
                up to date in 2.55s
                processing complete for module MMM-SoccerLiveScore
                processing for module MMM-SmartWebDisplay please wait
                added 93 packages from 86 contributors and audited 94 packages in 49.515s
                processing complete for module MMM-SmartWebDisplay
                processing for module MMM-ioBroker please wait
                added 41 packages from 465 contributors and audited 41 packages in 32.545s
                2 packages are looking for funding
                found 1 low severity vulnerability
                processing complete for module MMM-ioBroker
                processing for module MMM-FRITZ-Box-Callmonitor please wait
                added 11 packages from 64 contributors and audited 11 packages in 15.02s
                processing complete for module MMM-FRITZ-Box-Callmonitor
                processing for module MMM-Fuel please wait
                npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                npm WARN eslint-config-recommended@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
                npm WARN eslint-config-esnext@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
                npm WARN eslint-config-node@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
                npm WARN eslint-config-react-native@4.1.0 requires a peer of eslint@^6.0.0 but none is installed. You must install peer dependencies yourself.
                added 584 packages from 375 contributors and audited 584 packages in 366.594s
                38 packages are looking for funding
                processing complete for module MMM-Fuel
                processing for module MMM-PublicTransportHafas please wait
                added 33 packages from 23 contributors and audited 33 packages in 25.836s
                processing complete for module MMM-PublicTransportHafas
                processing for module MMM-Tools please wait
                added 3 packages from 3 contributors and audited 3 packages in 8.165s
                processing complete for module MMM-Tools
                restoring custom.css
                we stashed a set of files that appear changed from the latest repo versions. you should review them
                see installers/stashed_files for the list
                you can use git checkout stash@{0} -- filename to extract one file from the stash
                or git stash pop to restore them all
                WARNING..
                WARNING.. either will overlay the file just installed by the update
                WARNING..
                  sdetweil @kusselin
                  @kusselin cool… looks good… now to run MM… and see if it all works…
                  • kusselinK
                    kusselin
                    no, nothing is good…sorry:
                    i have a black screen :-(
                    > magicmirror@2.13.0 start /home/pi/MagicMirror
                    > ./run-start.sh $1
                    [2020-11-15 18:39:25.557] [LOG]    Starting MagicMirror: v2.13.0
                    [2020-11-15 18:39:25.648] [LOG]    Loading config ...
                    [2020-11-15 18:39:25.691] [LOG]    Loading module helpers ...
                    [2020-11-15 18:39:25.703] [LOG]    No helper found for module: alert.
                    [2020-11-15 18:39:26.107] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:26.112] [LOG]    Module helper loaded: updatenotification
                    [2020-11-15 18:39:26.117] [LOG]    No helper found for module: clock.
                    [2020-11-15 18:39:30.439] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:30.444] [LOG]    Module helper loaded: calendar
                    [2020-11-15 18:39:30.451] [LOG]    No helper found for module: MMM-OpenmapWeather.
                    [2020-11-15 18:39:30.457] [LOG]    No helper found for module: weatherforecast.
                    [2020-11-15 18:39:31.996] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:32.001] [LOG]    Module helper loaded: MMM-Remote-Control
                    [2020-11-15 18:39:32.030] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:32.039] [LOG]    Module helper loaded: MMM-SoccerLiveScore
                    [2020-11-15 18:39:32.059] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:32.062] [LOG]    Module helper loaded: MMM-Tankerkoenig
                    [2020-11-15 18:39:32.069] [LOG]    No helper found for module: MMM-SmartWebDisplay.
                    [2020-11-15 18:39:32.099] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:32.107] [LOG]    Module helper loaded: MMM-ioBroker
                    [2020-11-15 18:39:33.022] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:33.024] [LOG]    Module helper loaded: MMM-FRITZ-Box-Callmonitor
                    [2020-11-15 18:39:33.475] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:33.482] [LOG]    Module helper loaded: MMM-Fuel
                    [2020-11-15 18:39:34.691] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:34.693] [LOG]    Module helper loaded: MMM-PublicTransportHafas
                    [2020-11-15 18:39:34.696] [LOG]    No helper found for module: compliments.
                    [2020-11-15 18:39:35.002] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:35.010] [LOG]    Module helper loaded: MMM-Tools
                    [2020-11-15 18:39:35.216] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:35.222] [LOG]    Module helper loaded: newsfeed
                    [2020-11-15 18:39:35.239] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:35.245] [LOG]    Module helper loaded: MMM-COVID19
                    [2020-11-15 18:39:35.264] [LOG]    Initializing new module helper ...
                    [2020-11-15 18:39:35.270] [LOG]    Module helper loaded: MMM-COVID19-AMPEL
                    [2020-11-15 18:39:35.275] [LOG]    All module helpers loaded.
                    [2020-11-15 18:39:36.247] [LOG]    Starting server on port 8080 ...
                    [2020-11-15 18:39:36.295] [INFO]   You're using a full whitelist configuration to allow for all IPs
                    [2020-11-15 18:39:36.338] [LOG]    Server started ...
                    [2020-11-15 18:39:36.347] [LOG]    Connecting socket for: updatenotification
                    [2020-11-15 18:39:36.355] [LOG]    Connecting socket for: calendar
                    [2020-11-15 18:39:36.359] [LOG]    Starting node helper for: calendar
                    [2020-11-15 18:39:36.363] [LOG]    Connecting socket for: MMM-Remote-Control
                    [2020-11-15 18:39:36.370] [LOG]    Starting node helper for: MMM-Remote-Control
                    [2020-11-15 18:39:36.418] [LOG]    Connecting socket for: MMM-SoccerLiveScore
                    [2020-11-15 18:39:36.424] [LOG]    MMM-SoccerLiveScore helper started...
                    [2020-11-15 18:39:36.427] [LOG]    Connecting socket for: MMM-Tankerkoenig
                    [2020-11-15 18:39:36.430] [LOG]    Starting module helper: MMM-Tankerkoenig
                    [2020-11-15 18:39:36.435] [LOG]    Connecting socket for: MMM-ioBroker
                    [2020-11-15 18:39:36.441] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
                    [2020-11-15 18:39:36.446] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
                    [2020-11-15 18:39:36.451] [LOG]    Connecting socket for: MMM-Fuel
                    [2020-11-15 18:39:36.456] [LOG]    Starting module helper: MMM-Fuel
                    [2020-11-15 18:39:36.459] [LOG]    Connecting socket for: MMM-PublicTransportHafas
                    [2020-11-15 18:39:36.462] [LOG]    Connecting socket for: MMM-Tools
                    [2020-11-15 18:39:36.468] [LOG]    [Tools] MMM-Tools Version: 2.0.3
                    [2020-11-15 18:39:36.472] [LOG]    Connecting socket for: newsfeed
                    [2020-11-15 18:39:36.476] [LOG]    Starting node helper for: newsfeed
                    [2020-11-15 18:39:36.480] [LOG]    Connecting socket for: MMM-COVID19
                    [2020-11-15 18:39:36.484] [LOG]    Starting node helper for: MMM-COVID19
                    [2020-11-15 18:39:36.489] [LOG]    Connecting socket for: MMM-COVID19-AMPEL
                    [2020-11-15 18:39:36.492] [LOG]    Starting node helper for: MMM-COVID19-AMPEL
                    [2020-11-15 18:39:36.494] [LOG]    Sockets connected & modules started ...
                    [2020-11-15 18:39:36.538] [ERROR]  Whoops! There was an uncaught exception...
                    [2020-11-15 18:39:36.543] [ERROR]  Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                        at listenInCluster (net.js:1274:12)
                        at doListen (net.js:1413:7)
                        at processTicksAndRejections (internal/process/task_queues.js:84:9) {
                      code: 'EADDRINUSE',
                      errno: 'EADDRINUSE',
                      syscall: 'listen',
                      address: '0.0.0.0',
                      port: 8080
                    [2020-11-15 18:39:36.573] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [2020-11-15 18:39:36.576] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [2020-11-15 18:39:38.359] [LOG]    Launching application.
                    Username for 'https://github.com':
                      sdetweil @kusselin
                      @kusselin said in Update auf 2.13.0:
                      mirror already running…
                      can’t run two at the same time… (on the same port)
                      • kusselinK
                        kusselin
                        @sdetweil said in Update auf 2.13.0:
                        o.k. and what can i do now…?
                        Sorry for my questions but i´m not the expert as you
                          sdetweil @kusselin
                          @kusselin if you use pm2 to start a boot,
                          pm2 stop all
                          then npm start to test
                          • kusselinK
                            kusselin
                            pi@raspberrypi:~ $ pm2 stop all
                            [PM2] Applying action stopProcessId on app [all](ids: 0)
                            [PM2] [MagicMirror](0) ✓
                            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                            │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                            pi@raspberrypi:~ $ npm start
                            npm ERR! code ENOENT
                            npm ERR! syscall open
                            npm ERR! errno -2
                            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                            npm ERR! enoent This is related to npm not being able to find a file.
                            npm ERR! enoent
                            npm ERR!     /home/pi/.npm/_logs/2020-11-15T18_01_08_239Z-debug.log
                              sdetweil @kusselin
                              @kusselin from the MagicMirror folder
                              • kusselinK
                                kusselin
                                username for github.com?
                                what ist this?
                                  sdetweil @kusselin
                                  @kusselin the updateNotification module if u don’t use it, u can disable it.
                                  add
                                  module:"updatenotification",
                                  disabled: true,       // < this line
                                  • kusselinK
                                    kusselin
                                    the screen is always black :-(
                                    i ihink i have to save the config and i have to install magic mirror new…
                                    what do you think?
                                    • kusselinK
                                      kusselin
                                      after a new installation…can i also copie the save config and all is good?
                                      S 2 Replies Last reply
                                        sdetweil @kusselin
                                        @kusselin upgrade didn’t touch the config, it should be the same as before
                                          sdetweil @kusselin
                                          @kusselin if a NEW install, then u would have to reinstall all the modules and update the config
                                          • kusselinK
                                            kusselin
                                            o.k i musst have to install all the modules again and then i can copie the config in the config folder…right?
                                            And please can you send me a link how i can install about the console the ltest magic mirror please…
                                            • 2 / 4
