    Update auf 2.13.0
    65 Posts 4 Posters 30.1k Views 4 Watching
    • kusselinK Offline
      kusselin
      @sdetweil said in Update auf 2.13.0:
      mirror already running…
      can’t run two at the same time… (on the same port)
      o.k. and what can i do now…?
      Sorry for my questions but i´m not the expert as you
        sdetweil @kusselin
        @kusselin if you use pm2 to start a boot,
        pm2 stop all
        then npm start to test
        • kusselinK Offline
          kusselin
          pi@raspberrypi:~ $ pm2 stop all
          [PM2] Applying action stopProcessId on app [all](ids: 0)
          [PM2] [MagicMirror](0) ✓
          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
          │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
          pi@raspberrypi:~ $ npm start
          npm ERR! code ENOENT
          npm ERR! syscall open
          npm ERR! errno -2
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/.npm/_logs/2020-11-15T18_01_08_239Z-debug.log
            sdetweil @kusselin
            @kusselin from the MagicMirror folder
            • kusselinK Offline
              kusselin
              username for github.com?
              what ist this?
                sdetweil @kusselin
                @kusselin the updateNotification module if u don’t use it, u can disable it.
                add
                module:"updatenotification",
                disabled: true,       // < this line
                • kusselinK Offline
                  kusselin
                  the screen is always black :-(
                  i ihink i have to save the config and i have to install magic mirror new…
                  what do you think?
                  • kusselinK Offline
                    kusselin
                    after a new installation…can i also copie the save config and all is good?
                      sdetweil @kusselin
                      @kusselin upgrade didn’t touch the config, it should be the same as before
                        sdetweil @kusselin
                        @kusselin if a NEW install, then u would have to reinstall all the modules and update the config
                        • kusselinK Offline
                          kusselin
                          o.k i musst have to install all the modules again and then i can copie the config in the config folder…right?
                          And please can you send me a link how i can install about the console the ltest magic mirror please…
                          • kusselinK Offline
                            kusselin
                            can you tell me why the screen is now black?
                              sdetweil @kusselin
                              @kusselin install is the same place u got the upgrade script
                              why are u trying to install again??
                              black screen
                              probably one of the lang files with comments
                              switch to the develop branch
                              git checkout develop
                              • kusselinK Offline
                                kusselin
                                o.k. can you help me once again please that i have a picture…
                                pi@raspberrypi:~ $ cd MagicMirror
                                pi@raspberrypi:~/MagicMirror $ git checkout develop
                                error: Pfadspezifikation 'develop' stimmt mit keinen git-bekannten Dateien überein.
                                  sdetweil @kusselin
                                  @kusselin see here
                                  https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix/2
                                  • kusselinK Offline
                                    kusselin
                                    sorry…its not going with:
                                    git fetch origin develop:develop
                                    after a restart i see fast an white screen and the the black screen :-( and nothing happend
                                      sdetweil @kusselin
                                      @kusselin open the developers console, ctrl-shit-i on the mirror, or chrome from your pc if allowed,
                                      select the tab labeled ‘console’, and scroll up to see any errors…
                                      • kusselinK Offline
                                        kusselin
                                        i can´t see a mistake…you?
                                          sdetweil @kusselin
                                          @kusselin select the tab labeled ‘console’,
                                          • kusselinK Offline
                                            kusselin
                                            i haven´t it
                                            • 3 / 4
